查看: 140|回复: 0
[NI软件产品] NI Switch Executive 2023 Q4 Patch 1 Win11 32/64bitEng 美国国家仪器开关管理软件23.8.1
    昨天 10:57
  • 签到天数: 3732 天
    连续签到: 59 天
     楼主| 发表于 2025-11-14 09:52:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Switch Executive是一款开关管理与路由应用软件,能够加速开发过程、简化对复杂开关系统的维护。
    Switch Executive提供交互式配置和自动路由功能,使开关系统的设计变得更加容易。您可以为开关模块、外部连接和信号路由分配别名,从而简化系统的文档,以便未来进行修改。使用Switch Executive开发的测试代码可以复用于LabVIEW、LabWindows/CVI、Measurement Studio和TestStand环境。
    发布日期:2025/1/14
    包含的版本:2023 Q4 Patch 1完整版,版本号23.8.1
    受支持的操作系统
    语言:英文English
    文件大小: 1136566272 字节 (1.06 GB)
    修改日期: 2025-11-14 09:36
    MD5: 7b1a610972c0e9ea215b597b42dc2c52
    SHA1: 68038736f4d974d09475284b641fd203f89d8c56
    SHA256: 1eff64ed7e4b920224acdc5d15395dfab3454fa15fd247c1edd37846c7c3334c
    CRC32: 2be19f93
    百度网盘下载地址和NI官方下载地址:
    请注册登录机器视觉论坛账号,购买附件查看下载地址下载地址
    NI-Switch Executive 2023 Q4 Patch 1.txt (606 Bytes, 下载次数: 0, 售价: 10 圆)
    2023Q4Pacth1版未更新自述文件,请参考2023Q1版
    Switch Executive 2023 Q1 Readme
    January 2023
    This file contains installation instructions and compatibility information for Switch Executive.
    You can find more information on ni.com
    • Switch Executive Release Notes: New features, behavior changes, and other documentation
    • Switch Executive Manuals: New features, behavior changes, and other documentation
    Switch Executive 2023 Q1 has the following requirements:
    • Processor—1 GHz or faster 64-bit (x64) processor
    • 2 GB RAM (64-bit)
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW.
    Switch Executive 2023 Q1 supports the following operating systems:
    Switch Executive 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by Switch Executive
    LabVIEW2020 or later
    Download the Switch Executive installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using Package Manager.
    Note  If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue.
    When installing NI SwitchExecutive, the "NI SwitchExecutive Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2023 or later and installs to the LVAddons directory. This package supports applications using NI SwitchExecutive with LabVIEW 2023 or later.
    • Switch Executive 2023 Q1 adds support for LabVIEW 2022 Q4 and LabVIEW 2023 Q1.
    Refer to the NI Switch Executive Help, accessible from Start»All Programs»National Instruments»Switch Executive»Switch Executive Documentation, for information about Switch Executive.
    You can access all the installed Switch Executive examples at Start»All Programs»National Instruments»Switch Executive»Switch Executive Examples and online at ni.com/examples.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for Switch Executive are located in the LabVIEW XXXX\examples\SwitchExecutive directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    • Click the Browse tab to locate modulation examples by task at Toolkits and Modules»NI Switch Executive.
    • Click the Search tab to search all installed examples by keyword. For example, search for "Switch Executive" to locate all Switch Executive examples.
    Switch Executive no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2025-12-5 07:31
