查看: 490|回复: 0
[NI软件产品] NI RFmx Pulse 2025 Q3 Patch 2 Win11 64bitENG RFmx脉冲分析仪25.5.2
  • 签到天数: 3810 天
     楼主| 发表于 2025-9-28 09:40:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx Pulse
    RFmx Pulse可帮助您执行交互式和自动化脉冲分析测量。
    RFmx Pulse是一款测量专用软件,可扩展NI RF仪器的脉冲分析功能,例如PXI矢量信号分析仪和PXI矢量信号收发器。借助RFmx Pulse,您可以通过脉冲轮廓测量(例如时间、电平、相位和频率)以及FM线性调频调制测量和幅度和相位的脉冲稳定性测量来分析脉冲信号。
    发布日期:2025/7/23
    包含的版本:2025 Q3F2完整版/运行版,版本号25.5.2
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2621325312 字节 (2.44 GB)
    修改日期: 2025-08-19 18:50
    MD5: a0265f931bd4d9f13a232566d747613d
    SHA1: 15acae5b3ab388594382b75073d667f60e219c4d
    SHA256: a134afe3b7d2d4e9a8e897a6eceb1aacf0097b96445db54b032cb0fc4356f414
    CRC32: fa647f10
    NI官方下载和百度网盘下载地址:
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx Pulse 2025Q3F2.txt (546 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1021992960 字节 (974.65 MB)
    修改日期: 2025-08-19 18:49
    MD5: 002a88c7a57c0a8edc07d641a6bca623
    SHA1: 6712c52999eed9be4afc882088f92046fd93c97a
    SHA256: 6384c67983d07a7dceb3f99e7abd1375f7ed3a4d39350b531bfd5f7556e52df7
    CRC32: 13ab4baa
    NI官方下载和百度网盘下载地址:
    RFmx Pulse 2025Q3F2RTE.txt (571 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q3F2版未更新自述文件,参考2023Q3版
    RFmx Pulse 2023 Q3 Readme
    This file contains important information about the RFmx Pulse, including system requirements, and installation instructions.
    • RFmx Pulse Release Notes: Known issues, and other notes about this release
    • RFmx Pulse Manuals: Features overview and other documentation
    Overview of Features
    RFmx Pulse 2023 Q3 includes the following features:
    • Support for Pulse profile measurement results
      • Time
        • Rise Time, Fall Time, Pulse Width and PRI
      • Level
        • Top level, Base level, ON level, Droop, Overshoot, Ripple
      • Phase and Frequency
        • Average, Deviation and Error
    • Support for FM Chirp modulation results
    • Support for Pulse Stability measurements
      • Amplitude, Phase and Total
    • Support for Segmented and Single large record in Signal Acquisition methods
    RFmx Pulse has the following requirements:
    RFmx Pulse 2023 Q3 supports the following 64-bit operating systems:
    RFmx Pulse supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx Pulse. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx Pulse (64-bit only)
    If you are using the RFmx Pulse .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx Pulse .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx Pulse installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx Pulse. For more information on RFmx Pulse activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.PulseMX.Fx40.dll
    RFmx Pulse palette VIs are available from the Functions » Measurement I/O » RFmx » Pulse palette.
    Documentation for RFmx Pulse is located at Start » National Instruments » RFmx Pulse Documentation.
    You can access all the installed RFmx Pulse examples at Start » National Instruments » RFmx Pulse Examples.
    GMT+8, 2026-2-27 11:49
