查看: 7090|回复: 0
[LV工具模块] LabVIEW Report GenerationToolkit for Microsoft Office 2014 LV报表工具包RGT2014
    4 小时前
  • 签到天数: 3733 天
    连续签到: 60 天
    发表于 2014-8-11 22:05:12 | 显示全部楼层 |阅读模式 来自:广东省东莞市 移动
    LabVIEW Report Generation Toolkit for Microsoft Office 2014 for LabVIEW 2014 报表工具包RGT2014适用LabVIEW2014
    RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
    The LabVIEW Report Generation Toolkit for Microsoft Office provides VIs you can use to create and edit reports in Microsoft Word and Microsoft Excel formats. You can use the Report Generation VIs to perform the following tasks:
    Create and edit Word documents and Excel worksheets.
    Use Word and Excel templates to create reports with a consistent style.
    Insert, format, and edit text, tables, images, and graphs within Word documents and Excel worksheets.
    Run Microsoft Visual Basic for Applications macros from Word documents and Excel worksheets.
    In addition to the system requirements for the LabVIEW Development System, the Report Generation Toolkit for Microsoft Office has the following requirements:
    Windows 7 (32-bit and 64-bit)
    Windows Vista (32-bit and 64-bit)
    Windows XP Service Pack 3 or later (32-bit)
    Windows 8.1 (32-bit and 64-bit)
    LabVIEW 2014 Base, Full, or Professional Development System (32-bit)
    At least 40 MB of disk space
    Microsoft Office 2010/2007/2003/XP
    Note:  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
    请注册视觉论坛用户,登录后购买附件下载查看
    RGT2014.txt (794 Bytes, 下载次数: 80, 售价: 10 圆)
    LabVIEW 2014 Report Generation Toolkit for Microsoft Office Readme
    2014
    Version 14.0.0
    July 2014
    This file contains important information about the Report Generation Toolkit for Microsoft Office, including installation instructions, new features, a partial list of bugs fixed for LabVIEW 2014 Report Generation Toolkit for Microsoft Office, and known issues.
    • Create and edit Word documents and Excel worksheets.
    • Use Word and Excel templates to create reports with a consistent style.
    • Insert, format, and edit text, tables, images, and graphs within Word documents and Excel worksheets.
    • Run Microsoft Visual Basic for Applications macros from Word documents and Excel worksheets.
    • Windows XP Service Pack 3 or later (32-bit)
    • LabVIEW 2014 Base, Full, or Professional Development System (32-bit)
    • At least 40 MB of disk space
    • Microsoft Office 2010/2007/2003/XP
    Refer to the LabVIEW Readme for additional system requirements and supported operating systems for LabVIEW 2014.
    You can install all of your LabVIEW products—including the Report Generation Toolkit for Microsoft Office—using the LabVIEW 2014 Platform media. Refer to the LabVIEW Installation Guide on the LabVIEW Platform media for installation instructions and system requirements.
    Report Generation Toolkit for Microsoft Office Updates and Notifications
    The following items are the IDs and titles of a subset of issues fixed in the Report Generation Toolkit for Microsoft Office. This is not an exhaustive list of issues fixed in the current version of the Report Generation Toolkit for Microsoft Office. If you have a CAR ID, you can search this list to validate the issue has been fixed.
    380769Appending a one row table to a Word report causes an exception.
    Refer to the LabVIEW Help, accessible by selecting Help»LabVIEW Help from LabVIEW, for information about the Report Generation Toolkit for Microsoft Office.
    Select Help»Find Examples from LabVIEW to launch the NI Example Finder. LabVIEW examples for the Report Generation Toolkit for Microsoft Office are located in the labview\examples\office directory. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    Using NI Launcher
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8. You can launch MAX either from the Start screen or from within NI Launcher. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI LabVIEW 2014 Report Generation Toolkit for Microsoft Office Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    National Instruments LabVIEW 2014 Report Generation Toolkit for Microsoft Office will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of National Instruments LabVIEW 2014 Report Generation Toolkit for Microsoft Office that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2009–2014 National Instruments. All rights reserved.
    GMT+8, 2025-12-5 13:03
