查看: 853|回复: 0
[NI驱动程序] NI-SCOPE 2025 Q1 Win11 32/64bitEng/Jpn NI示波器驱动程序SCOPE25.0.0
     楼主| 发表于 2025-4-25 10:21:20 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI-SCOPE
    NI-SCOPE为使用NI示波器产品的客户提供支持。
    NI-SCOPE 2025 Q1
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.0.0
    语言:English英文,日语Japanese
    文件大小: 3791558656 字节 (3.53 GB)
    修改日期: 2025-03-12 17:36
    MD5: 71c2a5bb35e0f4ee4b7602d46a678a17
    SHA1: 3b69942c778190267141f0e766cecd7c26550fb2
    SHA256: 846d776addbec5a362341c885cb34410d7b8a1defdc14a99342e86f7c5d57272
    CRC32: 6cf9dbd2
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    SCOPE2025Q1.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版未更新自述文件,请参考2023Q3版
    NI-SCOPE 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-SCOPE 2023 Q3.
    • NI-SCOPE Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-SCOPE Documentation: New features, behavior changes, and other documentation
    NI-SCOPE is an NI instrument driver that enables you to implement multirecord acquisition, continuous acquisition, multiboard synchronization, more than 50 measurement and analysis functions, and the functionality of traditional oscilloscopes. NI-SCOPE is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the oscilloscope and includes an interactive soft front panel and examples.
    NI-SCOPE 2023 Q3 has the following requirements:
    • 1 GHz or faster 64-bit (x64) processor
    • If you are running your application on a RT target, at least 128 MB of disk space
    • At least 2 GB RAM (x64)
    NI-SCOPE 2023 Q3 supports the following operating systems:
    • NI Linux® Real-Time1
    1 This operating system is not supported for the following features:
    • Test panels as accessible from NI Measurement & Automation Explorer (NI MAX)
    Note  NI-SCOPE no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    NI-SCOPE 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support or Python Support.
    Versions Supported by NI-SCOPE 2023 Q3
    LabVIEW2020 and later
    LabWindows/CVI Real-Time Module22019 and later
    2No support for the PXIe-5110/5111/5113, the PXIe-5163, or the PXIe-5164 and PXIe-517x reconfigurable oscilloscopes.
    If you are using the NI-SCOPE .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-SCOPE 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using Python, refer to the niscope module.
    Download the NI-SCOPE installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Uninstalling NI-SCOPE
    As part of the NI-SCOPE installation, the following software is installed. To completely remove the NI-SCOPE installation from your system, you must also remove all of the following packages:
    • NI-DAQmx
    • NI I/O Trace
    Notice  Several of the software packages listed above are shared with other NI software packages. If you attempt to remove a piece of software that something else is dependent on, a message launches to warn you about the software dependencies. You can choose to either uninstall all of the software or to leave the shared software installed. If you choose to uninstall the shared software, some of your other NI software may no longer function correctly.
    When installing NI-SCOPE, the "NI-SCOPE Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. This package supports applications using NI-SCOPE with LabVIEW 2022 or later.
    • The NI-SCOPE Soft Front Panel has been replaced by InstrumentStudio, which is automatically installed when you install the NI-SCOPE driver. You can access InstrumentStudio in one of the following ways:
      • From Windows, select Start»National Instruments»InstrumentStudio. This launches InstrumentStudio and runs a soft front panel populated with devices detected on your system.
      • From NI MAX, select a device and click Test Panels.... This launches InstrumentStudio and runs a soft front panel for the device you selected.
      Note   The deprecated NI-SCOPE Soft Front Panel remains available for download. Visit Legacy Soft Front Panels for NI-SCOPE for more information.
    • For help with the NI-SCOPE driver, refer to the NI High-Speed Digitizers Help, accessible by selecting Help»NI High-Speed Digitizers Help.
    • For help with InstrumentStudio, used to configure and monitor NI-SCOPE devices, refer to the InstrumentStudio help at ni.com.
    NI-SCOPE ships with several examples for LabVIEW, LabWindows/CVI, Measurement Studio, MSVC, Visual C++, and Microsoft Visual Basic that will help you develop your software. These examples illustrate how to perform the most common operations with your hardware. To find the examples, go to Start»Programs»National Instruments»NI-SCOPE Examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for NI-SCOPE are located in the labview\examples\instr\niScope directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    NI-SCOPE no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-8 08:03
