NI VeriStand 2025 Q2 and Drivers Win11 64bitEng VerStand PC版完整版及运行版2025Q2 NIVS25.3.0含驱动版7.0GB
NI VeriStand 和驱动程序2025 Q2
发布日期:2025/4/9
包含的版本:2025 Q2 PC版、完整版、运行版,版本号25.3.0
Windows Server 2025
语言:英文English
文件大小: 7520909312 字节 (7.00 GB)
修改日期: 2025-04-12 11:58
MD5: d4705d132419b5a3011dafb079b9a799
SHA1: 73572df0a118a1905490f7f764254a7968860a1f
SHA256: 1e9d81d514f7d29285767ddace24bb93662cce2dbb0aea59354282f46b09580e
CRC32: 86e9935c
请注册登录机器视觉论坛账号,购买附件查看下载地址
VeriStand and Drivers2025Q2.txt
(583 Bytes, 下载次数: 0, 售价: 20 圆)
2025Q2版未更新自述文件,参考2023Q3版
VeriStand 2025 Q2 New Features
Running VeriStand on Windows Machine with FIPS
VeriStand can now run on a Windows machine with federal information processing standards (FIPS). IP to FPGA Conversion Utility Supporting LabVIEW 2025 64-Bit
IP to FPGA Conversion Utility 2025 Q2 now supports LabVIEW 2025 Q1 64-bit. Configurable Time Axis for VeriStand Chart
VeriStand chart now allows you to configure any monotonically increasing channel as a time axis. VeriStand Model Generation Support for Block Parameters
Use VeriStand Model Generation Support to access block parameters from Simulink models as model parameters in VeriStand. For more information, refer to How VeriStand Imports Models from the Model Generation Support MATLAB Add-on and the VeriStand Model Generation Support documentation. Error Message Enhancement
Existing error messages now include more information to help you locate the source of the error.
Related concepts:
Related information:
VeriStand 2025 Q1 New Features
VeriStand Steps for TestStand
VeriStand Steps for TestStand are sets of custom steps that allow you to automate VeriStand and develop/reuse test sequences for hardware-in-the-loop (HIL) systems. This product is available for download using NI Package Manager, or at ni.com/downloads. Follow the prompts in NI Package Manager to install VeriStand Steps for TestStand. Please refer to the VeriStand Steps for TestStand for more information on how to use this application. LabVIEW 2025 Q1 Support
VeriStand is compatible with LabVIEW 2025 Q1 64-bit. All custom devices, LabVIEW models, and LabVIEW applications that contain the VeriStand API require this LabVIEW version. The VeriStand API will not install in previous versions of LabVIEW. Enhanced VeriStand Model Generation Support for VeriStand IO Blocks
VeriStand Inport/Outport blocks now supports the enum data type, and can be connected to masked blocks and additional blocks like bus selector. GCC Compiler Upgrade for VeriStand Model Generation Support
NI GCC Cross-Compiler for NI Linux Real-Time targets toolchain is upgraded to GNU C & C++ Compile Tools x64 2024Q4.
VeriStand 2024 Q3 New Features
FMI Support for Enum Data Type
Import FMUs with Inports/Outports/Parameters/Signals of type Enum as VeriStand channels. Enhanced Debug Logging for Simulation Models in Target Log Viewer
Use the Target Log Viewer to understand debug information from FMUs, .vsmodels, and .lvmodels. Simulink Model Enum Channels on VeriStand Screens
Scalar enum variables from .vsmodel and .fmu (3.0) are visible on VeriStand screens with their type definitions. IP to FPGA Conversion Utility Supporting LV 2024 64-bit
IP to FPGA Conversion Utility 2024 Q3 now supports LabVIEW 2024 Q1 64-bit. Support for Custom Reference Designs in HDL Coder Support Package for NI FPGA Hardware
The HDL Coder Support Package for NI FPGA hardware now includes support for custom reference designs, enabling the integration of Simulink models into existing LabVIEW FPGA projects.
VeriStand 2024 Q2 New Features
VeriStand Model Generation Support for Enum DataType
Use VeriStand Model Generation Support to import Inport/Outport/Signals/Parameter of type Enum from Simulink models as channels. VeriStand Model Generation Support for VeriStand IO Blocks
Place VeriStand Inport/Outport blocks from VeriStand Model Generation Support anywhere in the subsystem hierarchy in your Simulink model to access them as model Inport/Outport channels. APIs to Configure ECU Network Cluster
Configure Virtual ECU Clusters programmatically using APIs in the System Definition namespace. Synopsys Silver FMI 3.0 Virtual ECU Support
Configure and execute Virtual ECUs from Synopsys Silver that follow the FMI 3.0 standard.
