查看: 601|回复: 0
[LV工具模块] LabVIEW 2025 Q3 Datalogging and Supervisory Control Module Win11 32bitEng LabVIEW2025Q3数据记录与监控模块DSC25.3.0
    昨天 16:03
     楼主| 发表于 2025-8-19 10:54:25 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW数据记录和监控(DSC)模块适用于开发HMI/SCADA或高通道数数据记录应用程序。
    LabVIEW数据记录和监控(DSC)模块是LabVIEW编程环境的一个附加软件。您可以使用此模块以及数十到数万个标签,快速开发分布式监测和控制系统。该模块包含将数据记录到网络历史数据库、跟踪实时和历史趋势、管理警报和事件、将LabVIEW实时终端和OPC设备联网到一个完整系统,以及为用户界面添加安全性等任务所需的工具。
    LabVIEW 2025 Q3数据记录与监控模块25.3.0
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版/运行版,版本号25.3.0
    Windows Server 2025
    应用程序位数:32位(DSC到目前为止,仅有32位版本,64位LabVIEW下无此模块)
    Full完整版
    文件大小: 1781374976 字节 (1.66 GB)
    修改日期: 2025-07-24 15:19
    MD5: 352ffbb60b1fcc1605ce17e8620e3ac9
    SHA1: 5ac0bebfba688a5359cba29fbc28cea0bad6b10a
    SHA256: 14b6109cc559a47e1779bec35c82d1c5b2ca6ff9d63f99bd4c0ed04c6ebdf220
    CRC32: 6369d582
    请注册登录视觉论坛会员,购买附件查看下载地址
    DSC2025Q3.txt (663 Bytes, 下载次数: 0, 售价: 10 圆)
    RunTime运行版
    文件大小: 1497298944 字节 (1.39 GB)
    修改日期: 2025-03-13 14:56
    MD5: c4c62d5f060e239f3396ae3bb4f3dd85
    SHA1: a90fed497ab6f56df94ec6943db1e7baf677a0a8
    SHA256: ada9cd1dbf353f5f283dea3a875a53c3b12da0d4f160d2adf6f4edf1c6a389f2
    CRC32: fdc0cf3b
    DSC2025Q3RTE.txt (707 Bytes, 下载次数: 0, 售价: 5 圆)
    DSC2025Q3未更新自述文件,参考2021版本
    LabVIEW 2021 Datalogging and Supervisory Control Module Readme
    July 2021
    This file contains installation instructions and compatibility information for LabVIEW Datalogging and Supervisory Control (DSC) Module.
    • Manuals: New features, behavior changes, and other documentation
    The LabVIEW DSC Module extends the LabVIEW graphical development environment with additional functionality for the rapid development of distributed measurement, control, and high-channel-count monitoring applications. The DSC Module enhances the LabVIEW shared variable, supports logging data to the Citadel and relational databases, enhances the Historical Data Viewer and the NI Distributed System Manager, and provides tools for graphing historical or real-time trends, enhancing the security of front panels, and writing custom I/O servers.
    In addition to the system requirements for the LabVIEW Development System, the DSC Module has the following requirements:
    • LabVIEW 2021 Base, Full, or Professional Development System
    • At least 2.5 GB of disk space
    • 512 MB of RAM. NI recommends 1 GB of RAM.
    • Internet Explorer 6 Service Pack 1 or later
    Note  The DSC Module is compatible with LabVIEW (32-bit) only. Therefore, you must have LabVIEW (32-bit) installed even if you use a 64-bit OS.
    The DSC Module supports the following operating systems:
    • Windows 10 (version 1909)
    NI installs the DSC Module using NI Package Manager. If you do not already have NI software installed, the DSC Module installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the DSC Module using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    SQL Server Support
    The LabVIEW 2021 DSC Module requires Microsoft SQL Server 2012 Service Pack 4 (SP4) Express. This component is installed by default when you install the DSC Module.
    To install the LabVIEW 2021 DSC Module on a machine that has a previous version of the DSC Module installed, you need to upgrade the Microsoft SQL Server version from 2008 R2 to 2012 SP4 Express. Because upgrading the Microsoft SQL Server affects the Citadel database, you must backup your Citadel data before upgrading. Refer to the Archiving Citadel Data topic in the LabVIEW Help for detailed information about archiving the Citadel database.
    Licensing
    The DSC Module relies on licensing activation. When the evaluation period expires, you must activate a valid DSC Module license to continue using the DSC Module.
    The NI OPC Servers application installed with the DSC Module provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help, for information about the DSC Module.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the DSC Module are located in the labview\examples\lvdsc directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    The Advanced Signal Processing Toolkit no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2000–2021 National Instruments Corporation. All rights reserved.
    375310H-01
    LabVIEW 2021 Datalogging and Supervisory Control Runtime Readme
    July 2021
    This file contains installation instructions and compatibility information for LabVIEW Datalogging and Supervisory Control (DSC) Runtime.
    The LabVIEW DSC Runtime allows you to run applications built with LabVIEW, the DSC Module, and the LabVIEW Application Builder on a computer without the DSC Module installed. The DSC Runtime contains components that enable the DSC Module features in the built applications.
    The DSC Runtime has the following requirements:
    • Depending on the components you choose to install, the computer must have the following amount of free disk space:
      • 1.0 GB free disk space if you install all components of the DSC Runtime except the Shared Variable Logging Support component
      • 2.5 GB free disk space if you install all components of the DSC Runtime
    • At least 512 MB of RAM
    The DSC Runtime supports the following operating systems:
    NI installs the DSC Runtime using NI Package Manager. If you do not already have NI software installed, the DSC Runtime installs NI Package Manager to handle the installation of your NI software. Visit ni.com/r/NIPMDownload to download NI Package Manager. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    You can also install LabVIEW and the DSC Runtime by using the LabVIEW Platform media. To request additional LabVIEW Platform media, refer to the NI website.
    Note  The NI OPC Servers application installed with the DSC Runtime provides a temporary license for a two-hour evaluation period. You must activate a valid license to continue using the NI OPC Servers application after the evaluation period expires.
    SQL Server Support
    To install the LabVIEW 2020 DSC Module on a machine that has a previous version of the DSC Module installed, you need to upgrade the Microsoft SQL Server version from 2008 R2 to 2012 SP4 Express. Because upgrading the Microsoft SQL Server affects the Citadel database, you must backup your Citadel data before upgrading. Refer to the Archiving Citadel Data topic in the LabVIEW Help for detailed information about archiving the Citadel database.
    375311H-01
    GMT+8, 2026-2-24 19:22
