查看: 454|回复: 0
[NI软件产品] NI Vehicle Communication Diagnostic Toolkit 2025 Q3 Patch 3 Win11 64bitEng 车辆通信诊断工具包VCDT25.5.3
    13 小时前
  • 签到天数: 3823 天
    连续签到: 16 天
     楼主| 发表于 2025-11-19 08:55:18 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Vehicle Communication Diagnostic工具包可与支持NI-XNET的设备配合使用,为电子控制单元(ECU)设计和验证提供诊断应用程序。
    Vehicle Communication Diagnostic工具包是车辆通信工具包的软件附加Vehicle Communication工具包。该工具包可与诊断数据库文件(PDX)和MCD-3D服务器(未包含在诊断工具包中)配合使用,以执行诊断服务、读取诊断故障代码和刷新ECU。该工具包提供了一个用于Windows操作系统的LabVIEW和C/C++的API以及一个Web诊断数据库查看器。
    发布日期:2025/8/29
    包含的版本:2025 Q3 F3基本版,完整版,版本号25.5.3
    Windows Server 2025
    语言:英文English
    文件大小: 1560477696 字节 (1.45 GB)
    修改日期: 2025-11-03 12:02
    MD5: 7ace0cc8bdc999c3ade860ddea3099d6
    SHA1: 0bdfc5fe7bc4b012fe316d7444c0a1074b1ef9ff
    SHA256: 3d59737024140ad172446cc76bc8c4b493a4a552fb6101a8094a2cb68e596608
    CRC32: bee6942c
    注册登录视觉论坛账号,购买附件查看下载地址
    Vehicle Communication Diagnostic工具包2025Q3F3.txt (585 Bytes, 下载次数: 0, 售价: 10 圆)
    2025Q3F3未更新自述文件,参考2023Q1版
    Vehicle Communication Software Suite 2025 Q3 Changes
    Vehicle Communication Toolkit (NI-VCOM) New Features
    • Support for LabVIEW 2025
    • Support for VeriStand 2025
    • Support for proto files in Ethernet Tap Mode
    • Support for the enumerator, string, and array data types in the LabVIEW API
    • Bug fixes and performance improvements
    • Improvements to enhance user experience, including:
      • Switch to Dark Mode to improve your viewing experience
      • Expand the RestBus page data into tree view
      • Use drop-down field suggestions for properties
    Vehicle Communication Software Suite 2025 Q1 Changes
    • Adds support for making the extended CAN ID settable separately for DTO messages and CRO messages.
    • Adds support for text tables in the NI-VCOM LabVIEW API enum data type.
    • Adds support for the Protobuf workflow.
    • Adds optimized performance for the NI-VCOM custom device engine, allowing you to execute more channels with VeriStand.
    Vehicle Communication Software Suite 2024 Q4 Changes
    • Adds support for array signals in the NI-VCOM custom device.
    • Adds support for measurement signal arrays in the Measurement and Calibration Toolkit.
    Vehicle Communication Software Suite 2024 Q3 Changes
    Vehicle Communication Toolkit New Features
    • Base and Full Versions:
      • Adds support for separate activation of the extended CRO (request) and DTO (response) CAN IDs
    • Full Version Only:
      • Adds support for CAN FD activation in the Measurement and Calibration Toolkit
      • Adds support for Toyota OEM-specific Secure Onboard Communication for CAN .dbc files
      • Adds support for AUTOSAR E2E Profile 11A and 11C for CAN/CAN-FD, Flexray, Automotive Ethernet, and SOME/IP messages
      • Adds support for cyclic transmission mode for Automotive Ethernet and SOME/IP messages
    Vehicle Communication Software Suite 2024 Q1 Changes
    Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2024 Q1.
      • Upgrades supported version of LabVIEW to 2024 Q1
      • Upgrades supported version of VeriStand to 2024 Q1
      • Adds support for a Bus monitor
      • Adds support of byte array data type signals in the NI-VCOM custom device and LabVIEW API
    • NI-VCOM has a new database viewer for RBS, the Calibration Toolkit, and the Diagnostic Toolkit. The new database viewer allows a more hierarchical and dense view of database content and provides a smoother search experience.
    • The Read Signal - State RBS VI in the NI-VCOM LabVIEW API is now named Read (State VCOM).vi. Update the name of the VI if you use this API in your NI-VCOM application.
    Vehicle Communication Software Suite 2023 Q3 Changes
    Learn about new features, behavior changes, and other updates in Vehicle Communication Software Suite 2023 Q3.
      • Adds support for J1939 protocol
      • Adds support for CAN and LIN virtual devices
      • Adds support for multiple VCOM custom devices, each with unique configurations, in the same VeriStand project containing multiple controllers. Each controller can be associated with one VCOM custom device.
      • Adds support for LabVIEW API signal selection in the Read and Write VIs.
      • Adds support for deploying configuration files to remote targets from the WebUI rather than manually copying files between machines.
      • Adds performance improvements for importing large .arxml files and large numbers of signals.
      • Adds support for optional Diagnostic Toolkit
      • Adds support for AUTOSAR Global Time Synchronization
    • The VeriStand Custom Device is now called NI:VCOM rather than Provetech:RBS
    • The VeriStand Custom Device API is now located on the NI-VCOM:Restbus simulation palette
    • The Measurement and Calibration Toolkit is now configured automatically.
    • The VCOM custom device now creates channels that are not scalable by default, but you can set them to be scalable if necessary.
    Vehicle Communication Measurement and Calibration Toolkit 2023 Q1 Readme
    March 2023
    This file contains installation instructions and compatibility information for Vehicle Communication Measurement and Calibration Toolkit 2023 Q1 (Measurement and Calibration Toolkit).
    • Measurement and Calibration Toolkit Release Notes: Known issues and other notes about this release
    • Measurement and Calibration Toolkit Documentation
    Measurement and Calibration Toolkit 2023 Q1 has the following requirements:
    • At least 3 GB of disk space
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for supported LabVIEW versions.
    Measurement and Calibration Toolkit 2023 Q1 supports the following operating system:
    • Windows 10 (64-bit)
    Measurement and Calibration Toolkit 2023 Q1 supports the following communication buses:
    • CAN/CAN-FD
    • FlexRay
    • Automotive Ethernet
    Measurement and Calibration Toolkit 2023 Q1 supports the following application software versions, including service packs.
    Versions Supported by Measurement and Calibration Toolkit 2023 Q1
    LabVIEW (32- and 64-bit)2020, 2021, 2022, 2023
    You must install the Vehicle Communication Toolkit before installing the Measurement and Calibration Toolkit. Refer to the Vehicle Communication Toolkit (Full) Readme or the Vehicle Communication Toolkit (Base) Readme for installation instructions.
    Download the Measurement and Calibration Toolkit installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    The "Measurement and Calibration Toolkit Support for LabVIEW" package supports applications using the Measurement and Calibration Toolkit with LabVIEW 2020 or later. When installing the Measurement and Calibration Toolkit, this package will be recommended if you have already installed LabVIEW 2020 or later and it installs to the LabVIEW VI library.
    Refer to the Vehicle Communication Toolkit documentation, accessible from ni.com/docs, for information about the Measurement and Calibration Toolkit.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Measurement and Calibration Toolkit are located in the LabVIEW\examples\Vehicle Communication Measurement and Calibration Toolkit directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    A demo ECU application for the Measurement and Calibration Toolkit is located in the %Public%\Documents\National Instruments\NI-VCOM\Examples\Measurement and Calibration Toolkit\Demo ECU directory.
    GMT+8, 2026-3-12 21:18
