查看: 901|回复: 0
[NI驱动程序] NI Linux Device Drivers 2025 Q2 Online Linux64Eng Linux设备驱动程序2025Q2DeviceDrivers在线安装
  • 签到天数: 3733 天
    连续签到: 60 天
     楼主| 发表于 2025-5-15 09:03:40 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI Linux Device Drivers 2025 Q2 Online Linux64Eng Linux设备驱动程序NILinux2025Q2DeviceDrivers在线安装
    NI Linux仪器驱动程序
    NI Linux Device Drivers软件为采用Linux操作系统的NI和第三方硬件提供了所需的NI仪器驱动。
    NI Linux Device Drivers软件为各种NI测试和测量硬件提供了Linux桌面支持。该软件提供了一个存储库附加工具,下载该附加工具后,就可以指示Linux软件包管理器安装NI驱动软件包,如NI-DAQmx、NI-VISA、NI-488.2和NI-Sync。NI Linux Device Drivers软件也支持LabVIEW。
    发布日期:2025/4/9
    包含的版本:2025 Q2完整版
    RedHat
    SUSE
    Ubuntu
    程序位数:64位
    语言:英文English
    文件大小: 432553 字节 (422.42 KB)(在线安装版本,文件很小,需要连网从NI服务器下载资源安装)
    修改日期: 2025-04-11 19:22
    MD5: 0f93a31c6bfc4da0d4346e84996aabc7
    SHA1: 3f88879deab6df584e92bec36fa2e107241f18cb
    SHA256: 8bef19c41a2269f5afa3414a2e7bf5d621e68122963253d956e97d022b4b9b48
    CRC32: 02139e08
    百度网盘和NI官方下载地址(在线安装,需要连网支持,且能正常连接NI服务器):
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    2025Q2版未更新自述文件,参考2023Q3版
    NI Linux Device Drivers 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI Linux Device Drivers 2023 Q3.
    • NI Linux Device Drivers Release Notes: for known issues, bugs fixed since the last release, and other release details.
    Package Repositories
    Supported Drivers
    NI Linux Device Drivers software provides Linux Desktop support for a variety of NI test and measurement hardware. It offers repository registration packages for each supported Linux distribution. Once the appropriate driver software repository is registered for the system, use the Linux distribution's native package manager to install NI driver software packages.
    • Hardware Configuration Utility support for RF composite devices
    Refer to Download and Install NI Driver Software on Linux Desktop.
    NI Linux Device Drivers are installed from one of the following two options.
    • Static repository registration packages are labeled with a date-based suffix, such as ni-rhel8-drivers-2023Q2. Software from this repository is not intended to change, and it is updated only for critical patches. Use this kind of repository when you need to reproduce a specific software stack.
    • Stream repository registration packages are labeled with a -stream suffix, for example: ni-rhel8-drivers-stream. Software in this repository is updated regularly with the latest versions of each driver package as it is released. Running an update/upgrade command with a package manager will update installed NI packages to their latest released version for systems that have registered a stream repository. This kind of repository is the simplest way to keep NI driver software up to date.
    Firstlook is present in some repository registration package names, for example ni-ubuntu2204firstlook-drivers-2023Q2.deb. Firstlook identifies a newer repository that is now in an introductory roll-out phase as NI steadily adds and validates individual drivers over the course of multiple releases. Although not yet comprehensive, support for these repositories is progressing to the same level to that of other distributions.
    If you plan to upgrade to a new distribution and you see "firstlook" in its NI repository registration package name, refer to the Supported Drivers table to ensure that the NI products you need support the new distribution.
    Supported Drivers
    For a list of supported hardware, refer to the NI Hardware and Operating System Compatibility page. For details about a specific driver's system requirements, limitations, and so on, refer to the readme for the individual driver (linked below).
    The following table shows driver support for several Linux distributions. Use your Linux distribution's package manager to install the specified add-on files for an NI driver.
