查看: 510|回复: 0
[LV工具模块] Digital Audio Acquisition and Generation Toolkit(LabVIEW PDM Acquisition Toolkit) 2025 Q2 x64Win10 32/64bitEng 数字音频采集和生成工具包(LV脉冲密度调制采集工具包)25.2.0
  • 签到天数: 3810 天
     楼主| 发表于 2025-8-20 09:35:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Digital Audio Acquisition and Generation工具包
    数字音频采集和生成工具包可帮助您采集和生成I2S、PDM和TDM信号,以评估设备性能。
    数字音频采集和生成工具包,以前称为LabVIEW PDM Acquisition工具包,是LabVIEW的软件附加工具,可与PXIe-7820和PXIe-7821 PXI数字可重配置I/O模块以及USB-7845和USB-7846多功能一体机配合使用可重配置I/O模块。借助该附加工具,您可以采集I2S、脉冲密度调制(PDM)和时分复用(TDM)信号并将其转换为音频波形以进行测试。您还可以使用Digital Audio Acquisition and Generation Toolkit生成自己的信号,以评估数字音频设备的性能。此外,您还可以采集和生成各种速率和抽取因子的信号。
    LabVIEW PDM Acquisition Toolkit 2025 Q2
    发布日期:2025/6/2
    包含的版本:2025 Q2完整版专业版,版本号25.2.0
    语言:英文English
    文件大小: 1808228352 字节 (1.68 GB)
    修改日期: 2025-07-24 15:30
    MD5: 86ca381a1a7827fe147d0a1b0279e1be
    SHA1: 4cdacd38e1325e38dd4e2a435e853aa4281c3d0d
    SHA256: 032b82176233660afe2d7a34afe1085ae4ea2acc91a8f340a339b2d0f43b82f6
    CRC32: 05e5ebcf
    请注册登录视觉论坛账号,购买附件查看下载地址
    PDM Acquisition Toolkit2025Q2.txt (632 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q2未更新自述说明,参考2022Q4版
    LabVIEW PDM Acquisition Toolkit 2022 Q4 Readme
    February 2023
    This file contains installation instructions and compatibility information for LabVIEW PDM Acquisition Toolkit 2022 Q4.
    • LabVIEW PDM Acquisition Toolkit Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • LabVIEW PDM Acquisition Toolkit Help: Basic concepts, API reference, specifications, and other information
    Driver and Add-On Requirements
    LabVIEW PDM Acquisition Toolkit 2022 Q4 supports only the Windows 10 (64-bit) operating system.
    LabVIEW PDM Acquisition Toolkit 2022 Q4 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by LabVIEW PDM Acquisition Toolkit 2022 Q4
    LabVIEW2018 SP1 Patch, 2019, 2020, and 2021
    If you are using the LabVIEW PDM Acquisition Toolkit .NET Class Library, .NET Framework 4.6.2 (minimum) is required. The LabVIEW PDM Acquisition Toolkit 2022 Q4 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.6.2 or later.
    LabVIEW PDM Acquisition Toolkit 2022 Q4 requires the following driver and add-on version: NI R Series Multifunction RIO 20.0.0.
    Download the LabVIEW PDM Acquisition Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    LabVIEW PDM Acquisition Toolkit 2022 Q4 includes the following new features:
    • Added support for 64-bit LabVIEW 2018 SP1 Patch, 2019, 2020, and 2021.
    • Provided C# APIs and examples.
    The following list details the hardware models supported in LabVIEW PDM Acquisition Toolkit 2022 Q4.
    • PXIe-7820/7821
    • USB-7845/7846
    Refer to the LabVIEW PDM Acquisition Toolkit Help, accessible at LabVIEW XXXX\help\pdmacquisition.chm or ni.com/r/pdmhelp, for information about the LabVIEW PDM Acquisition Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the LabVIEW PDM Acquisition Toolkit are located in the LabVIEW XXXX\examples\PDM Acquisition Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    C# dynamic-link library (DLL) and examples for the LabVIEW PDM Acquisition Toolkit are located in the following directories:
    • DLL: C:\Program Files\National Instruments\PDM Acquisition Toolkit\NationalInstruments.PDMToolkit.Task.dll
    • Examples: C:\Users\Public\Documents\National Instruments\PDM Acquisition Toolkit\Examples\DotNET
    GMT+8, 2026-2-27 11:59
