查看: 723|回复: 0
[NI软件产品] NI RFmx for Bluetooth Test 2025 Q2 Win11 64bitEng RFmx蓝牙测试NIRFmxBluetooth25.3.0
     楼主| 发表于 2025-5-17 10:31:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    发布日期:2025/4/9
    包含的版本:2025 Q2完整版/运行版,版本号25.3.0
    Windows Server 2025
    语言:英文English
    64位完整版校验和:
    文件大小: 2436190208 字节 (2.27 GB)
    修改日期: 2025-04-11 17:08
    MD5: a3ed7717e77f2d90b2f85435a7c825d5
    SHA1: eb0305e66be2f158db6314fc080296341be9153d
    SHA256: 0fe98c1ae796ae3e7829bcaf5fca122c5e31872077aedcbbc75006084615ac8a
    CRC32: 5a5a7dee
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx for Bluetooth Test2025Q2Full.txt (564 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1087217664 字节 (1.01 GB)
    修改日期: 2025-04-11 17:06
    MD5: cdc3671cc7b02709e6fa63eace87a91e
    SHA1: 07c62c77de11a5f8715d4edd2b21550a74cbbf78
    SHA256: d80094f3a55d6c9d8e5160dc5873b33dfb053bb7ec60dc83fc28985eed76f5db
    CRC32: ca0c5e85
    RFmx for Bluetooth Test2025Q2RTE.txt (587 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q2版未更新自述文件,参考2023Q3版
    RFmx for Bluetooth® Test 2023 Q3 Readme
    This file contains important information about the RFmx for Bluetooth® Test, including system requirements, and installation instructions.
    • RFmx for Bluetooth® Test Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx for Bluetooth® Test Manuals: New features, behavior changes, and other documentation
    RFmx for Bluetooth® Test 2023 Q2 includes the following new features:
    • Support for Basic Rate, Enhanced Data Rate, and Low Energy versions of Bluetooth physical layer conforming to the Bluetooth Core Specification v5.4, and the Bluetooth RF PHY test specifications RF.TS.p30e2 and RF-PHY.TS.p15.
    • Support for Low Energy Direction Finding physical layer conforming to Bluetooth Core Specification v5.4
    RFmx for Bluetooth® Test 2023 Q1 includes the following new feature:
    RFmx for Bluetooth® Test 2022 Q4 includes the following new feature:
    • Support for DF2 and CFO measurements for Bluetooth LE 500kbps (S=2) packets
    • Support for PXIe-5842
    RFmx for Bluetooth® Test has the following requirements:
    RFmx for Bluetooth® Test 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx for Bluetooth® Test no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx for Bluetooth® Test 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx for Bluetooth® Test 2023 Q3 to an unsupported OS. Additionally, after installing RFmx for Bluetooth® Test 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx for Bluetooth® Test supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx for Bluetooth® Test. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx for Bluetooth® Test (64-bit only)
    If you are using the RFmx for Bluetooth® Test .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx for Bluetooth® Test .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx for Bluetooth® Test installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx for Bluetooth® Test. For more information on RFmx for Bluetooth® Test activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx for Bluetooth® Test palette VIs are available from the Functions » Measurement I/O » RFmx » BT palette.
    Documentation for RFmx for Bluetooth® Test is located at Start » National Instruments » RFmx for Bluetooth® Test Documentation.
    You can access all the installed RFmx for Bluetooth® Test examples at Start » National Instruments » RFmx for Bluetooth® Test Examples.
    The following is the behavior change in RFmx Bluetooth® Test 2023 Q3 from RFmx Bluetooth® Test 2023 Q2
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q4 from RFmx for Bluetooth® Test 2022 Q3:
    • RFmx for Bluetooth® Test drops support for 32-bit user mode.
    The following is the behavior change in RFmx for Bluetooth® Test 2022 Q3 from RFmx for Bluetooth® Test 21.8.2:
    The following are the behavior changes in RFmx for Bluetooth® Test 21.3 from RFmx for Bluetooth® Test 20.7.
    • Obsoleted ConfigureFrequencyChannelNumber(string, int, int) method in .NET. Use ConfigureFrequencyChannelNumber(string, RFmxBTMXStandard, int) method instead.
    GMT+8, 2025-12-8 07:36
