查看: 527|回复: 0
[NI软件产品] NI RFmx TD-SCDMA 2025 Q3 Patch 2 Win11 64bitENG RFmx蜂窝测试TD-SCDMA25.5.2
  • 签到天数: 3810 天
     楼主| 发表于 2025-9-28 10:05:21 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx TD-SCDMA
    发布日期:2025/7/23
    包含的版本:2025 Q3 F2完整版/运行版,版本号25.5.2
    Windows Server 2025
    64位完整版校验和:
    文件大小: 2627999744 字节 (2.45 GB)
    修改日期: 2025-08-19 17:15
    MD5: f3e8d7a61f38504b94685078829d822a
    SHA1: 5588f98883d7fd6a85fa7446e3d8da55fd87baf8
    SHA256: 6ac9c9f52dea1006cc57a4a6f25809d1898bf9caadc0f80842d4d08fc3866489
    CRC32: af93a3c3
    请注册登录机器视觉论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA 2025Q3F2.txt (555 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1027147776 字节 (979.56 MB)
    修改日期: 2025-08-19 17:14
    MD5: 6ef3d947a841d0e97384ca56bcb58518
    SHA1: 1d73a63ce0c240beed30967d8baccc894b85fb2b
    SHA256: d703bb2fbbd92fab88d0e68417ce78a7c695fc6655a071b5276ed459a1c269a8
    CRC32: 205e3ec8
    请注册登录视觉机器论坛用户,购买附件查看下载地址
    RFmx TD-SCDMA 2025Q3F2RTE.txt (580 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q3未更新自述文件,参考2023Q3版本
    RFmx TD-SCDMA 2023 Q3 Readme
    • RFmx TD-SCDMA Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx TD-SCDMA Manuals: New features, behavior changes, and other documentation
    RFmx TD-SCDMA 2023 Q2 includes the following new feature:
    RFmx TD-SCDMA 2023 Q1 includes the following new feature:
    RFmx TD-SCDMA 2022 Q4 includes the following new feature:
    • Support for PXIe-5842
    RFmx TD-SCDMA 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx TD-SCDMA no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx TD-SCDMA 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx TD-SCDMA 2023 Q3 to an unsupported OS. Additionally, after installing RFmx TD-SCDMA 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx TD-SCDMA supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx TD-SCDMA. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx TD-SCDMA (64-bit only)
    • Use the serial number that is included with your software to activate RFmx TD-SCDMA. For more information on RFmx TD-SCDMA activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    Import Library files
    RFmx TD-SCDMA palette VIs are available from the Functions » Measurement I/O » RFmx » TDSCDMA palette.
    Documentation for RFmx TD-SCDMA is located at Start » National Instruments » RFmx TD-SCDMA Documentation.
    You can access all the installed RFmx TD-SCDMA examples at Start » National Instruments » RFmx TD-SCDMA Examples.
    The following is the behavior change in RFmx TD-SCDMA 2023 Q3 from RFmx TD-SCDMA 2023 Q2
    The following is the behavior change in RFmx TD-SCDMA 2022 Q4 from RFmx TD-SCDMA 2022 Q3
    • RFmx TD-SCDMA drops support for 32-bit user mode.
    The following is the behavior change in RFmx TD-SCDMA 2022 Q3 from RFmx TD-SCDMA 21.8.2:
    GMT+8, 2026-2-27 11:48
