NI-USRP 2026 Q1 Patch 1 Win11 32/64bitEn NI通用软件无线电外设仪器驱动程序26.0.1
NI USRP
NI-USRP支持使用NI通用软件无线电外设(USRP)收发仪和LabVIEW可重配置I/O (RIO) USRP设备的客户。
NI-USRP是一个NI仪器驱动程序,可同时支持软件无线电(SDR)设备和可重配置SDR设备。如果要配置设备,可使用NI-USRP仪器驱动程序中包含的NI-USRP API或USRP RIO仪器设计库(IDL)。NI-USRP可帮助您使用NI SDR硬件创建发射(Tx)和接收(Rx)应用。
发布日期:2026/2/5
包含的版本:2026Q1Patch1完整版,版本号26.0.1
Windows Server 2025
程序位数:32/64位
文件大小: 4049719296 字节 (3.77 GB)
修改日期: 2026-02-08 09:36
MD5: 265549cf091e64eec63d7e23afe208b9
SHA1: 6601b0586dad4ef6235ce6823e385415bc1b600d
SHA256: 3eb98d911d1e1418307faefc9510ae246859d6234ca7f77255da6b3ee163f4c6
SHA512: a30f92bc01fcfb7852c396ba0ea0c50211d7241dc1ad3e95da8ef2a711868405c05f65177b01612d5f4afa006e6952d3a733f90596d769de9922d5bdc65d96a0
请注册登录机器视觉论坛账号,购买附件查看下载地址
NI-USRP 2026 Q1Patch1.txt
(660 Bytes, 下载次数: 0, 售价: 10 圆)
2026Q1Patch1版本未更新自述说明,参考2023Q3版本
NI-USRP 2023 Q3 ReadmeJuly 2023 This file contains installation instructions and compatibility information for NI-USRP 2023 Q3. You can find more release information on ni.com. - NI-USRP Release Notes: Known issues, bugs fixed since the last release, and other notes about this release
- NI-USRP Documentation: New features, behavior changes, and other documentation
Overview System Requirements Supported Operating Systems Application Software Support Installation Instructions Product Security and Critical Updates New Features Supported Hardware Behavior Changes Accessing the Documentation Finding Examples, Lessons, and Sample Projects Automating the Installation of NI Products Using NI Software with Microsoft Windows 11 Legal Information OverviewThis software installation provides support for customers using software defined radio (USRP) devices, software defined radio reconfigurable (USRP RIO) devices, and software defined radio stand-alone (USRP Stand-Alone) devices, as specified in the Supported Hardware section. To program your USRP, USRP RIO, or USRP Stand-Alone device, use the NI-USRP API or USRP RIO Instrument Design Library (IDL) included in the NI-USRP instrument driver. The getting started guide for your device provides information about how to install, configure, test, and begin using a USRP, USRP RIO, or USRP Stand-Alone device. System RequirementsNI-USRP 2023 Q3 has the following requirements: - Processor—1 GHz or 64-bit (x64) processor
- RAM— 2 GB RAM (64-bit)
- Windows 10 with all available critical updates and service packs
- Connector requirements shown in the following table
Device | USB 2.0 or Higher | Gigabit Ethernet | PCI/MXI Express | | USRP-2900/2901 | √ | | | | USRP-2920/2921/2922 | | √ | | | USRP-2930/2932 | | √ | | | USRP-2940/2942/2943/2944/2945 | | √ | √1 | | USRP-2950/2952/2953/2954/2955 | | √ | √1 | | Ettus USRP X410 | | √ | √2 | 1 Recommended PCIe Gen1 x4 Interfaces: PCIe-8371 or PXIe-83742 Recommended PCIe Gen3 x8 Interfaces: PCIe-8398 or PXIe-8394Refer to the LabVIEW Readme for additional system requirements and supported operating systems for your version of LabVIEW. Ethernet Support on USRP-294x/295x DevicesNI USRP-294x/295x devices support both 1G Ethernet (1 GbE) and 10G Ethernet (10 GbE) using the connectors on the device back panel. With the default FPGA image, port 0 is designated for 1G, and port 1 is designated for 10G. Users programming with LabVIEW can use Ethernet. Note The FPGA cannot be modified when the 294x/295x device is connected through Ethernet. Ethernet Support on Ettus USRP X410 DeviceEthernet Support for the Ettus USRP X410 device depends on the utilized FPGA image. Supported Operating SystemsNI-USRP 2023 Q3 supports the following operating systems: - Windows 11
- Windows 10
- Windows Server 2022
- Windows Server 2019
- Windows Server 2016
Note NI-USRP no longer supports any 32-bit Windows operating system. Refer to Unsupported Windows Operating Systems for more information about support for Microsoft Windows OSes. Application Software SupportNI-USRP 2023 Q3 supports the following application software versions, including service packs. If you are using LabVIEW, you should install it before installing NI-USRP. Device | LabVIEW 2020 and later | NI Linux RT | | USRP-2900/2901 | √ | | | USRP-2920/2921/2922 | √ | | | USRP-2930/2932 | √ | | | USRP-2940/2942/2943/2944 | √ | √✝ | | USRP-2950/2952/2953/2954 | √ | √✝ | | USRP-2945/2955 | √ | | | Ettus USRP X410 | √ | √ |
