查看: 3916|回复: 0
[远心镜头] 石鑫华视觉供应远心镜头VST VS-TC1-300CO
  • 签到天数: 128 天
    发表于 2014-7-14 17:41:51 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    VST VS-TC系列远心镜头
    VS-TC系列远心镜头
    Compact size and light weight
    紧凑的尺寸与较轻重量
    Wide range of WD from 40mm~340mm
    宽范围的工作距离,从40mm到340mm
    Variety of magnifications 0.5x~10x : 1.5x / 3.0x / 5.0x also available
    多种多样的放大倍率,0.5X~10X之间,1.5X、3X、5X也可以有
    Built-in Co-axial models ( model number : VS-TC□□-□□CO )
    同置同轴型号(型号名为:VS-TC□□-□□CO),CO表示同轴照明型号
    Optical mirror units available
    光学镜像配件可选
    Telecentric lens has parallel chief ray with its optical axis and is ideal for co-axial lighting. Telecentric lenses eliminate
    perspective errors in your image and do not change magnification when the WD changed. This allows accurate measurement of 3D
    objects or even objects that move up and down.
    远心镜头拥有与它的光轴平行的主光线,同轴照明是非常理想的。远心镜头可以消除图像中的透视错误(视角错误),并且可以不改变放大倍率当
    工作距离改变时。这样就允许精度测量3D对象甚至是上下移动的对象。
    常规镜头与远心镜头原理与成像效果
    Conventional lens:常规镜头
    Sensor-side telecentric lens:像方远心镜头
    Object-side telecentric lens:物方远心镜头
    Both-sides telecentric lens:双侧远心镜头
    石鑫华视觉网的镜头购买请看http://visionbbs.com
    GMT+8, 2026-2-26 15:51