Related concepts:
VeriStand 2024 Q1 New Features
LabVIEW 2024 Q1 Support
VeriStand is compatible with LabVIEW 2024 Q1 64-bit. All custom devices, LabVIEW models, and LabVIEW applications that contain the VeriStand API require this LabVIEW version. The VeriStand API will not install in previous versions of LabVIEW. VeriStand Virtual ECU Toolkit
Use the VeriStand Virtual ECU Toolkit to integrate and execute virtual electronic control units (ECUs) for hardware-in-the loop (HIL) testing. Virtual ECUs allow you to test devices quickly, with a more realistic rest bus simulation, and with less effort for creating the bus simulation. FMI 3.0 Support
VeriStand can configure and execute FMUs that follow the 3.0 standard. For more information on the support, refer to FMI Support.
Related tasks:
VeriStand 2023 Q4 New Features
Alarm Monitor Displays Trip Message and Value
VeriStand Editor's Alarm Monitor now actively showcases Trip Messages across all three tabs (Active, History, Rules). Furthermore, it actively presents Values within the Active and History tabs. Additionally, the Alarm Log actively records both the Trip Message and Value for comprehensive tracking. Revamped Launcher Interface
The VeriStand Launcher has undergone a significant transformation, introducing separate tabs for Projects and Learning. To access a collection of preloaded VeriStand projects and educational resources, navigate to the Learning tab. Meanwhile, the Projects tab offers access to Default Projects and enables users to incorporate their custom template projects seamlessly. VeriStand Model Generation Support for Simulation States
With VeriStand Model Generation Support, you can now preserve the state of a .vsmodel file during execution, allowing for later restoration of the model using the saved state through an XML file. To save and restore states, use the .NET IModel method or the Screen/Workspace.
VeriStand 2023 Q3 ReadmeJuly 2023 This file contains installation instructions and compatibility information for VeriStand 2023 Q3. You can find more release information on ni.com. - VeriStand Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- VeriStand Documentation: Detailed documentation about how to use your product
System Requirements Supported Operating Systems Installation Instructions Product Security and Critical Updates Upgrade and Compatibility Issues Accessing the Documentation Finding Examples Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Using NI Software with Microsoft Windows 10 Unsupported Windows Operating Systems System RequirementsVeriStand 2023 Q3 installs with the following: - NI-DAQmx 2023 Q3
- NI-VISA 2023 Q3
- NI-SLSC 2022 Q4
- NI-XNET 2023 Q2
- NI R Series Multifunction RIO 2023 Q3
Refer to the following sections for system requirements that apply if you use models, LabVIEW functionality, and .NET APIs. Simulation ModelsTo configure and run a simulation using your existing compiled model, you need only VeriStand installed. You need the following additional software to perform other tasks with models: - To develop a model using MathWorks Simulink® software, you must be a licensed user and have MathWorks MATLAB® software (64-bit version) and MathWorks Simulink software installed on the host computer.
- To compile a model developed using MathWorks Simulink software for use on a Microsoft Windows or LabVIEW real-time target, you must be a licensed user of and have the following software installed on the host computer: MathWorks Real-Time Workshop® (Simulink Coder®). Refer to the NI website for a list of compilers that are tested and supported.
Note You do not need the full VeriStand environment to generate a compatible model. Instead, you can install VeriStand Model Generation Support Toolbox for Simulink or the VeriStand Model Framework. If you use other modeling environments, contact your model vendor for specific requirements. LabVIEWTo create custom devices, menu items, workspace controls and indicators, or timing and sync devices, you must have LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand always requires like-numbered versions. .NETThe VeriStand .NET APIs require the following Microsoft software: - Microsoft .NET Framework 4.6.2, which uses Microsoft .NET Common Language Runtime (CLR) 4.6.2.
- A .NET environment capable of interacting with .NET Framework 4.6.2-based assemblies, such as Microsoft Visual Studio 2015 or later.
Supported Operating SystemsVeriStand 2023 Q3 supports the following operating systems: Windows Systems | Real-Time Targets | - Windows 11 64-bit version 22H2
- Windows 10 64-bit version 22H21
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
| - NI Linux Real-Time (Intel x64-based)2
| 1 NI software installs VC2015 Runtime and .NET 4.6.2. 2 VeriStand no longer supports Phar Lap ETS or NI Linux Real-Time (ARM-based) targets. | Recommended PXI Linux RT System ImageWhen formatting a disk with a PXI Linux RT system image for VeriStand 2023 Q3, select Linux RT System Image 2023 Q3 and enable support for the LabVIEW 2023 programming environment. Doing so prevents driver version conflicts while deploying XNET to a real-time target. Installation InstructionsInstall VeriStand with either the online installer or with installation media. - Log on as an administrator or as a user with administrator privileges.
- Disable automatic virus detection programs.
Note Some virus detection programs interfere with the installer. - Activate VeriStand when prompted by the installer or activate later with NI License Manager.
- To use LabVIEW with VeriStand, install the like-numbered version of LabVIEW on the host computer.
- Check your computer for viruses and enable your virus detection.
