查看: 343|回复: 0
[NI软件产品] NI RFmx SpecAn/Power Amplifier/Phase Noise/Niose Figure 2025 Q4 Patch 1 Win11 64bitENG RFmx频谱分析仪/功率放大器/相位噪声/噪声系数25.8.1
  • 签到天数: 3810 天
     楼主| 发表于 2025-11-18 10:14:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    RFmx SpecAn
    RFmx SpecAn为时域和频谱分析提供互动和自动测量。
    发布日期:2025/10/19
    包含的版本:2025 Q4完整版/运行版,版本号25.8.1
    Windows Server 2025
    64位完整版校验和:
    文件大小: 3208886272 字节 (2.99 GB)
    修改日期: 2025-11-03 10:00
    MD5: 615797a3d5fa9e193f1123df8c9e4661
    SHA1: 30c83d92617fa3a31abe66624a7ec6b72060d9de
    SHA256: b9f427939ff4a4cc5cdd085594010d804b78b10618265bf636c495f2992f6f3e
    CRC32: b204c88e
    请注册登录视觉论坛账号,购买附件查看下载地址
    RFmx SpecAn2025Q4F1.txt (549 Bytes, 下载次数: 0, 售价: 10 圆)
    64位运行版校验和:
    文件大小: 1033490432 字节 (985.61 MB)
    修改日期: 2025-11-03 10:01
    MD5: 0c547845c9e8dd7c2a4da56abd104c4f
    SHA1: e36f775dac8a91e1dd6188a8429de41e8fce6d8e
    SHA256: 5a7b7fca432f60fc5b003d089ae8da2c8d690899fb8b5ad5af0a17d7597493a7
    CRC32: 2779f72e
    RFmx SpecAn2025Q4RTEF1.txt (574 Bytes, 下载次数: 0, 售价: 5 圆)
    2025Q4Patch1版本未更新自述文件,参考2023Q3版本
    RFmx SpecAn 2023 Q3 Readme
    This file contains important information about the RFmx SpecAn, including system requirements, and installation instructions.
    • RFmx SpecAn Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • RFmx SpecAn Manuals: New features, behavior changes, and other documentation
    RFmx SpecAn 2023 Q3 includes the following new features:
    • Iterative Learning Control for DPD measurement
    RFmx SpecAn 2023 Q2 includes the following new features:
    • Support for Detectors in CHP and ACP measurements
    RFmx SpecAn 2023 Q1 includes the following new feature:
    RFmx SpecAn has the following requirements:
    RFmx SpecAn 2023 Q3 supports the following 64-bit operating systems:
    Note    RFmx SpecAn no longer supports Windows Vista/XP/7/8.1, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. RFmx SpecAn 2023 Q3 will not install or run on an unsupported OS. You cannot deploy or distribute applications that use RFmx SpecAn 2023 Q3 to an unsupported OS. Additionally, after installing RFmx SpecAn 2023 Q3, you cannot use any installers built on this computer with any version of LabVIEW, LabWindows™/CVI™, NI TestStand™, or Measurement Studio on an unsupported OS.
    RFmx SpecAn supports the following application software versions, including service packs. You should install application software, such as LabVIEW, LabWindows/CVI or Microsoft Visual Studio®, before installing RFmx SpecAn. If you are not using NI application software, refer to Microsoft Visual Studio Support.
    Versions Supported by RFmx SpecAn
    LabWindows™/CVI™2019 or later
    • NI-RFSG 14.0.1 or later
    Download the RFmx SpecAn installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Manual for more information about installing, removing, and upgrading NI software using NI Package Manager.
    • RFmx SpecAn installs the following licensed products
      • RFmx Noise Figure: This will enable the Noise Figure measurement in RFmx SpecAn.
      • RFmx Phase Noise: This will enable the Phase Noise measurement in RFmx SpecAn.
      • RFmx Power Amplifier: This will enable the AMPM and DPD measurements and the Crest Factor Reduction (CFR) support in RFmx SpecAn.
    • Use the serial number that is included with your software to activate the product. Refer to the NI Software Activation for more information on product activation.
    Item
    Installed Location
    Import Library files
    Documentation for RFmx SpecAn is located at Start » National Instruments » RFmx SpecAn Documentation.
    You can access all the installed RFmx SpecAn examples at Start » National Instruments » RFmx SpecAn » RFmx SpecAn Examples.
    The following is the behavior change in RFmx SpecAn 2023 Q3 from RFmx SpecAn 2023 Q2
    The following is the behavior change in RFmx SpecAn 2022 Q4 from RFmx SpecAn 2022 Q3:
    • RFmx SpecAn drops support for 32-bit user mode.
    The following is the behavior change in RFmx SpecAn 2022 Q3 from RFmx SpecAn 21.8.2:
    The following are the behavior changes in RFmx SpecAn 20.7 from RFmx SpecAn 20.6.
    GMT+8, 2026-2-27 12:00
