查看: 13038|回复: 0
[驱动] AVT VIMBA 1.2.x - The SDK for AVT cameras德国AVT工业相机驱动和二次开发包
    昨天 07:57
  • 签到天数: 3837 天
    连续签到: 30 天
    发表于 2014-8-11 22:41:59 | 显示全部楼层 |阅读模式 来自:广东省茂名市 联通
    AVT VIMBA - The SDK for AVT cameras德国AVT工业相机驱动和二次开发包
    VIMBA is AVT's future-proof SDK for all current AVT cameras with GigE Vision and FireWire (IEEE 1394) interface.
    Highlights:
    VIMBA uses the GenICam transport layer (GenTL) standard.
    To interface third-party software, VIMBA contains GenTL compliant transport layer producers for IEEE 1394 (only for Windows) and GigE Vision.
    VIMBA allows access on several API levels:
    The C API allows an easy migration from older SDKs.
    The C++ API is distributed as source code.
    On Windows, VIMBA also provides a .NET API.
    From version 1.2.0 onwards, VIMBA includes a Cognex adapter (for Cognex 6.0 or later).
    VIMBA is operating system independent. It allows application porting.
    VIMBA includes a viewer application.
    Operating systems:
    Windows XP (only 32-bit)*, Windows 7 (32-bit and 64-bit), Windows 8 (32-bit and 64-bit)*
    Linux is supported on standard PC systems based on Intel-compatible 32-bit and 64-bit processors. Currently, only the GigE Vision transport layer is available. Tested distributions:
    Fedora 17
    Debian 6.0.7
    Ubuntu 12.4
    Support for QNX and OS X is planned. AVT's PvAPI (only for GigE cameras) has been ported to QNX and OS X and can be used to integrate AVT's GigE Vision cameras. AVT ensures product maintenance for PvAPI until 2016.
    On request:
    On customer request and with verified commercial potential, AVT offers porting VIMBA to other real time operating systems, for example, VxWorks. In such cases, all tasks are carried out on a project basis, given that the customer has to provide:
    A hardware target (if required)
    All needed software and licenses
    A well-prepared tool chain, and
    Other necessary accessories for the development.
    Supported cameras:
    AVT 1394 cameras (only Windows)
    AVT GigE Vision cameras
    VIMBA will support future USB3 Vision cameras
    Windows版驱动与二次开发包1.2.1:
    http://pan.baidu.com/s/1dDIOUcx
    Linux版驱动与二次开发包1.2:
    http://pan.baidu.com/s/1gd25Mbp
    GMT+8, 2026-3-27 06:08
