查看: 446|回复: 0
[NI软件套件] Automated Test Software Suite 2025 Q3 Win11 32bitZh-cn 自动化测试软件套件2025Q3ATSS25.5.0-32位中文版
    13 小时前
  • 签到天数: 3731 天
     楼主| 发表于 2025-9-8 11:08:38 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Automated Test Software Suite自动化测试软件套件
    Automated Test Software Suite是一组用于特性分析、验证和测试电子器件的软件集合。
    Automated Test Software Suite结合了所有三种NI集成开发环境(IDE)以及专为帮助测试和验证工程师快速构建和部署自动化测试系统而设计的应用软件。
    发布日期:2025/7/18
    包含的版本:2025 Q3专业版,版本号25.5.0
    Windows Server 2025
    应用程序位数:32位
    语言:中文Chinese
    文件大小: 14308409344 字节 (13.33 GB)
    修改日期: 2025-07-22 10:59
    MD5: a96ddbe0fc35680c95e6d076feb20a20
    SHA1: e68986e7179872c78cedbf60e1347d480426db5d
    SHA256: dc3bc6a457bf545fbf4281f3220a416ec10d9f84dd2aeff3b5675da3c10ce108
    CRC32: b7502dd7
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    ATSS2025Q3x86Zh-cn.txt (652 Bytes, 下载次数: 0, 售价: 40 圆)
    编程环境
    ProductVersionBitness
    LabVIEW2025 Q332-bit and 64-bit
    Measurement Studio2019 F432-bit and 64-bit
    LabWindows/CVI2020 F332-bit and 64-bit
    应用软件
    TestStand2025 Q332-bit and 64-bit
    Requirements Gateway
    2018
    32-bit and 64-bit
    NI Switch Executive2023 Q432-bit and 64-bit
    附加软件
    JKI VI Package Manager2025 Q332-bit and 64-bit
    LabWindows/CVI Execution  Profiler1.1.132-bit and 64-bit
    LabWindows/CVI SQL工具包
    2.4
    32-bit and 64-bit
    驱动程序
    NI-Sync2025 Q332-bit and 64-bit
    NI-488.22025 Q332-bit and 64-bit
    PXI Platform Services2025 Q332-bit and 64-bit
    NI-VISA2025 Q332-bit and 64-bit
    NI-Serial2025 Q332-bit and 64-bit
    NI-DAQmx2025 Q332-bit and 64-bit
    IVI Compliance Package2025 Q232-bit and 64-bit
    FlexRIO with Modular I/O2025 Q332-bit and 64-bit
    FlexRIO with Integrated I/O2025 Q332-bit and 64-bit
    NI-DCPower2025 Q332-bit and 64-bit
    NI-SCOPE2025 Q332-bit and 64-bit
    NI R系列多功能RIO2025 Q332-bit and 64-bit
    NI-DMM2025 Q332-bit and 64-bit
    NI-FGEN2025 Q332-bit and 64-bit
    NI-HSDIO2025 Q332-bit and 64-bit
    NI-SWITCH2025 Q332-bit and 64-bit
    更多内容,请参考自述文件。
    2025Q3版自述文件未更新,参考2023Q1版本
    Automated Test Software Suite 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for Automated Test Software Suite 2023 Q1.
    • Automated Test Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the Automated Test Software Suite
    Automated Test Software Suite 2023 Q1 supports the following operating systems:
    The following products are included in the Automated Test Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    LabVIEW2023 Q132-bit and 64-bit
    LabWindows™/CVI2020 f232-bit
    Measurement Studio2019 f432-bit and 64-bit
    TestStand202232-bit and 64-bit
    Add-ons
    Version
    Bitness
    JKI VI Package Manager2023 Q132-bit and 64-bit
    LabWindows™/CVI Execution Profiler1.1.132-bit and 64-bit
    LabWindows™/CVI SQL Toolkit2.432-bit and 64-bit
    Note: The LabVIEW Professional Development System installs the LabVIEW Advanced Signal Processing Toolkit, LabVIEW Desktop Execution Trace Toolkit, LabVIEW Digital Filter Design Toolkit, LabVIEW Unit Test Framework Toolkit, LabVIEW VI Analyzer Toolkit, LabVIEW Database Connectivity Toolkit, and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    Drivers
    Version
    Bitness
    FlexRIO with Integrated I/O2023 Q132-bit and 64-bit
    FlexRIO with Modular I/O2023 Q132-bit and 64-bit
    IVI Compliance Package2022 Q332-bit and 64-bit
    NI-488.22022 Q432-bit and 64-bit
    NI-DAQmx2023 Q132-bit and 64-bit
    NI-DCPower2023 Q132-bit and 64-bit
    NI-DMM2023 Q132-bit and 64-bit
    NI-FGEN2023 Q132-bit and 64-bit
    NI-HSDIO2022 Q432-bit and 64-bit
    NI-SCOPE2023 Q132-bit and 64-bit
    NI-Serial21.532-bit and 64-bit
    NI-SWITCH2023 Q132-bit and 64-bit
    NI-Sync2023 Q132-bit and 64-bit
    PXI Platform Services2023 Q132-bit and 64-bit
    R-Series2023 Q132-bit and 64-bit
    Note: Some drivers included with previous versions of Automated Test Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    If you are using the Automated Test Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The Automated Test Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the Automated Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate Automated Test Software Suite. For more information on Automated Test Software Suite activation, refer to Activating a Product.
    Complete the following steps to install products using the Automated Test Software Suite media.
    • Insert the Automated Test Software Suite installation media.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the Automated Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the Automated Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    Refer to the readme of each product for examples.
    Automated Test Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-3 21:19
