查看: 430|回复: 0
[NI软件产品] NI RFmx NR 2025 Q4 Patch 1 Win11 64bitENG RFmx 5G新空口蜂窝测试25.8.1
    4 小时前
  • 签到天数: 3823 天
    连续签到: 16 天
     楼主| 发表于 2025-11-17 18:09:27 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx NR
    发布日期:2025/10/19
    包含的版本:2025 Q4 Patch 1完整版/运行版,版本号25.8.1
    Windows Server 2025
    64位完整版校验和:
    文件大小: 3398598656 字节 (3.17 GB)
    修改日期: 2025-11-03 09:32
    MD5: 05289c73a30a08d24cf62ca28a7b1d42
    SHA1: ecc37b388d6e6a192fc009c39952ae0acef75d40
    SHA256: 85d85313b0aa4b1b3e8bd1f5352ff6bd4c4ed408b7231dc9380a04076840481e
    CRC32: 7b113c70
    NI官方下载和百度网盘下载地址:
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    RFmx NR2025Q4F1.txt (533 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1073102848 字节 (1023.39 MB)
    修改日期: 2025-11-03 09:34
    MD5: bef7c3f7f3ab2f099c36daed09eec978
    SHA1: 7b87a6b0e73a10a4ddc844ed173c4ad68a5633f1
    SHA256: a43cd4039547d9795dafff482d790043bf0d7bc0a7d58651b6888372f632fe2f
    CRC32: 242886e7
    NI官方下载和百度网盘下载地址:
    RFmx NR2025Q4RTEF1.txt (564 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q4pacth1版未更新自述文件,参考2023Q3版本
    RFmx NR 2023 Q3 Readme
    This file contains important information about the RFmx NR, including system requirements, and installation instructions.
    • RFmx NR Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx NR Manuals: New features, behavior changes, and other documentation
    RFmx NR 2023 Q3 includes the following new features:
    • Support for Reference Signal Transmit (RSTX) power measurement in ModAcc measurement
    • Support for NS_03U and NS_21 (Rel-17 onwards) masks in SEM measurement
    • Support for Band n54 in downlink SEM measurement
    RFmx NR 2023 Q2 includes the following new features:
    • Support for Phase Offset measurement
    • Support for Test Tolerance for NR-U band n46 in SEM measurement as per 3GPP Release 17 (December-2022)
    RFmx NR 2023 Q1 includes the following new features:
    • Support for EVM Measurement including symbols with Transient Period
    • Support for shared spectrum channels for n46, n96, and n102 bands in the SEM Measurement
    • Support for Power Class 6 in the IBE Measurement
    RFmx NR has the following requirements:
    RFmx NR 2023 Q3 supports the following 64-bit operating systems:
    RFmx NR supports the following application software versions, including service packs. You should install application software, such as LabVIEW or Microsoft Visual Studio®, before installing RFmx NR. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx NR (64-bit only)
    If you are using the RFmx NR .NET Class Library, .NET Framework 4.0 (minimum) is required. The RFmx NR .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Download the RFmx NR installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • Use the serial number that is included with your software to activate RFmx NR. For more information on RFmx NR activation, refer to National Instruments Software Activation.
    Item
    Installed Location
    RFmx NR palette VIs are available from the Functions » Measurement I/O » RFmx » NR palette.
    Documentation for RFmx NR is located at Start » National Instruments » RFmx NR Documentation.
    You can access all the installed RFmx NR examples at Start » National Instruments » RFmx NR Examples.
    The following is the behavior change in RFmx NR 2023 Q3 from RFmx NR 2023 Q2
    The following are the behavior changes in RFmx NR 2022 Q3 from RFmx NR 21.8:
    • RFmx Soft Front Panel has been replaced by InstrumentStudio.
    The following are the behavior changes in RFmx NR 21.8 from RFmx NR 21.5:
    • RFmx NR drops support for 32-bit user mode.
    • Deprecated PDSCH present in SSB Resource Block.
    • Deprecated Subblock Freq Definition property. Use Subblock Freq (Hz) property for configuring subblock frequency offset from the center frequency.
    The following are the behavior changes in RFmx NR 21.3 from RFmx NR 20.7/20.7.1:
    • Updated downlink subblock integration bandwidth for ACP, CHP, and SEM measurements as per 38.104 CR0262.
    • Increased acquisition length for ModAcc measurement in the case of DFT-s-OFDM with SCS 60 kHz, and above with trigger types other than digital and sync mode other than Frame.
    GMT+8, 2026-3-12 12:59