This product no longer supports LabVIEW NXG. Refer to LabVIEW NXG on ni.com for more information about LabVIEW NXG Life-Cycle Dates and driver version support. ✝USRP-2940/2942/2943/2944 and USRP-2950/2952/2953/2954 are only supported using the USRP RIO interfaceInstallation InstructionsDownload the NI-USRP installer from ni.com/downloads. NI software includes NI Package Manager to handle the installation. Refer to the NI Package Manager Documentation for more information about installing, removing, and upgrading NI software using Package Manager. After installing your software, you will need to activate it. Activating your software verifies the licenses associated with your NI account, so you can start using your software. You have different options for activation, based on your software and how it was purchased. Please visit ni.com/activate for more information on activation methods. If Windows Update is enabled, the installation process might hang if Windows Update interferes with the installation of Microsoft Visual C++ 2015 Run-Time. Visit ni.com/r/exjq43 for more information and steps to resolve this issue. Updated LabVIEW Compatibility PolicyWhen installing NI-USRP, the "NI-USRP Support for LabVIEW" package will be recommended if you have already installed LabVIEW 2023 Q1 or later. It installs to the LVAddons directory. This package supports applications using NI-USRP with LabVIEW 2023 Q1 or later. LVAddons directory location: C:\Program Files\NI\LVAddons Product Security and Critical UpdatesVisit ni.com/security to view and subscribe to receive security notifications about NI products. For information about critical updates from NI, refer to Available Critical and Security Updates for NI Software. New FeaturesNI-USRP 2023 Q3 includes the following new features: - Support for LabVIEW 2023 Q1
NI-USRP 2022 Q4 includes the following new features: - Support for NI-USRP API GPIO configuration for NI Ettus USRP X410
- Support for LabVIEW 2022 Q3
NI-USRP 21.0 includes the following new features: - Support for Ettus USRP X410 for use with LabVIEW 2021 and LabVIEW 2020
- Support for LabVIEW 2021
NI-USRP 20.5 adds performance and architectural enhancements. Supported HardwareThe following hardware products are supported in all operating systems listed in the Supported Operating Systems section. Refer to the Application Software Support section for information regarding supported application software versions. - USRP-2900
- USRP-2901
- USRP-2920
- USRP-2921
- USRP-2922
- USRP-2930
- USRP-2932
- USRP-2940 40 MHz
- USRP-2940 120 MHz
- USRP-2942 40 MHz
- USRP-2942 120 MHz
- USRP-2943 40 MHz
- USRP-2943 120 MHz
- USRP-2944
- USRP-2945
- USRP-2950 40 MHz
- USRP-2950 120 MHz
- USRP-2952 40 MHz
- USRP-2952 120 MHz
- USRP-2953 40 MHz
- USRP-2953 120 MHz
- USRP-2954
- USRP-2955
- Ettus Research USRP2*
- Ettus Research N200*
- Ettus Research N210*
- Ettus Research X300*
- Ettus Research X310*
- Ettus USRP X410
*The NI-USRP instrument driver supports TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450 daughterboards. Other daughterboards may also be compatible, but they have not been tested. Device-specific information about these modules is included in the NI-USRP Help. Behavior ChangesThe following are the behavior changes in NI-USRP 2022 Q4 from NI-USRP 22.8: - Added a simplified NI Ettus USRP X410 reference project showing faster FPGA-RIO streaming.
The following are the behavior changes in NI-USRP 21.0 from NI-USRP 20.5: - Dropped support for LabVIEW NXG 5.0 and LabVIEW Communications System Design Suite 5.0.
The following are the behavior changes in NI-USRP 18.5 from NI-USRP 18.0: - The SDR Basic Elements IDL is obsolete in instrument driver version 18.5.
