查看: 410|回复: 0
[NI软件产品] NI RFmx WLAN 2025 Q3 Win11 64bitENG RFmx无线局域网络25.5.0
     楼主| 发表于 2025-8-28 11:54:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx WLAN无线局域网络
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版,版本号25.5.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2731251712 字节 (2.54 GB)
    修改日期: 2025-07-23 19:28
    MD5: 2d7a5458dcc0f48169f353b401a9e4d1
    SHA1: 5afbdf1a885645af366c1a471457df8dbb5662d3
    SHA256: 5e7a0036797dc21c27b4fc8a8e44863e8464fae856142b35de19c656c53ad77b
    CRC32: fafd6c46
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx WLAN2025Q3.txt (533 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1052450816 字节 (1003.70 MB)
    修改日期: 2025-07-23 19:27
    MD5: a34ad7838db470df1475fe579964c62b
    SHA1: bff53c0be5bef67393ac7d3dd57f95dd45680183
    SHA256: e9a40e8b4e06461d852cb73fb4f8f6666906b1b3d6765aa1c0679ad07e38e2c9
    CRC32: 62d01fff
    RFmx WLAN2025Q3RTE.txt (559 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q3未更新自述文件,参考2023Q3版
    RFmx WLAN 2023 Q3 Readme
    RFmx WLAN 2023 Q3 includes the following new features:
    • Support for 802.11be Standard IEEE P802.11be/D3.2
    • Support for auto detection of signal in Analysis-Only Mode
    RFmx WLAN 2023 Q2 includes the following new features:
    • Support for Combined Signal Demodulation across all MIMO standards
    • Support for 802.11be Standard IEEE P802.11be/D3.0
    RFmx WLAN 2023 Q1 includes the following new features:
    • Support for Fields Gated Power for 802.11be standard
    • Support for 802.11be Standard IEEE P802.11be/D2.3
    RFmx WLAN 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx WLAN no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx WLAN 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx WLAN 2023 Q3 to an unsupported OS. Additionally, after installing RFmx WLAN 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx WLAN supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx WLAN. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx WLAN (64-bit only)
    Item
    Installed Location
    RFmx WLAN palette VIs are available from the Functions » Measurement I/O » RFmx » WLAN palette.
    Documentation for RFmx WLAN is located at Start » National Instruments » RFmx WLAN Documentation.
    You can access all the installed RFmx WLAN examples at Start » National Instruments » RFmx WLAN Examples.
    The following is the behavior change in RFmx WLAN 2023 Q3 from RFmx WLAN 2023 Q2
    The following are the behavior changes in RFmx WLAN 2022 Q3 from RFmx WLAN 21.8.2:
    • EVM Noise compensation includes support to work for Linear, Wiener and Triangular Smoothing channel estimation interpolation types
    The following are the behavior changes in RFmx WLAN 21.8 from RFmx WLAN 21.5.
    • RFmx WLAN drops support for 32-bit user mode.
    • When you set the OFDMModAcc Noise Comp Enabled property to True:
      • Noise compensation applied limit check is now skipped if OFDMModAcc EVM Ref Data Symbols Mode property is set to Reference Waveform
      • EVM per Subcarrier and the EVM per Symbol traces now follow the noise compensation applied result
    GMT+8, 2025-12-8 07:35
