查看: 687|回复: 0
[NI驱动程序] NI RF Signal Generators 2025 Q1 Win11 32/64bitEng NI RF信号发生器NI-RFSG25.0.0
  • 签到天数: 3734 天
    连续签到: 61 天
     楼主| 发表于 2025-4-24 11:10:14 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-RFSG
    NI-RFSG 2025 Q1
    发布日期:2025/1/22
    包含的版本:2025 Q1完整版,版本号25.0.0
    文件大小: 4970485760 字节 (4.63 GB)
    修改日期: 2025-03-11 17:30
    MD5: 6d0f9b201f6c8ceeeab5ba4c132c15cb
    SHA1: 16947bb0de34e0903fb94c3c8917b4f3bab27a4a
    SHA256: 4665941a86495e678c1a2e3dfcdc86a5129e098b86ae1b28e59f45398fe2ca3d
    CRC32: a138872d
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFSG2025Q1.txt (510 Bytes, 下载次数: 0, 售价: 10 圆)
    NI-RFSG2025Q1版未更新自述文件,参考2023Q3版
    NI-RFSG 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-RFSG 2023 Q3.
    • NI-RFSG Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-RFSG Documentation: New features, behavior changes, and other documentation
    NI-RFSG 2023 Q1 Patch 1 includes the following new feature:
    NI-RFSG 2023 Q1 includes the following new feature:
    • Support for LabVIEW 2023 Q1
    NI-RFSG 2022 Q4 includes the following new feature:
    Note  You must install the same version of the NI-RFSA/NI-RFSG Runtime for PXIe-5644/5645/5646 and NI-RFSA/NI-RFSG Runtime for PXIe-5820/5830/5831/5832/5840/5841/5842 if you choose to install the runtimes independently.
    • 4 GB RAM*
    Note  NI-RFSG 2023 Q3 is not compatible with NI-RFSA 2.6. Upgrade to NI-RFSA 2.7 or later before installing NI-RFSG 2023 Q3.
    NI-RFSG and NI-RFSG SFP support the following operating systems:
    • NI Linux® Real-Time
    Versions Supported by NI-RFSG
    LabVIEW2020 and later
    LabWindows/CVI2019 and later
    Accessing the APILabVIEW
    LabWindows/CVI
    .NET Framework
    C
    NI-RFSG SFP
    The "NI-RFSG Support for LabVIEW" package supports applications using NI-RFSG ​with LabVIEW 2023 Q1 or later. When installing NI-RFSG, this package will be recommended if you have already installed LabVIEW 2023 Q1 or later and installs to the LVAddons directory.
    You can access all the installed NI-RFSG examples at Start»All Programs»National Instruments»NI-RFSG»NI-RFSG Examples.
    Documentation for NI-RFSG is located at Start»All Programs»National Instruments»NI-RFSG»Documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    • Hardware device overviews
    Other documentation for NI-RFSG can be found in Program Files\IVI Foundation\IVI\Drivers\niRFSG\documentation. This documentation set is composed of the following documents.
    Document
    Format
    Description
    NI-RFSG no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-6 17:24