Accessing the DocumentationDocumentation for NI-USRP is located at Start»National Instruments»NI-USRP»Documentation and online at ni.com/manuals. The documentation set is composed of the following documents. Document | Format | Location | Description | | NI-USRP Help | HTML/Windows Help | Start»National Instruments»NI-USRP»NI-USRP Documentation and online at ni.com/manuals | The primary document for most USRP products used in LabVIEW. The help is an installed and online version of a traditional user manual that includes the following information:- An introduction to USRP
- How to get started with application development
- A complete programming reference for all NI-USRP programming functions and VIs in LabVIEW
| | NI-USRP Manual | Online Help | Online at ni.com/manuals | The primary document for most USRP products. The help is an installed and online version of a traditional user manual that includes the following information:- An introduction to USRP
| | Getting started guide for your device | Printed and PDF | Online at ni.com/manuals | Contains software and hardware installation, configuration, signal connection, and troubleshooting information for your device. | | Specifications for your device | PDF | Online at ni.com/manuals | Lists technical specifications for your device. | | Manual for your device | Online Help | Online at ni.com/manuals | Contains information about supported hardware, including pinouts, block diagrams, and specifications. |
For the most recent revisions of documentation and for newly released documentation, visit ni.com/manuals. Note To view PDFs, you need to have Adobe Acrobat Reader installed. You can install the viewer from www.adobe.com/reader. Finding Examples, Lessons, and Sample ProjectsNI-USRP examples, lessons, and sample projects are available in the following locations. Content Type | Description | LabVIEW | | Examples | NI-USRP includes several example applications that serve as interactive tools, programming models, and building blocks in your own applications. NI-USRP includes examples for getting started and other software-defined radio (SDR) functionality.
Note You can access additional examples from the Code Sharing Community at ni.com/usrp. | - From the Start menu at Start»National Instruments»NI-USRP»Examples.
- From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
| | Lessons | NI-USRP includes lessons that guide you through the process of identifying and demodulating an FM signal with your device. | N/A | | Sample Projects | USRP RIO includes several sample projects that serve as starting points to build a USRP RIO streaming application. | From the Create Project dialog, select Sample Projects in the left pane and navigate to the NI-USRP Simple Streaming project. | | Ettus USRP X410 Reference FPGA Project | NI-USRP includes a LV FPGA reference project that generates default bitfiles designed for the Ettus USRP X410. The reference project also serves as a starting point to customize the FPGA of the Ettus USRP X410. | For detailed information on the Ettus USRP X410 Reference Project, visit ni.com/r/x410refproj. | Automating the Installation of NI ProductsYou can automate the installation of most NI products using command-line arguments to suppress some or all of the installer user interface and dialog boxes. If the NI product you are installing uses Microsoft .NET 4.6.2, the .NET installer may run before any NI software installs and may require a reboot before the installation of NI software begins. To avoid a .NET reboot, install .NET 4.6.2 separately before you install NI software. For more information about automating the installation of NI products, refer to Automating an Installer in the NI Package Manager manual. Using NI Software with Microsoft Windows 11Microsoft Windows 11 is the latest version of the Windows operating system and features significant changes compared to previous versions. For more information about NI support for Windows 11, refer to NI Product Compatibility for Microsoft Windows 11. Legal InformationCopyright ©2011–2023 National Instruments Corporation. All rights reserved. Under the copyright laws, this publication may not be reproduced or transmitted in any form, electronic or mechanical, including photocopying, recording, storing in an information retrieval system, or translating, in whole or in part, without the prior written consent of National Instruments Corporation. NI respects the intellectual property of others, and we ask our users to do the same. NI software is protected by copyright and other intellectual property laws. Where NI software may be used to reproduce software or other materials belonging to others, you may use NI software only to reproduce materials that you may reproduce in accordance with the terms of any applicable license or other legal restriction. End-User License Agreements and Third-Party Legal Notices You can find end-user license agreements (EULAs) and third-party legal notices in the following locations after installation: - Notices are located in the \_Legal Information and directories.
U.S. Government Restricted Rights If you are an agency, department, or other entity of the United States Government ("Government"), the use, duplication, reproduction, release, modification, disclosure or transfer of the technical data included in this manual is governed by the Restricted Rights provisions under Federal Acquisition Regulation 52.227-14 for civilian agencies and Defense Federal Acquisition Regulation Supplement Section 252.227-7014 and 252.227-7015 for military agencies. IVI Foundation Copyright Notice Content from the IVI specifications reproduced with permission from the IVI Foundation. The IVI Foundation and its member companies make no warranty of any kind with regard to this material, including, but not limited to, the implied warranties of merchantability and fitness for a particular purpose. The IVI Foundation and its member companies shall not be liable for errors contained herein or for incidental or consequential damages in connection with the furnishing, performance, or use of this material. Trademarks Refer to the NI Trademarks and Logo Guidelines at ni.com/trademarks for information on NI trademarks. Other product and company names mentioned herein are trademarks or trade names of their respective companies. Patents For patents covering the NI products/technology, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your media, or the NI Patent Notice at ni.com/patents. |
