查看: 21|回复: 0
[NI驱动程序] NI-Digital Pattern Driver 2026 Q1 Win11 32/64bitEng NI数字向量仪器驱动程序26.0.0下载
    半小时前
  • 签到天数: 3824 天
     楼主| 发表于 昨天 09:06 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    从NI-Digital Pattern Driver 21.0版本开始,仅支持64位的Win10/WinServer 2016/WinServer 2019系统,但是仍然支持64位系统下的32位LabVIEW。自2022Q4V22.8版本开始,支持Win11操作系统。自2026Q1版开始,放弃Win10常规版本的支持。
    发布日期:2026/1/28
    包含的版本:2026 Q1完整版,版本号26.0.0
    Windows Server 2025
    语言:英文
    文件大小: 2094002176 字节 (1.95 GB)
    修改日期: 2026-02-07 18:31
    MD5: 98a66163d4cdb034c33e3e6970b21d5f
    SHA1: 7e3844c056355a0671c44c26ed369ab662cbbd8a
    SHA256: 391311e071b6c36896dd9a511f9e542292ffacb55b9afafc7cce58c87a78837a
    SHA512: 2f4b28ad2ae44ab15f4573a93bfe87135e6dfa07fabab2575d4e8ec0e6c8a474adba5d4503f9d46ded45e717399720bb7dcca449bb9e9ad177ce37641917efb2
    请注册登录机器视觉论坛账号,购买附件查看下载地址
    Digital Pattern Driver 2026 Q1.txt (679 Bytes, 下载次数: 0, 售价: 10 圆)
    2026Q1版本未更新自述文件,参考2023Q3版本
    NI-Digital Pattern Driver 2023 Q3 Readme
    This file contains installation instructions and compatibility information for NI-Digital Pattern Driver 2023 Q3.
    • NI-Digital Pattern Driver Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
    • NI-Digital Pattern Driver Documentation: Detailed documentation about how to use your product
    Use the NI Digital Pattern Editor with a Digital Pattern Instrument and the NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs).
    NI-Digital Pattern Driver 2023 Q3 has the following requirements:
    Minimum System Requirements
    • 4 GB RAM
    Recommended System
    • 8 GB RAM
    The NI-Digital Pattern Driver and the Digital Pattern Editor 2023 Q3 support the following operating systems with all available critical updates and service packs:
    NI-Digital Pattern Driver and Digital Pattern Editor 2023 Q3 support the following application software versions, including service packs.
    Versions Supported by NI-Digital Pattern Driver and Digital Pattern Editor 2023 Q3
    LabVIEW2020 and later
    NI TestStand2016 and later (64-bit)
    NI TestStand Semiconductor Module™2016 and later (64-bit)
    Microsoft Visual Studio2010 and later (.NET versions 4.0 and 4.5)
    Note: You must install the NI-DCPower driver to access NI-DCPower-related functionality in the Digital Pattern Editor.
    Note: You must install the NI-Sync driver to access NI-Sync-related functionality.
    If you are using the NI-Digital Pattern Driver .NET Class Library, .NET Framework 4.0 (minimum) is required. The NI-Digital Pattern Driver 2023 Q3 .NET Class Library can be used with Visual C# or Visual Basic .NET in any Visual Studio version that can target .NET Framework 4.0 or .NET Framework 4.5.
    Python Support
    For more information on installing and using the NI-Digital Python API, refer to the nidigital module.
    Download the NI-Digital Pattern Driver installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager.
    Use the serial number that is included with your software to activate the NI-Digital Pattern Driver and Digital Pattern Editor. For more information on NI-Digital Pattern Driver and Digital Pattern Editor activation, refer to NI Software Activation.Accessing the APILabVIEW
    The NI–Digital Pattern Driver palette VIs are available from the following location:
    • Functions»Measurement I/O»NI–Digital palette or Functions»Instrument I/O»Instrument Drivers»NI–Digital palette
    .NET Class Library
    C
    You can use the NI-Digital Pattern C dynamically linked library by adding a reference to C:\Program Files\IVI Foundation\IVI\Bin\niDigital_64.dll for 64-bit development.
    The "NI-Digital Pattern Driver Support for LabVIEW" package supports applications using NI-Digital Pattern Driver ​with LabVIEW 2022 or later [1]. When you install NI-Digital Pattern Driver on LabVIEW 2022 or later, this package is recommended and will install to the LVAddons directory.
    Refer to the NI-Digital Pattern Driver documentation, accessible from Help»LabVIEW Help..., for information about the NI-Digital Pattern Driver. The installed documentation set is composed of the following document:
    • Digital Pattern Help—Contains information about using the Digital Pattern Editor with a Digital Pattern Instrument and NI-Digital Pattern Driver software for digital testing of semiconductors, or devices under test (DUTs). Includes references for the NI-Digital Pattern Driver VIs and properties, the NI-Digital Pattern Driver C functions, and the NI-Digital Pattern .NET Class Library.
    Digital Pattern Instrument manuals are available as PDFs. You must have Adobe Acrobat Reader installed to view the PDFs. You can install the viewer from www.adobe.com/acrobat.
    For the most recent revisions of documentation and for newly released documentation, visit ni.com/docs. Digital Pattern Instrument manuals include the following documents:
    • PXIe-6570 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6570.
    • PXIe-6570 Specifications—Lists technical specifications for the PXIe-6570.
    • PXIe-6570 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6570.
    • PXIe-6571 Getting Started Guide—Contains information about installing, configuring, and testing the PXIe-6571.
    • PXIe-6571 Specifications—Lists technical specifications for the PXIe-6571.
    • PXIe-6571 Safety, Environmental, and Regulatory Information—Contains information about safely operating the PXIe-6571.
    Use the getting started examples, located by default in the \National Instruments\NI-Digital\Examples\Getting Started directory, to help you learn key concepts or to serve as a starting point for applications you create. You can also access the getting started examples by selecting the Start menu and navigating to NI Digital Pattern Examples in the National Instruments folder.
    LabVIEW Examples
    Microsoft .NET Examples
    The Microsoft .NET examples are located in the \National Instruments\NI-Digital\Examples\DotNET 4.x directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    C Examples
    The C examples are located in the \National Instruments\NI-Digital\Examples\C directory. In the Start menu, navigate to NI Digital Pattern Examples in the National Instruments folder.
    NI-Digital Pattern Driver no longer supports Windows Vista/XP/7/8.x, Windows Server 2003/2008/2012, or any 32-bit Windows operating system. Versions of this product that ship after May 1, 2021, may not install or execute correctly on these operating systems. For detailed information about NI operating system support, visit https://www.ni.com/r/win32bitsupport.
    GMT+8, 2026-3-13 09:12
