查看: 611|回复: 0
[LV第三方库] JKI VI Package Manager Latest Linux32/64bitEng JKI VIPM最新版
  • 签到天数: 3810 天
     楼主| 发表于 2025-9-4 11:27:48 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    JKI
    JKI VI Package Manager可识别、创建和安装LabVIEW附加软件。
    JKI VI Package Manager是一款附加软件,用于查找并安装NI Tools Network上的LabVIEW附加软件。您可以使用JKI VI Package Manager为开发人员和客户构建可复用的代码库和工具,以及在LabVIEW中管理和维护软件包。
    VIPM之前的版本是独立版本。后面的版本,则在LabVIEW专业版中已经集成,在安装LabVIEW时可选择安装VIPM。
    JKI VI Package Manager Linux
    发布日期:2017/6/26
    包含的版本:最新版,latest
    受支持的操作系统:Linux
    语言:English英文
    文件大小: 86062735 字节 (82.08 MB)
    修改日期: 2025-07-24 15:12
    MD5: 3ae297afdfd8662aea38aca1fa3d953c
    SHA1: 479638d1076ceea4b9198ea21e46702165cd531a
    SHA256: c0f63acdb85f7064fc25c5dd2056dc8cd716cd70554d414be745e3808fd9777a
    CRC32: 65474c06
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    VI Package Manager (VIPM) is Copyright JKI
    Installing VIPM for Linux:
    Copy the folder /JKI and all the contents to /usr/local
    You may need root access to do this.
    VIPM for Linux depends on the LabVIEW 2013 run-time engine which is provided with this distribution. It's located in the /LabVIEW2013RTE_Linux folder. You must install all the RPM files located there. If you have trouble installing the run-time engine, please contact National Instruments (http://ni.com/support). Note: If you have the LabVIEW 2013 full development system already installed on your system, then you probably don't need to install the run-time engine since you already have it installed.
    Running VIPM for Linux:
    VIPM for Linux must be run with admin or root level privileges. There is no way around this. If you run VIPM as a standard user, it will not work as expected and will generate errors. To do this, navigate to the installation folder at /usr/local/JKI/VIPM and execute the following:
    $ sudo ./vipm
    You will be prompted for your root password. Enter the password and VIPM will launch.
    If you need help with VIPM, you can contact us at support@jki.net.
    JKI also provides custom LabVIEW programming services and training. Contact us at sales@jki.net and we'll do our best to help solve your tough technical challanges.
    VIPM is also available on Mac and Windows. See http://jki.net/vipm for more info.
    GMT+8, 2026-2-27 12:01
