查看: 485|回复: 0
[NI软件产品] NI IP to FPGA Conversion Utility 2025 Q3 Win11 64bitEng IP至FPGA转换工具25.5.0
    前天 16:03
     楼主| 发表于 2025-8-18 09:42:47 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IP至FPGA转换工具可帮助您将自定义算法导出为FPGA比特文件,以便在包含板载FPGA的NI硬件上进行部署。
    IP至FPGA转换工具是一个软件实用程序,可用于将自定义算法和知识产(IP)核导出为FPGA比特文件。您可以使用导出的比特文件将Mathworks Simulink中创建的自定义算法或IP部署到硬件FPGA。该工具支持转换HDL兼容的Simulink模型。Simulink是The MathWorks, Inc.的注册商标。
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版,版本号25.5.0
    Windows Server 2025
    语言:英文English
    应用程序位数:64位(官网上写的程序位数是64位,但是在自述文件中则写着兼容32位的LabVIEW、LV FPGA模块、R系列多功能RIO,看安装包里的内容,大概率是64位的,自述文件中可能是错的,具体版本还请确认清楚。不过该程序也只有这一个版本,如果不兼容相应的位数,只能改其他的LV、FPGA环境。)
    文件大小: 745701376 字节 (711.16 MB)
    修改日期: 2025-07-24 09:30
    MD5: 8c6d96cf069fd0cded3c3c76cb2249ee
    SHA1: 25fa6e3a0d3b80082307787eb97f99e757990475
    SHA256: f77585b4ab556e79c582245392220dfb344e666ee41e5f50d5532df5733e37cd
    CRC32: 9f3e0274
    请注册登录机器视觉论坛,购买附件查看下载地址
    IP to FPGA2025Q3.txt (596 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q3版未更新自述文件,参考2023Q3版。
    IP to FPGA Conversion Utility 2023 Q3 Readme
    This file contains installation instructions and compatibility information for IP to FPGA Conversion Utility 2023 Q3.
    • IP to FPGA Conversion Utility Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    IP to FPGA Conversion Utility 2023 Q3 has the following requirements:
    For 32-bit:
    Version
    LabVIEW Full or Professional Development Systems2020, 2021
    LabVIEW FPGA Module2020, 2021
    NI R Series Multifunction RIO with LabVIEW 2020/2021 Support2023 Q2
    NI FlexRIO with Integrated IO with LabVIEW 2021 Support (required only for PXIe-7890/91)2023 Q2
    For 64-bit:
    Version
    LabVIEW Full or Professional Development Systems2023
    LabVIEW FPGA Module2023
    NI R Series Multifunction RIO with LabVIEW 2023 Support2023 Q2
    NI FlexRIO with Integrated IO with LabVIEW 2023 Support (required only for PXIe-7890/91)2023 Q2
    Refer to the LabVIEW Readme, LabVIEW FPGA Module Readme, NI R Series Multifunction RIO Readme, and NI FlexRIO Readme for additional system requirements and supported operating systems.
    IP to FPGA Conversion Utility 2023 Q3 supports the following operating systems:
    Note  IP to FPGA Conversion Utility no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    Download the IP to FPGA Conversion Utility installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Early access support for PXIe-7890/91
    The IP to FPGA Conversion Utility 2023 Q3 supports the following NI FPGA hardware:
    • PXIe-7820R
    • PXIe-7821R
    • PXIe-7822R
    • PXIe-7846R
    • PXIe-7847R
    • PXIe-7856R
    • PXIe-7857R
    • PXIe-7858R
    • PXIe-7861
    • PXIe-7862
    • PXIe-7865
    • PXIe-7866
    • PXIe-7867R
    • PXIe-7868R
    • PXIe-7890 (Early access)
    • PXIe-7891 (Early access)
    To access help for the the IP to FPGA Conversion Utility, open the command line and enter ip2fpgaCLI –help. For more information on using the utility, refer to the supplemental documentation.
    IP to FPGA Conversion Utility no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-2-25 02:40
