查看: 697|回复: 0
[NI软件产品] NI RFmx WLAN 2025 Q2 Win11 64bitENG RFmx无线局域网络25.3.0
     楼主| 发表于 2025-5-20 08:28:41 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    RFmx WLAN无线局域网络
    发布日期:2025/4/9
    包含的版本:2025 Q2完整版,版本号25.3.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2496548864 字节 (2.33 GB)
    修改日期: 2025-04-11 19:09
    MD5: d65a72a68c7f04fe7a467b1a52edcb52
    SHA1: a009630b104606e16c8c5c795272aebf60926dc5
    SHA256: d0b8202d4b4fb127bcd5f898599e1817842c5fb3d68b5b5d4186c42089e040b2
    CRC32: 91d87614
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    WLAN2025Q2Full.txt (533 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1071626240 字节 (1021.98 MB)
    修改日期: 2025-04-11 19:06
    MD5: 593dd4cdbe62292a003d3fbb9b4f06d1
    SHA1: 7255ce17df873fc6cc9e85705fe1cef7d29454c2
    SHA256: 750fae492d34a1711722fb3dec837ace53f0d720ba70901755455bab142686b5
    CRC32: 556edbec
    WLAN2025Q2RTE.txt (559 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q2未更新自述文件,参考2023Q3版
    RFmx WLAN 2023 Q3 Readme
    RFmx WLAN 2023 Q3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D3.2
    • Support for auto detection of signal in Analysis-Only Mode
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following is the behavior change in RFmx WLAN 2023 Q3 from RFmx WLAN 2023 Q2
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-12-8 07:36
