查看: 389|回复: 0
[NI软件套件] HIL and Real-Time Test Software Suite 2025 Q3 Win11 32bitEn 硬件在环和实时测试软件套件2025Q3版-32位英文
    4 小时前
  • 签到天数: 3734 天
    连续签到: 61 天
     楼主| 发表于 2025-9-9 09:05:36 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    发布日期:2025/7/18
    包含版本:2025 Q3专业版,版本号25.5.0
    Windows Server 2025
    应用程序位数:32位
    语言:英文English
    文件大小: 28455563264 字节 (26.50 GB)
    修改日期: 2025-07-23 17:48
    MD5: 3f046591d93330cd212ee582251b2bb6
    SHA1: 704ae92de2197f04705d50217823bedca32d4883
    SHA256: 67aaeb4da50b60a7ad9f6c53e3a1cf57a8fe32d98c17073387844ec466d486dc
    CRC32: 26897f95
    请注册登陆机器视觉论坛账号,购买附件查看下载地址
    HIL-RT TSS2025Q3x86En.txt (658 Bytes, 下载次数: 0, 售价: 40 圆)
    套件包含产品:
    编程环境
    ProductVersionBitness
    LabVIEW2025 Q332-bit and 64-bit
    应用软件
    VeriStand2025 Q364-bit
    附加软件
    LabVIEW Real-Time Module2025 Q132-bit and 64-bit
    LabVIEW FPGA Module2025 Q132-bit and 64-bit
    LabVIEW FPGA Compile Farm  Toolkit2025 Q132-bit and 64-bit
    VeriStand Model Generation  Support for LabVIEW 20252025 Q364-bit
    VeriStand自定义设备2025 Q164-bit
    VeriStand Model Framework2025 Q164-bit
    JKI VI Package Manager2025 Q332-bit and 64-bit
    LabVIEW FPGA Compilation Tool  for Vivado 2021.12025 Q132-bit and 64-bit
    驱动程序
    NI CompactRIO2025 Q332-bit and 64-bit
    NI-DAQmx2025 Q332-bit and 64-bit
    NI-SLSC2025 Q164-bit
    NI-VISA2025 Q332-bit and 64-bit
    NI-XNET2025 Q332-bit and 64-bit
    PXI Platform Services2025 Q332-bit and 64-bit
    NI-Sync2025 Q332-bit and 64-bit
    FlexRIO with Modular I/O2025 Q332-bit and 64-bit
    FlexRIO with Integrated I/O2025 Q332-bit and 64-bit
    NI-488.22025 Q332-bit and 64-bit
    NI-DCPower2025 Q332-bit and 64-bit
    NI R系列多功能RIO2025 Q332-bit and 64-bit
    NI-Industrial Communications for  EtherCAT2025 Q232-bit and 64-bit
    NI-SWITCH2025 Q332-bit and 64-bit
    2025Q3版未更新自述文件,参考2023Q1版。
    HIL and Real-Time Test Software Suite 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for HIL and Real-Time Test Software Suite 2023 Q1.
    • HIL and Real-Time Test Software Suite Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    Products Included in the HIL and Real-Time Test Software Suite
    HIL and Real-Time Test Software Suite 2023 Q1 supports the following operating systems:
    The following products are included in the HIL and Real-Time Test Software Suite installer. This may not be a complete list of products that are activatable by your bundle serial number. Refer to the readme of each product for information including system requirements, installation, activation, known issues, and bug fixes.
    Application Software
    Version
    Bitness
    LabVIEW2023 Q132-bit and 64-bit
    VeriStand202364-bit
    Add-ons
    Version
    Bitness
    JKI VI Package Manager2023 Q132-bit and 64-bit
    LabVIEW FPGA Compilation Tool for Vivado 2021.12022 Q364-bit
    LabVIEW FPGA Compile Farm Toolkit2023 Q132-bit and 64-bit
    LabVIEW FPGA Module2023 Q132-bit and 64-bit
    LabVIEW Real-Time Module2023 Q132-bit and 64-bit
    VeriStand Model Framework202132-bit and 64-bit
    VeriStand Model Generation Support for LabVIEW 2023 Q12023 Q132-bit and 64-bit
    Note: The LabVIEW Professional Development System installs the LabVIEW Advanced Signal Processing Toolkit, LabVIEW Desktop Execution Trace Toolkit, LabVIEW Digital Filter Design Toolkit, LabVIEW Unit Test Framework Toolkit, LabVIEW VI Analyzer Toolkit, LabVIEW Database Connectivity Toolkit, and the LabVIEW Report Generation Toolkit. You can locate the readmes for these products in the labview\readme directory.
    Drivers
    Version
    Bitness
    FlexRIO with Integrated I/O2023 Q132-bit and 64-bit
    FlexRIO with Modular I/O2023 Q132-bit and 64-bit
    NI CompactRIO2023 Q132-bit and 64-bit
    NI-488.22022 Q432-bit and 64-bit
    NI-DAQmx2023 Q132-bit and 64-bit
    NI-DCPower2023 Q132-bit and 64-bit
    NI-Industrial Communications for EtherCAT2023 Q132-bit and 64-bit
    NI-SWITCH2023 Q132-bit and 64-bit
    NI-Sync2023 Q132-bit and 64-bit
    NI-XNET2023 Q132-bit and 64-bit
    PXI Platform Services2023 Q132-bit and 64-bit
    R-Series2023 Q132-bit and 64-bit
    Note: Some drivers included with previous versions of HIL and Real-Time Test Software Suite are not included with this release. Visit ni.com/downloads for the latest driver versions.
    If you are using the HIL and Real-Time Test Software Suite .NET Class Library, .NET Framework 4.0 (minimum) is required. The HIL and Real-Time Test Software Suite 2023 Q1 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the HIL and Real-Time Test Software Suite installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate HIL and Real-Time Test Software Suite 2023 Q1. For more information on HIL and Real-Time Test Software Suite 2023 Q1 activation, refer to Activating a Product.
    Complete the following steps to install products using the HIL and Real-Time Test Software Suite media.
    • Insert the HIL and Real-Time Test Software Suite installation media.
    Installing LabVIEW Add-Ons
    Installing LabVIEW add-ons, such as modules and toolkits, from the HIL and Real-Time Test Software Suite media ensures compatibility. Some versions of LabVIEW add-ons that are not found on the HIL and Real-Time Test Software Suite media may not work with the version of LabVIEW included in this release. Installing an incompatible add-on might cause some features in the add-on or LabVIEW to behave incorrectly.
    Refer to the readme of each product for examples.
    HIL and Real-Time Test Software Suite no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-6 17:01
