查看: 1052|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2025 Q1 Patch 1 Win11 64bitENG RFmx蜂窝测试TD-SCDMA25.0.1
     楼主| 发表于 2025-4-21 11:25:49 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx TD-SCDMA
    发布日期:2025/2/19
    包含的版本:2025 Q1 Patch 1完整版/运行版,版本号25.0.1
    64位完整版校验和:
    文件大小: 2390691840 字节 (2.23 GB)
    修改日期: 2025-03-12 15:01
    MD5: 621b23e7dfe8b26ca683e94fcaf0605d
    SHA1: 28868a2ebfe88468d0ae6ba36b83569d2b7a2a7a
    SHA256: 02e8b53172ec1346c4080e27d9370003382a3b3c2f64ff0ed28165e1b856dd09
    CRC32: deb6a752
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    TD-SCDMA2025Q1F1Full.txt (554 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1046210560 字节 (997.74 MB)
    修改日期: 2025-03-12 15:11
    MD5: 3d1a2e867e8f89e8b007fd3b0d13cee7
    SHA1: d0368b31d4761ce76dede7e0d43eaf7c8df6067c
    SHA256: 51fd81523df799f8d9351ad1c4bade9a3d82699cf5f461a88770d003bdeb58b2
    CRC32: 00a62da0
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    TD-SCDMA2025Q1F1RTE.txt (579 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q1Patch1未更新自述文件,参考2023Q3版本
    RFmx TD-SCDMA 2023 Q3 Readme
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2025-12-8 07:32
