NI RFmx EV-DO 2025 Q1 Win11 64bitEng 1xEV-DO蜂窝测试软件25.0.0
RFmx EV-DO
RFmx EV-DO为1xEV-DO蜂窝测试应用提供信号生成和分析功能。
RFmx EV-DO是一款测量专用软件,旨在扩展NI RF仪器生成和分析EV-DO蜂窝信号的能力。该软件可以通过误差矢量幅度(EVM)、码域误差(CDE)、相邻信道泄漏比(ACLR)、频谱发射屏蔽(SEM)等符合标准的物理层测量,对1xEV-DO反向链路信号进行分析。借助RFmx,您可通过交互式软面板快速轻松地执行和调试测量,使用RFmx Waveform Creator创建和回放开放的未锁定波形,并结合更高性能的API加快自动化测试的速度。
发布日期:2025/1/23
包含的版本:2025 Q1完整版/运行版,版本号25.0.0
64位完整版校验和:
文件大小: 1252147200 字节 (1.17 GB)
修改日期: 2025-03-12 15:14
MD5: f36806631401d71870ca4224c9dbf644
SHA1: 60a1c533feccad633d5c076a8ed603e7ea3a2495
SHA256: c0085ed761086fa04d92a6c4e961e8b96eeba456dd604bc3113e03209896f0cf
CRC32: d53b50b5
NI官方下载和百度网盘下载地址:
请注册登录机器视觉论坛账号,购买附件查看下载地址
EVDO2025Q1Full.txt
(534 Bytes, 下载次数: 0, 售价: 10 圆)
64位运行版校验和:
文件大小: 1046138880 字节 (997.68 MB)
修改日期: 2025-03-12 14:50
MD5: ef709af1bda36be7e3a036439a5434e5
SHA1: 90eb7f0b87e95819de95b9d9d52827e056179f61
SHA256: 8882d29bc09f352e88ab32a46887d749f05788db2b902bc689f2a0664c8ee03a
CRC32: 90682eea
NI官方下载和百度网盘下载地址:
EVDO2025Q1RTE.txt
(559 Bytes, 下载次数: 0, 售价: 5 圆)
2025Q1版未更新自述文件,参考2023Q3版本
RFmx EV-DO 2023 Q3 ReadmeJuly 2023 This file contains important information about the RFmx EV-DO, including system requirements, and installation instructions. You can find more release information on ni.com. - RFmx EV-DO Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- RFmx EV-DO Manuals: New features, behavior changes, and other documentation
New Features Supported Hardware System Requirements Supported Operating Systems Application Software Support Installation Instructions Installed Software File Locations Executable Accessing the API Accessing the Documentation Finding Examples Product Security and Critical Updates Behavior Changes Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 New FeaturesRFmx EV-DO 2023 Q2 includes the following new feature: - Speed improvements for Composite and Spectral measurements
RFmx EV-DO 2023 Q1 includes the following new feature: - Support for LabVIEW 2023 Q1 (64-bit)
RFmx EV-DO 2022 Q4 includes the following new feature:
Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. System RequirementsRFmx EV-DO has the following requirements: - Processor—1 GHz 64-bit (x64) processor
- 4 GB RAM *
- Any supported OS, with all available critical updates and service packs
* Depending on the amount of data acquired and/or processed, a larger amount of memory may be required. Supported Operating SystemsRFmx EV-DO 2023 Q3 supports the following 64-bit operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note RFmx EV-DO no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx EV-DO 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx EV-DO 2023 Q3 to an unsupported OS. Additionally, after installing RFmx EV-DO 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS. Application Software SupportRFmx EV-DO supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx EV-DO. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by RFmx EV-DO (64-bit only) | | LabVIEW | 2020 SP1, 2021 SP1 f1 patch, 2022 Q3, 2023 Q1, 2023 Q3 | Required Software- NI-RFSA 14.1 or later
- NI-RFSA 17.1 or later (for initializing debug session when "using breakpoints in C/C++/.NET application" is selected)
Microsoft Visual Studio SupportIf you are using the RFmx EV-DO .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx EV-DO .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. Installation InstructionsDownload the RFmx EV-DO installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Notes - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- Use the serial number that is included with your software to activate RFmx EV-DO. For more information on RFmx EV-DO activation, refer to National Instruments Software Activation.
Installed Software- is an alias for the following National Instruments file folder location:
- Program Files (x86)\National Instruments\MeasurementStudioVS2010
- is an alias for the following file folder location:
- Windows\SysWOW64 for 32-bit programs and windows\system32 for 64-bit programs
File LocationsItem | Installed Location | | Version Compatibility Checker | \RFmx\niRFmxCompatibility_Checker.exe | | Debug Configuration Utility | \RFmx\niRFmxDebugConfigurationUtility.exe | | DLLs | | | Header files | \Shared\ExternalCompilerSupport\C\include | | Import Library files (64-bit) | - 32-bit: \Shared\ExternalCompilerSupport\C\lib32\msvc
- 64-bit: \Shared\ExternalCompilerSupport\C\lib64\msvc
| | .NET Class Libraries | | Assemblies | \DotNET\Assemblies\Current\NationalInstruments.RFmx.EvdoMx.Fx40.dll
\DotNET\Assemblies\Current\NationalInstruments.Common.dll | ExecutableSelect Start » National Instruments» RFmx EV-DO Measurement Interactive Panel to launch the RFmx EV-DO Measurement Interactive Panel. Accessing the APIRFmx EV-DO palette VIs are available from the Functions » Measurement I/O » RFmx » EVDO palette. Accessing the DocumentationDocumentation for RFmx EV-DO is located at Start » National Instruments » RFmx EV-DO Documentation. Finding ExamplesYou can access all the installed RFmx EV-DO examples at Start » National Instruments » RFmx EV-DO Examples. For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Behavior ChangesThe following is the behavior change in RFmx EV-DO 2023 Q3 from RFmx EV-DO 2023 Q2 - Added support for saving and loading RFmx configurations into/from rfmxconfig files. Load from TDMS is supported but save into TDMS files is discontinued.
The following is the behavior change in RFmx EV-DO 2022 Q4 from RFmx EV-DO 2022 Q3 - RFmx EV-DO drops support for 32-bit user mode.
The following is the behavior change in RFmx EV-DO 20.7 from RFmx EV-DO 20.6. - Obsoleted the RFmxInstr Configure Automatic SG SA Shared LO API and the RFmxInstr Automatic SG SA Shared LO property. Use RFmxInstr LO Source property with Automatic_SG_SA_Shared value instead.
The following is the behavior change in RFmx EV-DO 19.1 from RFmx EV-DO 19.0. - Obsoleted RFmxEVDO Analyze (IQ) and RFmxEVDO Analyze (Spectrum) APIs. Use RFmxEVDO Analyze (IQ, 1 Wfm) and RFmxEVDO Analyze (Spectrum, 1 Wfm) APIs instead
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. |
