查看: 506|回复: 0
[NI软件产品] PCB Assembly Test Toolkit 2025 Q2 Win11 32/64bitEn PCB装配测试工具包PCBATT25.3.0
     楼主| 发表于 2025-7-24 16:23:01 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    PCB Assembly Test工具包
    PCB Assembly Test工具包可帮助用户节省开发时间,并为进行PCB装配电气功能测试的生成、测量、通信和自动化提供便利。
    PCB Assembly Test工具包是一组免许可证的LabVIEW虚拟仪器(VI),作为测量库、范例和自动化就绪的NI TestStand Sequence模板提供,用于执行PCB装配电气功能测试。该工具包包含对集成NI-DMM和NI-SWITCH驱动程序的NI PXI DMM和开关的支持,以及对具有即用型配置的NI-DAQmx数据采集设备的支持。该工具包提供了基于Initialize、Configure & Measure和Close的API函数,具有最小的参数,比原生NI驱动程序更易于编程。
    发布日期:2025/4/25
    包含的版本:完整版,版本号25.3.0
    语言:英文
    程序位数:32/64位
    文件大小: 242872320 字节 (231.62 MB)
    修改日期: 2025-05-13 09:30
    MD5: e34cf4cd40c1770620d1cbfd51db1ea4
    SHA1: dec825729a9c1d4812754baa0608df9163275e39
    SHA256: bac96eced6d054f475292ef0017b073e1b8a50f51601de62561bdc0716e296cc
    CRC32: 0fc6abb6
    注册登录视觉论坛会员,购买附件查看下载地址
    PCB ATT2025Q2.txt (617 Bytes, 下载次数: 0, 售价: 10 圆)
    PCB Assembly Test Toolkit 2025 Q2 for LabVIEW Changes
    Learn about new features, behavior changes, and other updates in PCB Assembly Test Toolkit 2025 Q2 for LabVIEW.
    This version of the PCB Assembly Test Toolkit for LabVIEW provides support for the following features:
    • Updated DAQ functions to support PCIe, PXIe, and USB devices, emphasizing support for NI 63xx (X Series) devices. Updated icons colors and library names (existing libraries now have a DAQ_ prefix) to distinguish new hardware and mixed signal support.
    • Added new individual simple DMM functions to measure AC/DC voltage and current, frequency and period, and 2-wire or 4-wire resistance. A new DMM mixed measurement library integrates all measurements while using the same Initialize, Configure and Measure, and Close function pattern used in other PCB Assembly Test Toolkit libraries.
    • Added new simple switch function to support NI multiplexers and all topologies using a path method to connect and disconnect internal relays (for example, ch1, com0).
    • Added new simple functions to support DMM Scan using three different hardware methods. Supported hardware methods correspond to the following NI bundles: PXI DMM Switches, PXI DMM with Switch Relay Driver and External Relays, and PXI DAQ DO with Custom External Relays).
    • Added a new list of examples for DAQ, DMM, DMM Scan methods in LabVIEW.
    • Updated TestStand automation sequences using PC-based devices, such as NI 63xx (X Series) devices.
    PCB Assembly Test Toolkit for LabVIEW Overview
    The PCB Assembly Test Toolkit for LabVIEW includes a measurement library, automation examples, a test demo example, and documentation for electrical functional testing of PCB assemblies.
    The PCB Assembly Test Toolkit for LabVIEW provides library examples and automation-ready TestStand sequence templates that you can use for production testing of printed-circuit board assembly (PCBA) with data acquisition systems, DMM and switch instruments, CompactDAQ hardware, TestScale devices, or any device supported by NI-DAQmx. The add-on includes example measurements for DC/RMS voltage, idle power, frequency, digital counting, DMM scanning with different hardware configurations, and more. Additionally, the PCB Assembly Test Toolkit provides example tests for interface buttons and LED, power diagnostics, and more.
