查看: 1013|回复: 0
[NI软件产品] NI RFmx CDMA2000 2025 Q1 Full/Runtime Win11 64bitEn RFmxCDMA2K完整版运行版25.0.0下载
     楼主| 发表于 2025-4-16 14:52:04 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx CDMA2000
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版/运行版,版本号25.0.0
    64位完整版校验和:
    文件大小: 1251846144 字节 (1.17 GB)
    修改日期: 2025-03-12 11:05
    MD5: 60b6aa75e0020ed98bfcb01990462276
    SHA1: 52c901240aafc621957761efea73970a269b4cca
    SHA256: 3841d0e254787c62d40421696cf6e61d0f77cb2a265a62734018e90f696dea41
    CRC32: 5ac80458
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2K2025Q1Full.txt (543 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1045999616 字节 (997.54 MB)
    修改日期: 2025-03-12 11:10
    MD5: 0802ffa3570b04def463a42c9251587d
    SHA1: 70601a260d129b0ae97abb98258efd8cee887b98
    SHA256: 7cf463ff2d208e4751ddb80db2433a0d3fa9af9b8fdefd491bdf6faeb4775af3
    CRC32: 5c8c86c9
    RFmx CDMA2K2025Q1RTE.txt (568 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q1版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2025-12-8 07:32
