查看: 678|回复: 0
[NI驱动程序] NI System Configuration 2025 Q3 Win11 32/64位多国语言 NI系统配置nisyscfg25.5.0
    12 小时前
  • 签到天数: 3823 天
    连续签到: 16 天
     楼主| 发表于 2025-9-1 09:50:30 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    System Configuration系统配置
    发布日期:2025/7/18
    包含的版本:2025 Q3完整版,版本号25.5.0
    Windows Server 2025
    语言:中文/德语/日语/法语/英文/韩语
    校验和
    文件大小: 1523019776 字节 (1.42 GB)
    修改日期: 2025-07-23 18:57
    MD5: b72fc69be85ea5fc95785b86f13690d7
    SHA1: 19c994a4f50070b9437f58d2fde083bf9f757939
    SHA256: db9d88f16940a0beef2731d6c683f0fa4cda6e5c087cf2d75594b45295186dc3
    CRC32: a911d1d0
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    系统配置2025Q3.txt (608 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q3版未更新自述说明,参考2023Q2
    System Configuration 2023 Q2 Readme
    April 2023
    This file contains installation instructions and compatibility information for System Configuration.
    System Configuration includes the following products:
    • NI Measurement & Automation Explorer (MAX) is a configuration utility that provides access to your NI devices.
    • NI Hardware Configuration Utility is a utility that enables visualizing and configuring the hardware in your systems.
    • Web-Based Configuration and Monitoring is a utility that enables remote configuration and monitoring of your NI devices.
    • NI I/O Trace is an application that monitors, records, and displays NI API calls made by applications.
    • NI Device Monitor is a utility for launching applications when a system detects an NI device.
    System Configuration contains an API that can be used to programmatically control various NI devices in a system. Refer to the Application Software Support section of this document for more information on the API.
    System Configuration and components support the following operating systems:
    • Windows 11 (x64)
    • Windows 10 (x64)
    • NI Linux® Real-Time
    Note  System Configuration no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes.
    System Configuration supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by System Configuration
    LabVIEW2019, 2020, 2021, 2022 Q3 and later
    LabWindows™/CVI™2012 and later
    System Configuration supports the following Microsoft Visual Studio versions and associated programming languages.
    Programming Language
    Visual Studio Versions Support by System Configuration
    Location of Visual Studio Examples on Windows 10
    .NET Framework 4.0 Languages
    (Visual C#)
    2010C:\Users\Public\Documents\National Instruments\MStudioVS2010\DotNET\Examples
    .NET Framework 4.5 Languages
    (Visual C#)
    2012C:\Users\Public\Documents\National Instruments\MStudioVS2012\DotNET\Examples
    Download the System Configuration installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    The "System Configuration Support for LabVIEW" package supports applications using System Configuration ​with LabVIEW 2022 Q3 or later. When installing System Configuration, this package will be recommended if you have already installed LabVIEW 2022 Q3 or later and installs to the LVAddons directory.
    New Web-Based Configuration and Monitoring Features
    • Added Application Web Server configuration
    • Added Web Service publishing
    System Configuration no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    © 2010–2023 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-3-12 20:57