    Components of a PCB Assembly Test Toolkit for LabVIEW System
    The PCB Assembly Test Toolkit for LabVIEW supports all devices supported by the following driver application software: NI-845x, NI-DAQmx, NI-DMM, NI-Serial, and NI-SWITCH. The PCB Assembly Test Toolkit for LabVIEW provides specific support for the following NI hardware:
    • PXIe, PCIe, and USB DAQ devices
    • PXIe and USB DMM instruments
    • PXI and PXIe switches
    • CompactDAQ (cDAQ) chassis and modules, emphasizing support for temperature measurement
    • TestScale chassis and modules
    • NI USB-8452 (I2C/SPI) modules
    • NI USB-232 or PXI-843x serial modules
    Software Components
    PCB Assembly Test Toolkit for LabVIEW requires minimum versions of LabVIEW, TestStand, and NI driver application software.
    Dependency
    Required Version
    2021 SP1 or later (32-bit, 64 bit)
    TestStand
    2021 SP1 or later (32 bit, 64-bit)
    NI-DAQmx
    2022 Q4 or later
    NI-DMM
    2022 Q3 or later
    NI-SWITCH
    2022 Q4 or later
    NI-Serial
    21.3 or later
    NI-VISA
    21.5 or later
    NI-845x
    21.3 or later
    LabVIEW Project, Libraries, and Examples
    PCB Assembly Test Toolkit for LabVIEW provides measurement and generation libraries to enable common actions performed in PCB assembly electrical functional test.
    Use these libraries to create or extend your LabVIEW sequencer application. The toolkit also provides LabVIEW examples to help you understand the toolkit libraries and accelerate your own application development.
    Related reference:
    • Launching the Toolkit in LabVIEW
    TestStand Functional Demo and Automated Test Sequences
    PCB Assembly Test Toolkit for LabVIEW includes test sequences to demonstrate how to accomplish common tasks such as extracting test data or determining pass/fail test results.
    Launch C:\Users\Public\Documents\National Instruments\PCB Assembly Test Toolkit for LabVIEW\TestStand\PCBA TestStand WorkSpace.tsw to open a TestStand workspace that includes all PCB Assembly Test Toolkit for LabVIEW functional test sequences and measurement libraries.
    The Functional Demo TestStand sequence can be found at the following location: C:\Users\Public\Documents\National Instruments\PCB Assembly Test Toolkit for LabVIEW\TestStand\PCBA FT Demo\PCBA FT Demo.seq
    Automated test sequences are located in the following directory: C:\Users\Public\Documents\National Instruments\PCB Assembly Test Toolkit for LabVIEW\TestStand\Automation
    Related tasks:
    • Launching the Toolkit in TestStand
    • Running the PCBA FT Demo Test Sequence
    Related reference:
    • Automation Test Sequences
    Installing the PCB Assembly Test Toolkit for LabVIEW
    Follow these steps to install the PCB Assembly Test Toolkit for LabVIEW with NI Package Manager.
    NoteInstall any related software, including LabVIEW, TestStand, and driver application software, before you install the PCB Assembly Test Toolkit for LabVIEW. Refer to the Software Components topic for a list of required and supported software.
    • Launch NI Package Manager and search for PCB Assembly Test Toolkit for LabVIEW.
    • Click the search result for PCB Assembly Test Toolkit for LabVIEW. The product page appears with the latest available version is automatically selected.
    • Click Install.
    • Review the prompts and complete the installation process.
      • Do not deselect all recommended packages without review. You must install packages related to PCB assembly testing, including the following packages, if they are recommended:
        • NI Certificates Installer
        • PCB Assembly Test Toolkit LabVIEW Support
        • PCB Assembly Test Toolkit LabVIEW 2021 32-bit Support
        • PCB Assembly Test Toolkit LabVIEW 2021 64-bit Support
        You may accept or reject other recommended software packages based on your needs.
      • The installer reminds you of the LabVIEW, TestStand, and driver application software requirements. If LabVIEW, TestStand, or required drivers are not installed, cancel the PCB Assembly Test Toolkit installation and install the required software.
      • You must accept the required license agreements to continue with software installation.
    • Restart the computer when installation is complete.
    GMT+8, 2025-12-8 07:36
