查看: 376|回复: 0
[NI软件产品] NI RFmx CDMA2000 2025 Q4 Full/Runtime Win11 64bitEn RFmxCDMA2K完整版运行版25.8.0下载
    4 小时前
  • 签到天数: 3810 天
     楼主| 发表于 2025-11-15 10:01:42 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx CDMA2000
    发布日期:2025/10/10
    包含的版本:2025 Q4完整版/运行版,版本号25.8.0
    Windows Server 2025
    64位完整版校验和:
    文件大小: 1287813120 字节 (1.20 GB)
    修改日期: 2025-11-03 09:23
    MD5: 6f8b84c819c3fc2978f06a3ec1731ddd
    SHA1: 0927ced8eb88fa34ac652c0b325706a68a0f3171
    SHA256: 63810fbd6dd870cc9d828a9e7eb71f30dadf8f98e43af66f38684222f8fe6409
    CRC32: 8415ec23
    请注册登录视觉论坛,购买附件查看下载地址
    RFmx CDMA2000 2025Q4.txt (543 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1025198080 字节 (977.71 MB)
    修改日期: 2025-11-03 09:24
    MD5: 0ecc7a58070f5b8d37da6558322bfcc9
    SHA1: a99e4bf41f6dacb0e7afd0c40c0724c4c5d13216
    SHA256: b8c46f6216c2cc7fc88965b1569c5630b34add5aba0355503ffdce660299e606
    CRC32: 2b7035e3
    RFmx CDMA2000 2025Q4RTE.txt (568 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q4版未更新自述文件,参考2023Q3版本
    RFmx CDMA2k 2023 Q3 Readme
    • RFmx CDMA2k Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx CDMA2k Manuals: New features, behavior changes, and other documentation
    RFmx CDMA2k 2023 Q2 includes the following new feature:
    RFmx CDMA2k 2023 Q1 includes the following new feature:
    RFmx CDMA2k 2022 Q4 includes the following new features:
    • Support for PXIe-5842
    • Support for Downlink link direction in CDMA2k ModAcc measurement.
    RFmx CDMA2k 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx CDMA2k no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx CDMA2k 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx CDMA2k 2023 Q3 to an unsupported OS. Additionally, after installing RFmx CDMA2k 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    Versions Supported by RFmx CDMA2k (64-bit only)
    Item
    Installed Location
    Import Library files (64-bit)
    Assemblies\DotNET\Assemblies\Current\NationalInstruments.RFmx.CDMA2k.Fx40.dll
    Select Start » National Instruments» RFmx CDM2k Measurement Interactive Panel to launch the RFmx CDMA2k Measurement Interactive Panel.
    RFmx CDMA2k palette VIs are available from the Functions » Measurement I/O » RFmx » CDMA2K palette.
    Documentation for RFmx CDMA2k is located at Start » National Instruments » RFmx CDMA2k Documentation.
    You can access all the installed RFmx CDMA2k examples at Start » National Instruments » RFmx CDMA2k Examples.
    The following is the behavior change in RFmx CDMA2k 2023 Q3 from RFmx CDMA2k 2023 Q2
    The following is the behavior change in RFmx CDMA2k 2022 Q4 from RFmx CDMA2k 2022 Q3
    • RFmx CDMA2k drops support for 32-bit user mode.
    The following is the behavior change in RFmx CDMA2k 20.7 from RFmx CDMA2k 20.6.
    GMT+8, 2026-2-27 13:31
