查看: 6879|回复: 8
[LV工具模块] NI LabVIEW Internet Toolkit 2009 Win32Eng LabVIEW2009网络工具包下载
    前天 16:03
    发表于 2013-3-7 20:03:37 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    Internet工具包可用于将internet功能整合至VI,实现基于Telnet协议的数据收发、从FTP服务器上传或下载文件、向Web发布VI、以及通过Web浏览器对VI进行远程控制。
    文件大小: 38299815 字节 (36.53 MB)
    修改日期: 2019-12-19 18:01
    MD5: 3add4fa23d9a46a97a6173c66bd7bca4
    SHA1: 9d846a51d7389bbcc87e5b53c2410ace10830946
    SHA256: 21442383421bca6ce2f8a0c2f360a47fe5e26866f1e8ac72bf4ac3469031a1eb
    CRC32: 621bac48
    百度和NI官方下载地址:
    Internet2009.txt (178 Bytes, 下载次数: 1, 售价: 10 圆)
    LabVIEW 2009 Internet Toolkit Readme
    June 2009
    This file contains the following information about the LabVIEW 2009 Internet Toolkit.
    Installation
       Version 2009 for Windows
       Version 6.0.2 for LabVIEW 8.6 or later
            Mac OS X
            Linux
    InstallationVersion 2009 for Windows
    You can install all of your LabVIEW products—including the Internet Toolkit—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the Internet Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    Version 6.0.2 for LabVIEW 8.6 or later for Mac OS X and Linux
    Internet Toolkit 6.0.2 is compatible with LabVIEW 8.6. If you want to use Internet Toolkit with an older version of LabVIEW, you must install Internet Toolkit 6.0.1.
    Before installing the LabVIEW Internet Toolkit 6.0.2, uninstall any previous versions of the Internet Toolkit from the computer.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    (Mac OS X) If a previous version of the LabVIEW Internet Toolkit exists on the machine, complete the following steps to uninstall the previous version before you install Internet Toolkit 6.0.2.
    • Navigate to the LabVIEW directory and drag the Internet_Toolkit_Uninstall.sh uninstallation script to the prompt in a Terminal Window. Press Return and follow the instructions provided by the script.
    • After uninstalling the Internet Toolkit, you must manually delete the uninstallation script.
    Complete the following steps to install the LabVIEW Internet Toolkit 6.0.2 for Mac OS X from the Internet Toolkit installation CD.
    • Insert and browse to the LabVIEW Internet Toolkit 6.0.2 installation CD and open Internet_Toolkit6.0.2.pkg located under the LabVIEW_8.6\Mac OS X directory.
    • Select Continue to run a program to determine if the Internet Toolkit can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Select Destination dialog box.
    • In the Select Destination dialog box, click the Choose button and select the version of LabVIEW (8.6 or later) to which you want to install the Internet Toolkit.
    Note  You must click the Choose button for a proper installation. If you do not select a location where LabVIEW is installed or you select a non-compatible version of LabVIEW, the installation will not complete.
    • After you select the destination directory, click the Continue button to complete the installation.
    • (Optional) Mass compile the Internet Toolkit VIs. When you open a VI last saved in a previous version of LabVIEW, LabVIEW automatically converts and compiles the VI. You must save the VI in the current version of LabVIEW or the conversion process, which uses extra memory resources, occurs every time you access the VI. Because the Internet Toolkit supports multiple versions of LabVIEW, you might need to mass compile after you install.
      • Launch LabVIEW and select Tools»Advanced»Mass Compile to display the Mass Compile dialog box.
      • Navigate to the labview\vi.lib\addons\internet directory and click the Mass Compile button to mass compile the Internet Toolkit VIs.
    (Linux) Complete the following steps to install the Internet Toolkit 6.0.2 for Linux from the Internet Toolkit installation CD.
    • Use mount /mnt/cdrom to mount the CD. On some systems, the CD is mounted automatically.
    • Enter the following command to navigate to the LabVIEW directory:
      cd /usr/local/natinst/labview
      where labview is the version of LabVIEW to which you are installing the Internet Toolkit, such as lv86.
    • Enter the following command to extract the toolkit to the LabVIEW folder:
      tar xf /mnt/cdrom/Linux/InternetToolkitLinux.tar
    • Enter the following command to navigate to the Example Finder directory:
      cd /usr/local/natinst/share/example finder/1.0/Products/labview/x.y/exbins/english
      where x.y is the version of LabVIEW to which you are installing the Internet Toolkit, such as 2009.
    • Enter the following command to copy the toolkit example information to the Example Finder:
      cp /mnt/cdrom/Linux/lvexint.bin4 .
    The Internet Toolkit VIs Help contains reference information about the Internet Toolkit.
    (Windows) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Search the LabVIEW Help to launch the LabVIEW Help.
    • Click the Contents tab.
    • Navigate to the Toolkits»Internet Toolkit VIs top-level topic.
    (Mac OS X, Linux) Complete the following steps to access this help file.
    • Launch LabVIEW.
    • Select Help»Internet Toolkit to launch the Internet Toolkit VIs Help.
    Refer to the labview\examples\internet directory for example VIs that demonstrate common tasks using the Internet Toolkit. You also can access these VIs by selecting Help»Find Examples from the pull-down menu and selecting Toolkits and Modules»Internet in the NI Example Finder window. You can modify an example VI to fit an application, or you can copy and paste from one or more examples into a VI that you create.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 Internet Toolkit.
    IDLegacy IDFixed Issue
    422154EHH16RJHang in FTP Command.vi if the FTP server is shut down at the wrong time
    451194HRBQ51GFTP Write can hang when an error occurs
    141203-Transferring files in ASCII mode from LabVIEW adds extra lines
    © 1999–2009 National Instruments Corporation. All rights reserved.
    发表于 2013-4-8 15:11:09 | 显示全部楼层 来自:北京市 联通
    发表于 2013-4-8 15:27:23 | 显示全部楼层 来自:北京市 联通
    楼主,真神人啊!爱死你了,正是所需要的东西,找了一个多月了。
    点评
    呵呵。俺这里有一些珍藏的。  发表于 2013-4-8 17:34
    发表于 2013-4-24 08:58:58 | 显示全部楼层 来自:广西 移动数据上网公共出口
  • 签到天数: 30 天
    发表于 2014-4-23 19:05:25 | 显示全部楼层 来自:浙江省杭州市 浙江科技学院
  • 签到天数: 30 天
    发表于 2014-4-23 19:05:29 | 显示全部楼层 来自:浙江省杭州市 浙江科技学院
    发表于 2014-12-19 09:52:28 | 显示全部楼层 来自:浙江省杭州市 电信
  • 签到天数: 7 天
    发表于 2015-1-18 10:53:38 | 显示全部楼层 来自:北京市大兴区 联通
  • 签到天数: 7 天
    发表于 2015-1-18 10:53:42 | 显示全部楼层 来自:北京市大兴区 联通
    GMT+8, 2026-2-25 03:03
