查看: 419|回复: 0
[NI驱动程序] NI IVI Compliance Package 2025 Q4 Win11 32/64bitEng NI IVI合规软件包下载ICP25.8.0
  • 签到天数: 3810 天
     楼主| 发表于 2025-11-10 08:41:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    IVI合规软件包
    发布日期:2025/10/10
    包含的版本:2025 Q4完整版,版本号25.8.0
    Windows Server 2025
    文件大小: 493025280 字节 (470.19 MB)
    修改日期: 2025-11-03 11:24
    MD5: 77056073d80eaf8fbba54b3033461028
    SHA1: 647406a42a30e768f11f2a827cd5fe0d3a3929e5
    SHA256: 3ebd03960a500a000211a22ed81b3b09f824ea12d7758686a206873a1395867d
    CRC32: 2a697ced
    请注册登录视觉论坛账号,购买附件查看下载地址
    IVI Compliance Package2025Q4.txt (523 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q4版未更新自述文件,参考2022Q3版。
    NI IVI Compliance Package 2022 Q3 Readme
    July 2022
    This file contains important information about the IVI Compliance Package (ICP), including installation instructions, new features, a list of bugs fixed for ICP 2022 Q3, and known issues.
    • IVI Compliance Package Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • IVI Compliance Package Manuals: New features, behavior changes, and other documentation
    Installed Components
    Uninstall Considerations
    Known Incompatibilities
    The IVI Compliance Package is a software package that contains the IVI class drivers and support libraries necessary to develop and use applications that leverage IVI instrument interchangeability. The IVI Compliance Package also is based on and is compliant with the latest version of the instrument programming specifications defined by the IVI Foundation. You can use the IVI class drivers in the IVI Compliance Package with IVI specific drivers.
    IVI class drivers implement functions and attributes for controlling an instrument within a specified class, as defined by the IVI Foundation. The IVI Compliance Package provides IVI class drivers for the following specifications:
    • IviACPwr
    • IviCounter
    • IviDCPwr
    • IviDigitizer
    • IviDmm
    • IviDownconverter
    • IviFgen
    • IviPwrMeter
    • IviRFSigGen
    • IviScope
    • IviSpecAn
    • IviSwtch
    • IviUpconverter
    IVI specific drivers are drivers for the most popular instruments from all of the currently defined IVI Foundation classes and from the largest instrument manufacturers including National Instruments, Keysight Technologies, and Tektronix. You can create IVI specific drivers yourself, or download them from ni.com/idnet.
    Depending on the software support you select when you install ICP 2022 Q3, the installation includes one or more of the following components:
    • IVI class drivers
    • IVI class driver wrappers for LabVIEW 2019, 2020, 2021, and 2022
    • IVI.NET adapters
    • IVI Shared Components 2.6.1
    • IVI.NET Shared Components 1.4.1
    • IVI configuration plug-in for Measurement & Automation Explorer (MAX) 4.7 and later
    • Documentation
    ICP supports the following operating systems:
    • Red Hat Enterprise Linux 8
    • Red Hat Enterprise Linux 7
    • CentOS 8
    • CentOS 7
    • openSUSE Leap 15.2
    • openSUSE Leap 15.1
    • Ubuntu 20.04
    • Ubuntu 18.04
    Note  ICP no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. ICP 2022 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use ICP 2022 Q3 to an unsupported OS. Additionally, after installing ICP 2022 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    ICP supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by ICP
    LabVIEW2019 and later
    NI LabWindows™/CVI™2017 and later
    Download the IVI Comliance Package installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    The "IVI Compliance Package Support for LabVIEW" package supports applications using ICP ​with LabVIEW 2022 or later. When installing ICP 2022 Q3, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    To install the stand-alone, web-only version of ICP, complete the following steps:
    • Download the ICP 2022 Q3 installer from http://www.ni.com/downloads/drivers/ by searching for IVI Compliance Package.
    • Double-click on the installer file.
    Installation Notes
    • The ICP 21.0 and later stand-alone, web-only distributions do not install NI I/O Trace (formerly known as NI-Spy) or MAX. You can install NI I/O Trace and MAX using several other National Instruments products, including the NI Device Drivers media.
    • The installation directory for LabWindows/CVI IVI Class examples and IVI Class Simulation drivers has been changed. The new installation directory is \Documents\National Instruments\CVI\Samples\IVI directory.
    • ICP 3.2 and later include IVI-COM adapters, which enable users to use IVI-C and IVI-COM specific drivers interchangeably in the same 32-bit application. For more information on IVI-COM adapters, refer to the IVI-C Class Driver Support for IVI-COM Specific Drivers document.
    • ICP 19.0 and later include IVI.NET adapters, which enable users to use IVI-C and IVI.NET specific drivers interchangeably in the same application.
    • ICP 4.5 and later install alternate FP and SUB files for the IviFgen class driver in order to support setting 64-bit integer attributes. For more information, refer to KnowledgeBase 5WOA752F: Issue Setting IviFgen Attribute ID Using Get/Set/CheckAttributeViInt64 Functions.
    After you uninstall ICP 2022 Q3, the IVI Shared Components remain on the system. To remove the remaining components, right-click IVI Shared Components 3.0 and select Uninstall/Change.
    If you installed ICP 2022 Q3 as part of another distribution that depends on ICP 2022 Q3, you cannot uninstall ICP 2022 Q3 without uninstalling the dependent product.
    This release includes the following new features:
    • Added support for LabVIEW 2022 Q3
    • In ICP 19.5 and IVI Shared Components 2.6 or later, the installers no longer unlock the IVI Foundation directory. Therefore, you no longer can modify the files installed under the IVI Foundation directory.
    Refer to the National Instruments IVI™ Driver Help, accessible from Start>>All Programs>>National Instruments>>ICP Documentation>>IVI Driver Help, for information about the ICP 2022 Q3.
    ©1999–2022 National Instruments Corporation. All rights reserved.
    GMT+8, 2026-2-27 11:48
