NI-FGEN 2025 Q2 Win11 32/64bitEng/Jpn NI-FGEN波形发生器仪器驱动程序25.3.0
NI-FGEN
NI-FGEN为使用NI波形发生器产品的客户提供支持。
NI-FGEN 2025 Q2
发布日期:2025/4/9
包含的版本:2025 Q2完整版,版本号25.3.0
Windows Server 2025
语言:英文English/日语Japanese
文件大小: 3638720512 字节 (3.39 GB)
修改日期: 2025-04-12 15:08
MD5: 806e8931acb1e6298740f95df6fd4ed8
SHA1: 475729127b3fd5f71606d4db83fff455e2a2b6c5
SHA256: 3d21aee68c348af9e87423165925ec4588f24b091071ea2b37edea128390c3d5
CRC32: c80221e1
请注册登录机器视觉论坛账号,购买附件查看下载地址
FGEN2025Q2.txt
(510 Bytes, 下载次数: 0, 售价: 10 圆)
2025Q2版本未更新自述文件,参考2023Q3
NI-FGEN 2023 Q3 ReadmeJuly 2023 This file contains installation instructions and compatibility information for NI-FGEN 2023 Q3. You can find more release information on ni.com. - NI-FGEN Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- NI-FGEN Documentation: New features, behavior changes, and other documentation
Overview System Requirements Supported Hardware Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates IVI Compliance Package Functionality Accessing the Documentation Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems NI no longer supports Phar Lap ETS Real-Time Operating System OverviewNI-FGEN is an NI instrument driver that enables you to implement frequency sweeping and hopping, waveform linking and looping, and frequency shift keying (FSK) modulation for complex measurement solutions. NI-FGEN is an interchangeable virtual instrument (IVI)–compliant instrument driver, and it features a set of operations and properties that exercise the functionality of the waveform or signal generator and includes an interactive soft front panel and examples. System RequirementsNI-FGEN 2023 Q3 has the following requirements: - Processor—1 GHz or faster 64-bit (x64) processor
- RAM—2 GB RAM (64-bit)
Supported Operating SystemsNI-FGEN 2023 Q3 supports the following operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
- NI Linux® Real-Time
Note NI-FGEN no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportNI-FGEN 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support. Application Software | Versions Supported by NI-FGEN 2023 Q3 | | LabVIEW | 2020 and later | | LabVIEW Real-Time Module with NI Linux® Real-Time | 2020 and later | | LabWindows™/CVI™ | 2019 and later | | LabWindows™/CVI™ Real-Time Module | 2019 and later |
This product no longer supports LabVIEW NXG. Refer to LabVIEW NXG on ni.com for more information about LabVIEW NXG Life-Cycle Dates and driver version support. Microsoft Visual Studio SupportIf you are using the NI-FGEN .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-FGEN 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5. To use the .NET API, you must install the .NET class libraries or the .NET wrapper in addition to the NI device driver. For information about versions of the .NET Framework and the drivers each supports, as well as the download location of the installer files, refer to .NET Resources for NI Hardware and Software. Python SupportFor more information on installing and using Python, refer to the nifgen module. Installation InstructionsDownload the NI-FGEN installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager. After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Please visit ni.com/activate for more information on activation methods. If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue. If you purchased this product with an NI Software Suite or NI Product Bundle, use the installation method of the Suite or Bundle. NI Script Editor is no longer installed with NI-FGEN. Updated LabVIEW Compatibility PolicyThe "NI-FGEN Support for LabVIEW" package supports applications using NI-FGEN with LabVIEW 2022 or later. When installing NI-FGEN, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory. LVAddons directory location: - Windows C:\Program Files\NI\LVAddons
- Linux /usr/local/natinst/share/lvaddons
Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. IVI Compliance Package FunctionalityNI-FGEN no longer installs IVI Compliance Package (ICP). NI-FGEN supports IVI configuration and runtime, but no longer installs the following IVI components: - LabVIEW and CVI IVI class drivers for developing IVI interchangeable applications
- IVI Class Simulation drivers
- IVI-COM Adapters
To use these features, you must install ICP separately. ICP is included in the Software Platform Bundle media. A stand-alone web distribution is available from ni.com/downloads. Onboard Signal ProcessingNI-FGEN driver when used with NI Linux® Real-Time will not support Onboard Signal Processing. This feature remains supported on Windows. Upgrading FirmwareThe PXIe-5442, PXIe-5450, and PXIe-5451 have upgradeable device firmware. It is highly encouraged and may be required that you upgrade the firmware on these devices; newer firmware contains new features and important bug fixes. To update the firmware, run the Firmware Updater application for your device (54xxFirmwareUpdater_X.Y.Z.exe, where 54xx is the name of the device and X.Y.Z is the firmware version) that is installed in the Program Files (x86)\National Instruments\NI-FGEN\ directory. This application upgrades your firmware to the latest available version that works with this driver. After the application runs, you are required to power down your computer and PXI Express chassis to complete the firmware update. Supported HardwareVisit NI Hardware and Software Operating System Compatibility to view driver, desktop operating system, and real-time operating system support for individual hardware devices. To view information for your device: - Select your hardware model in the dropdown list on the page to view compatibility information for your device.
- Type your hardware model number in the dropdown list on the web page to filter the list of available devices.
Note: Some compatibility information may only be available in the archive attached to the NI Hardware and Software Operating System Compatibility page. For historic driver and OS support information, refer to the readme for the relevant driver version. Behavior ChangesNote The deprecated NI-FGEN Soft Front Panel remains available for download. Visit Legacy Soft Front Panels for NI-FGEN for more information. Accessing the DocumentationRefer to the NI Signal Generators Help, accessible from Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Documentation, for information about NI-FGEN. Finding ExamplesYou can access all the installed NI-FGEN examples for LabVIEW, LabWindows/CVI, C, and .NET at Start»All Programs»National Instruments»NI-FGEN»NI-FGEN Examples and online at ni.com/examples. Examples also are available online that demonstrate integrating NI waveform generators with NI toolkit software including the Modulation Toolkit. Refer to ni.com/examples for these examples and for more information. Select Help»Find Examples from LabVIEW or LabWindows/CVI to launch the NI Example Finder. LabVIEW examples for NI-FGEN are located in the LabVIEW XXXX\examples\instr\niFgen directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create. The NI Example Finder offers two ways to access all installed LabVIEW example VIs and their descriptions: - Click the Browse tab to locate modulation examples by task at Hardware Input and Output»Modular Instruments»NI–FGEN or by directory structure at instr»niFgen.
- Click the Search tab to search all installed examples by keyword. For example, search for "FGEN" to locate all waveform generator examples.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager documentation. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsNI-FGEN no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. NI No Longer Supports Phar Lap ETS Real-Time Operating SystemNI Software no longer supports Phar Lap ETS Real-Time Operating System. Versions of this product that ship after May 1, 2022, may not install or execute correctly on this operating system. For high-level information on the support roadmap for Phar Lap and its replacement, NI Linux Real-Time, visit ni.com/r/xf35k1. To find out what hardware is supported on PXI controllers running NI Linux Real-Time, visit ni.com/r/b7g5wi. |
