查看: 1320|回复: 0
[NI软件产品] LabVIEW 2025 Q1 FPGA Module Xilinx Compilation Tools Linux64Eng LV2025Q1 FPGA编译工具(Vivado 2021.1)
    昨天 08:18
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2025-4-28 09:47:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    LabVIEW 2025 Q1 FPGA Module Xilinx Compilation Tools  Win10 32/64bitEng LV2025Q1 FPGA编译工具(Vivado 2021.1)
    LabVIEW 2025 Q1 FPGA Compilation Tool for Vivado 2021.1
    发布日期:2025/1/23
    包含的版本:2025 Q1完整版,版本号25.1.0
    支持:Vivado 2021.1
    文件大小: 15751659520 字节 (14.67 GB)
    修改日期: 2025-03-13 16:10
    MD5: 4f8532f631af41271379b574923f2cbc
    SHA1: 5acb2cfe25ee747ae07a2217cb8536d71f650a45
    SHA256: cdd5c0b9a406276ab6e872b9e0d005e18b8fc99515b2e67f858749f547e7b0b9
    CRC32: 617fd712
    百度网盘下载和NI官方下载地址:
    请注册视觉论坛会员,登录购买附件查看,充值请联系在线客服
    LabVIEW FPGA Compilation Tool LabVIEW2025Q1.txt (618 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q1版未更新自述文件,参考2022Q3版本
    LabVIEW 2022 Q3 FPGA Module Xilinx Compilation Tools for Windows Readme
    July 2022
    This file contains important information about the LabVIEW FPGA Module Xilinx Compilation Tools for Windows, including system requirements and installation instructions.
    The Xilinx compilation tools include tools for Vivado 2021.1, which are supported by the LabVIEW FPGA Module. Install these compilation tools if you want to compile FPGA VIs on a Windows computer. You must install these tools on the FPGA Module development computer if you plan to use the Configure Component-Level IP wizard, configure the IP Integration Node, incorporate Xilinx IP, or use third-party simulation.
    The Xilinx compilation tools also support Linux. Refer to the FPGA Module Xilinx Compilation Tools for Linux Readme for more information.
    The Xilinx compilation tool for Vivado 2021.1 has the following system requirements:
      • Windows 11 (64-bit)
      • Windows 10 (version 1909) (64-bit)
    • 15 GB of additional disk space
    • Memory—Refer to the Xilinx website at www.xilinx.com for memory requirements of different FPGA targets. Failure to meet the target-specific memory requirement may result in unpredictable compilation results.
      Note  The recommended memory size on the Xilinx website is for one compile job only. If you run multiple compile jobs at a time, the memory requirement increases by multiple times accordingly.
    Note After installing the LabVIEW 2022 Q3 FPGA Module Xilinx Compilation Tools, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Visit Compatibility between Xilinx Compilation Tools and NI FPGA Hardware for the list of NI hardware supported by Xilinx compilation tools for Vivado.
    NI installs the Xilinx Compilation Tools for Windows using NI Package Manager. If you do not already have NI software installed, the Xilinx Compilation Tools installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install the Xilinx Compilation Tools for Windows using the installation media. Depending on the installation media type, you can install the Xilinx Compilation Tools for Windows in either of the following ways:
    (USB) Complete the following steps to install the Xilinx Compilation Tools for Windows:
    • Insert the Xilinx compilation tools installation media.
    • Navigate to the Windows\Vivado2021_1.
    • Double-click Install.exe on the media to begin installation.
    • Follow the instructions on the screen to complete the installation.
    Note In case of compiler issues, refer to 66184 - Install - How do I find out which libraries are required to run Vivado tools in Linux? for additional information.
    For more information about NI support for Windows 10, visit ni.com/windows10.
    © 2012–2022 National Instruments Corporation. All rights reserved.
    Third-Party Copyright Notices
    \LabVIEW \FPGA\Legal
    For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the National Instruments Patent Notice at ni.com/patents.
    GMT+8, 2025-12-6 07:17