    NI Driver Support for Linux Distributions
    Driver
    Packages
    RHEL18
    RHEL1 9
    openSUSE2 15.3
    openSUSE2 15.4
    Ubuntu3 20.04
    Ubuntu3 22.04
    Driver
    Release Notes
    Tested Kernel
    4.18
    5.14
    5.3
    5.14
    5.13
    5.15
    NI-488.2
    Required Packages:
    ni-488.2
    Optional Packages:
    libni4882-devel
    ni-488.2-iotrace-support
    NI-488.2 2023 Q3
    Automotive Diagnostic
    Command Set Toolkit
    Required Packages:
    ni-adcs
    Optional Packages:
    ni-adcs-labview-20xy-support
    libnidiagcs-devel
    Automotive Diagnostic Command Set Toolkit 2022 Q4
    NI-DAQmx
    Required Packages:
    ni-daqmx
    Optional Packages:
    ni-daqmx-labview-20xy-support
    ni-daqmx-labview-support
    libnidaqmx-devel
    NI-DAQmx 2023 Q3
    NI-DCPower
    Required Packages:
    ni-dcpower
    Optional Packages:
    ni-dcpower-daqmx
    ni-dcpower-labview-20xy-support
    ni-dcpower-labview-support
    ni-dcpower-devel
    NI-DCPower 2023 Q3
    NI-DMM
    Required Packages:
    ni-dmm
    Optional Packages:
    ni-dmm-daqmx
    ni-dmm-labview-20xy-support
    ni-dmm-labview-support
    ni-dmm-devel
    NI-DMM 2023 Q3
    ECU Measurement and
    Calibration Toolkit
    Required Packages:
    ni-ecumc
    Optional Packages:
    ni-ecumc-labview-20xy-support
    libniemcc-devel
    ECU Measurement and Calibration Toolkit 2022 Q4
    NI-FGEN
    Required Packages:
    ni-fgen
    Optional Packages:
    ni-fgen-daqmx
    ni-fgen-devel
    ni-fgen-labview-support
    ni-fgen-labview-20xy-support
    NI-FGEN 2023 Q3
    FlexRIO
    Required Packages:
    ni-flexrio
    Optional Packages:
    ni-flexrio-795x
    ni-flexrio-796x
    ni-flexrio-797x
    libniflexrioapi-devel
    ni-flexrio-modulario-libs-devel
    FlexRIO 2023 Q3
    Utility
    Required Packages:
    ni-hwcfg-utility
    Hardware Configuration Utility 2023 Q3
    PXI Platform
    Services
    Required Packages:
    ni-pxiplatformservices
    Optional Packages:
    ni-pxiplatformservices-labview-20xy-support
    ni-pxiplatformservices-labview-support
    ni-pxiplatformservices-devel
    PXI Platform Services 2023 Q3
    NI-RIO4
    Required Packages:
    ni-fpga-interface
    Optional Packages:
    ni-rio-mxie
    NI-RIO 2023 Q3
    NI R Series
    Required Packages:
    ni-rseries
    NI R Series 2023 Q3
    NI-RFSA
    Required Packages:
    ni-rfsa
    Optional Packages:
    ni-rfsa-daqmx
    ni-rfsa-labview-20xy-support
    ni-rfsa-devel
    NI-RFSA 2023 Q3
    NI-RFSG
    Required Packages:
    ni-rfsg
    Optional Packages:
    ni-rfsg-daqmx
    ni-rfsg-labview-20xy-support
    ni-rfsg-devel
    NI-RFSG 2023 Q3
    NI-SCOPE
    Required Packages:
    ni-scope
    Optional Packages:
    ni-scope-daqmx
    ni-scope-labview-20xy-support
    ni-scope-labview-support
    ni-scope-devel
    NI-SCOPE 2023 Q3
    NI-Serial
    Required Packages:
    ni-serial
    NI-Serial 2023 Q2
    NI-SWITCH
    Required Packages:
    ni-switch
    Optional Packages:
    ni-switch-daqmx
    ni-switch-daqmx-config
    ni-switch-labview-support
    ni-switch-labview-20xy-examples
    ni-switch-devel
    NI-SWITCH 2023 Q3
    NI-Sync
    Required Packages:
    ni-sync
    Optional Packages:
    ni-sync-devel
    ni-sync-labview-20xy-support
    ni-sync-labview-support
    NI-Sync 2023 Q1
    System
    Configuration
    Required Packages:
    ni-syscfg-runtime
    Optional Packages:
    ni-syscfg-labview-20xy-support
    ni-syscfg-labview-support
    ni-iotrace
    ni-syscfg-devel
    System Configuration 2023 Q3
    NI-VISA
    Required Packages:
    ni-visa
    Optional Packages:
    ni-visa-labview-20xy-support
    ni-visa-labview-support
    ni-visa-devel
    NI-VISA 2023 Q3
    NI-XNET
    Required Packages:
    ni-xnet
    Optional Packages:
    ni-xnet-labview-20xy-support
    libnixnet-devel
    NI-XNET 2023 Q2
    1 Red Hat Enterprise Linux
    2 openSUSE Leap
    3 Ubuntu LTS
    4 Enables connections via the FPGA Interface API to remote RIO devices such as CompactRIO, Single-Board RIO, and Ethernet RIO
    Optional package types:
    There are several categories of optional packages including:
    LabVIEW support packages: These packages install the driver APIs to LV. These have the driver and 'labview' in the package name. They come in two types: version-specific LV support packages (the older style) which list a year and version-agnostic LV support packages (the newer style). Only use the version-specific LV support package when there's one that matches the version of LV that you need to use. Otherwise use the version-agnostic one.
    Development packages: These packages install header files that are needed to compile code with the driver, but that aren't required to execute code that was compiled somewhere else. Typically this is needed on the development machine, but not always on a deployed system. These package names end with "-devel".
    driver-DAQmx support packages: NI-DCPower, NI-DMM, NI-FGEN, NI-RFSA, NI-RFSG, NI-SCOPE, and NI-SWITCH each have a few HW devices that have separate drivers built on top of DAQmx. These packages function as the top-level driver package for those particular HW models.
    For additional information about supported operating systems, refer to the NI Operating System Support Roadmap.
    For an introduction to using Linux with NI products see About the NI Platform on Linux
    GMT+8, 2025-12-5 14:01
