查看: 156|回复: 0
[NI驱动程序] NI-DAQmx 2025 Q4 Win11 32/64bit多国语言 NI-DAQmx25.8.0
    昨天 10:57
  • 签到天数: 3732 天
    连续签到: 59 天
     楼主| 发表于 2025-11-12 08:42:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-DAQmx
    自19.0版开始,使用在线安装与离线安装版,视觉论坛仅提供离线安装版本。同时自19.0版开始,不再提供运行引擎和含配置支持的运行引擎。从20.7版本开始,仅支持Win10 64位系统(仍可支持32位的LabVIEW)。从2022Q3版开始,支持WIN11操作系统。
    NI-DAQmx 2025 Q4
    发布日期:2025/10/10
    包含的版本:2025 Q4完整版,版本号25.8.0
    Windows Server 2025
    语言:中文, 德语, 日语, 法语, 英文, 韩语
    文件大小: 3222077440 字节 (3.00 GB)
    修改日期: 2025-11-03 11:36
    MD5: c540712e9b7116da144ef2793c1dc325
    SHA1: f7e6a06ec9a493a46721b8f116ac777b6db680e1
    SHA256: 92cdd92d0d1257f818c22edbfcb45ce9875c2aca8b4548d140307ad24baa0511
    CRC32: 38f464c4
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    NI-DAQmx2025Q4.txt (514 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q4版未更新自述文件,参考2023Q3版
    NI-DAQmx 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-DAQmx 2023 Q3.
    • NI-DAQmx Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-DAQmx Documentation: New features, behavior changes, and other documentation
    Device Support in NI-DAQmx
    NI-DAQmx 2023 Q3 has the following requirements:
    • 1 GHz or faster 64-bit (x64) processor
    • 2 GB of RAM
    NI-DAQmx 2023 Q3 supports the following operating systems:
    • Windows Server 2016 (64-bit)
    • Windows Server 2019 (64-bit)
    Note  NI-DAQmx no longer supports any 32-bit Windows operating system.
    NI-DAQmx 2023 Q3 supports the following application software versions, including service packs. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by NI-DAQmx 2023 Q3
    2020 and later
    LabVIEW Real-Time Module
    2020 and later
    LabWindows™/CVI™
    2015, 2017, and 2019
    LabWindows/CVI Real-Time Module
    2015 and 2017
    NI-DAQmx Measurement Studio Integration (Measurement Studio 2019)
    Visual Studio 2015, 2017, and 2019
    SignalExpress
    2015
    The following table lists the programming languages and Microsoft Visual Studio versions supported by this version of NI-DAQmx. Earlier versions of NI-DAQmx support other application software and language versions.
    Programming Language
    Visual Studio Versions Supported by NI-DAQmx
    ANSI C
    2012 and Later
    .NET Framework 4.0 and Later Languages
    (Visual C# .NET and Visual Basic .NET)
    2012 and Later
    For information on Visual Studio compatibility with earlier versions of NI-DAQmx, refer to ni.com/info and enter the info code NETlegacydrivers. To find and download an earlier version of a driver, refer to ni.com/downloads.
    For information on examples that use NI-DAQmx and Measurement Studio, refer to Where to Find Examples in the NI-DAQmx .NET Class Library Help.
    Download the NI-DAQmx installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    • Use the serial number that is included with your software to activate NI-DAQmx 2023 Q3. For more information on NI-DAQmx 2023 Q3 activation, refer to Activating a Product.
    The "NI-DAQmx Support for LabVIEW" package supports applications using NI-DAQmx ​with LabVIEW 2022 or later. When installing NI-DAQmx, this package will be recommended if you have already installed LabVIEW 2022 or later and installs to the LVAddons directory.
    FieldDAQ
    • As of DAQmx 19.1, FieldDAQ firmware is distributed with the DAQmx driver and installed via MAX. For additional information, refer to Firmware Information for NI FieldDAQ Devices.
    • To fully enable TSN synchronization features, TSN-enabled chassis and devices should update to at least firmware version 20.0.
    • Certain NI Linux Real-Time controllers, including the the cRIO-904x and cRIO-905x NI Linux Real-Time controllers support C Series modules in DAQmx mode.
    CompactRIO Controllers and CompactRIO Single-Board ControllersFor these controllers, you must install both NI CompactRIO and NI-DAQmx. For additional information on driver support, refer to Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT.
    SC Express AccessoriesSupport for SC Express terminal blocks and other accessories is documented for individual devices in the Notes section of the NI Hardware and Operating System Compatibility page.
    C Series, Network DAQ, and USB DAQ
    • The NI USB-9211A and NI USB-9215A (C Series modules with a bundled NI USB-9162) are supported in NI-DAQmx.
    • The NI USB-9211 and NI USB-9215 (C Series modules with a bundled NI USB-9161) are not supported in NI-DAQmx.
    • NI 9207, NI 9208, NI 9209, NI 9425, and NI 9476 Spring Terminal variants are supported only in NI-DAQmx 17.1 and later. For additional information on driver support, refer to Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT
    • NI 9210 Spring Terminal variants are supported only in NI-DAQmx 17.1 and later. For additional information on driver support, refer to Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT
    CompactDAQ Chassis
    • As of DAQmx 19.1, CompactDAQ chassis firmware is distributed with the DAQmx driver and installed via MAX. For additional information, refer to Firmware Information for NI CompactDAQ Network Chassis.
    • To fully enable TSN synchronization features, cDAQ-9185/9 chassis should update to at least firmware version 20.0.
    • The NI cDAQ-9181, NI cDAQ-9184, NI cDAQ-9188, NI cDAQ-9188XT, and NI cDAQ-9191 devices are not supported by Real-Time controllers.
    • Regarding the NI cDAQ-9185 and NI cDAQ-9189 chassis: Only the cRIO-904x and cRIO-905x NI Linux Real-Time controllers support C Series modules in DAQmx mode.
    CompactDAQ Controllers
    • Regarding the NI cDAQ-9136 and NI cDAQ-9137: real-time support for this controller was added in the LabVIEW Real-Time Module 2015.
    SwitchesAs of NI-DAQmx 14.5, the NI-DAQmx Switch API is obsolete and is no longer recommended for new applications.
    Some devices are no longer supported in NI-DAQmx. Refer to Devices No Longer Supported in NI-DAQmx 17.6 and Later for specific devices and the versions in which support was dropped.
    To find the locations of examples for your software application, refer to the following table.
    Software Application
    Example Location
    LabVIEW or LabWindows/CVIHelp»Find Examples
    SignalExpressProgram Files\National Instruments\SignalExpress\Examples
    ANSI C*...NI-DAQ\Examples\DAQmx ANSI C
    .NET 4.0 Framework*...NI-DAQ\Examples\DotNET 4.0
    .NET 4.5 Framework*...NI-DAQ\Examples\DotNET 4.5
    * For Windows, the default path is :\Users\Public\Public Documents\National Instruments\NI-DAQ\Examples\... .
    NI-DAQmx no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-5 07:06