Online InstallerDownload the VeriStand installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager. Installation MediaIf you purchased this product with media, insert the VeriStand installation media and follow the instructions that appear on the screen. Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. Upgrade and Compatibility IssuesThe following sections describe issues to be aware of when you upgrade to VeriStand 2023 Q3. Note NI recommends that you review the Upgrade and Compatibility Issues in the readme files for each VeriStand version between the version from which you are upgrading and VeriStand 2023 Q3. To access the documents, refer to the VeriStand Release Notes. Primary Control Loop (PCL) Timing SourceAs of VeriStand 2023 Q2, the System Explorer default for the PCL DAQ timing source is Signal From Task (Sample Complete). This default applies to new projects under the following conditions: - Setting the timing source to DAQ Timing.
- Setting the timing source to Automatic Timing when a NI-DAQ device has at least one analog input hardware-timed single point channel.
Note This behavior will not change for existing, upgraded projects. Uncompiled ModelsVeriStand does not support communication with uncompiled models. Models Created from LabVIEW VIsModels compiled from LabVIEW VIs (.lvmodel or .lvmodelso files) using earlier versions of LabVIEW must be recompiled using LabVIEW 2023 64-bit. The LabVIEW functionality in VeriStand requires like-numbered versions. Note Models built with LabVIEW 2023 Q1 and later no longer support simulation subsystems developed using the LabVIEW Control Design and Simulation Module add-on. Models Compiled for Previous VersionsTake the following actions to ensure your models are 64-bit compatible: - Recompile all Windows models for 64-bit.
- Recompile all PharLap models for Linux RT.
Beginning with VeriStand 2021, the VeriStand Model Framework contains changes to the files used to develop and compile models in C/C++ and third-party modeling environments. If your system contains models compiled for Linux RT 64-bit with previous versions of the Model Framework, choose from the following options to continue to use the models: - If you do not need to modify your model, continue to use the model as-is.
- If you need to modify model functionality, and do not require the latest Model Framework version updates, recompile the model against the deprecated Model Framework files. These files are installed at \VeriStand\version\ModelInterface\custom\src\obsolete.
Migrating Files from VeriStand 2010 through 2018 SP1VeriStand 2023 Q3 can open projects from VeriStand 2010 through 2018 SP1 using the Open Legacy Project option in the Welcome tab. LabVIEW can no longer automate actions with legacy stimulus profiles. Consider migrating to modern stimulus profiles and real-time sequences. In addition, the following LabVIEW automation VIs are deprecated and no longer included with VeriStand: - NI VeriStand - Get Alarm Status.vi
- NI VeriStand - Get Engine State.vi
- NI VeriStand - Lock Workspace File.vi
- NI VeriStand - Run Workspace File.vi
- NI VeriStand - Stop Workspace File.vi
- NI VeriStand - Unlock Workspace File.vi
VeriStand Custom Devices Included with VeriStand SuiteBeginning with VeriStand 2021, the VeriStand suite installer will include custom devices for both offline and online installation. To install custom devices separately, refer to the release page for each Custom Device on the VeriStand Add-ons support page. Accessing the DocumentationVeriStand includes the following documentation resources: Resource | Contents | Access Instructions | | VeriStand Help | Conceptual, how-to, and reference information for using VeriStand. | In software: Help»Show VeriStand Help
OR
Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q3 Help | | VeriStand .NET API Help | Reference information for the .NET APIs included with VeriStand. You can access these assemblies from any .NET-compatible programming language or environment, including LabVIEW and NI TestStand. | Windows Start menu: All Programs»National Instruments»VeriStand 2023 Q3 .NET API Help. |
Note If you install VeriStand with a compatible version of LabVIEW, you can access a subset of VeriStand related materials in the LabVIEW Help. This includes information about VeriStand VIs and extending VeriStand functionality. To access this help from LabVIEW, select Help»LabVIEW Help. Finding ExamplesVeriStand includes the following types of examples: - VeriStand Project — An example VeriStand project, including related items such as a system definition, a Workspace screen file, compiled models, and NI-XNET files, are located in the \National Instruments\VeriStand 2023\Projects\Example directory.
- Stimulus Profile Editor — VeriStand Stimulus Profile Editor examples are located in the \National Instruments\VeriStand 2023\Examples directory.
- ASAM XIL and Custom Device Sample Configurations — Configuration examples for ASAM XIL and custom devices are located in the \National Instruments\VeriStand 2023\Examples directory.
Note On the Windows OS, the default location of the directory is C:\Users\Public\Public Documents.- LabVIEW API — LabVIEW examples that use the VeriStand API are located in the \National Instruments\LabVIEW 2023\examples\NI VeriStand directory or in the \National Instruments\LabVIEW 2023\examples\NI VeriStand Custom Devices directory.
Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager documentation. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Using NI Software with Microsoft Windows 10For more information about NI support for Windows 10, refer to NI Product Compatibility for Microsoft Windows 10. Unsupported Windows Operating SystemsVeriStand no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport. |
