NI-DMM 2025 Q2 Driver Win11 32/64bitEng/JPN NI数字万用表驱动程序25.3.0下载
NI-DMM
NI-DMM支持使用NI数字万用表的客户。
NI-DMM是与所有NI可编程数字万用表(DMM)进行通信必需的NI仪器驱动程序。NI-DMM是一种兼容可互换虚拟仪器(IVI)的仪器驱动程序,提供了一系列操作和属性,可以执行波形或信号发生器的功能,而且包含了交互式软件前面板和示例。
NI-DMM 2025 Q2
发布日期:2025/4/9
包含的版本:2025 Q2完整版,版本号25.3.0
Windows Server 2025
语言:英文English/日语Japanese
文件大小: 3538700288 字节 (3.30 GB)
修改日期: 2025-04-12 15:09
MD5: 8ec93278ac7d537a7e88579d2906902f
SHA1: 0fd68c8befea70a2d178fd452781b40943a952be
SHA256: be4682cb74fbd22bf621ed1d79c67a7b33968aca27bf4dea3ae0d8d6764f6081
CRC32: e7b7a767
请注册登录机器视觉论坛后台,购买附件查看下载地址
DMM2025Q2.txt
(506 Bytes, 下载次数: 0, 售价: 10 圆)
2025Q2未更新自述文件,参考2023Q3版本
NI-DMM 2023 Q3 ReadmeJuly 2023 This file contains installation instructions and compatibility information for NI-DMM 2023 Q3. You can find more release information on ni.com. - NI-DMM Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- NI-DMM Documentation: New features, behavior changes, and other documentation
System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates Supported Hardware Accessing the Documentation Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems NI no longer supports Phar Lap ETS Real-Time Operating System System RequirementsNI-DMM 2023 Q3 has the following requirements: Minimum System Requirements- Processor—2.53 GHz Intel Core 2 Duo processor or equivalent
- RAM—1 GB, 800 MHz DDR2 RAM
Recommended System- Processor—2.3 GHz quad-core Intel Core i7 or equivalent
- RAM—4 GB, dual-channel 1600 MHz DDR3 RAM
Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW. Supported Operating SystemsNI-DMM 2023 Q3 supports the following operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
- NI Linux® Real-Time
Note NI-DMM no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportNI-DMM 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by NI-DMM | | LabVIEW | 2020 and later | | LabVIEW Real-Time Module | 2020 and later | | LabWindows™/CVI™ | 2019 and later | | LabWindows/CVI Real-Time Module | 2019 and later |
This product no longer supports LabVIEW NXG. Refer to LabVIEW NXG on ni.com for more information about LabVIEW NXG Life-Cycle Dates and driver version support. Microsoft Visual Studio SupportIf you are using the NI-DMM .NET Class Library, the .NET Framework 4.0 (minimum) is required. The NI-DMM .NET Class Library can be used with the Visual C# or Visual Basic .NET programming languages in any Visual Studio version that can target the .NET Framework 4.0 or the .NET Framework 4.5. To use the .NET API, you must select the .NET Framework 4.0 Languages Support or the .NET Framework 4.5 Languages Support packages in the NI-DMM installer to install the .NET class libraries in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software. Python SupportFor more information on installing and using Python, refer to the nidmm module. Installation InstructionsDownload the NI-DMM installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager. After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Please visit ni.com/activate for more information on activation methods. Note - If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
- If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation media that shipped with your purchase to install this product.
The "NI-DMM Support for LabVIEW" package supports applications using NI-DMM with LabVIEW 2022 or later. When installing NI-DMM, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. LVAddons directory location: C:\Program Files\NI\LVAddons Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Supported HardwareVisit NI Hardware and Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. Accessing the DocumentationRefer to the NI Digital Multimeters Help, accessible from Start»All Programs»National Instruments» NI-DMM»NI-DMM Documentation, for information about NI-DMM. Finding ExamplesYou can access all the installed NI-DMM examples at Start»All Programs»National Instruments»NI-DMM»NI-DMM Examples and online at ni.com/examples. Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-DMM are located in the LabVIEW XXXX\examples\instr\niDMM directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions: - Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–DMM or by directory structure at instr»niDMM.
- Click the Search tab to search all installed examples by keyword. For example, search for "DMM" to locate all NI-DMM examples.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager documentation. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsNI-DMM no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. NI No Longer Supports Phar Lap ETS Real-Time Operating SystemNI Software no longer supports Phar Lap ETS Real-Time Operating System. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi. |
