查看: 6363|回复: 0
[Patch补丁] LabVIEW 2012 f1 Patch Win32多国语言 LV2012f1补丁-32位版
    发表于 2012-11-24 16:17:07 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    问题:
    LabVIEW 2012 f1补丁程序中修正了哪些问题?
    解答:
    LabVIEW 2012 f1补丁可以作为LabVIEW 2012开发环境和LabVIEW 2012运行引擎的组合补丁,也可以作为LabVIEW 2012运行引擎的独立发布。
    该补丁修复了几个重要问题,强烈建议在每次安装LabVIEW 2012之后安装该补丁。可通过更新服务或下面的驱动与更新链接查找该补丁。
    LabVIEW 2012 f1解决的问题
    ID说明
    356459Crash in DrawPlot when trying to display 42984 points on an XY Graph.
    363464Plots with reversed X axis display extraneous horizontal line.
    362018Crash when loading some VIs, saved in a previous version of LabVIEW, into LabVIEW 2012.
    362925Crash when dragging instance of Polymorphic VI from dialog to block diagram.
    361951 & 362316LabVIEW doesn't use Service Locator to identify Web Server configuration page port.
    360556Rare issue where an application may build successfully, but actually be broken.
    362366Packed Project Library deployment fails on Real-Time targets.
    361666Issue where the Actor Framework Message Maker utility isn't installed with LabVIEW for Linux.
    364076Some Project Template documentation for LabVIEW Chinese (Simplified) incorrectly links to English online resources.
    LV2012_f1patch32.txt (267 Bytes, 下载次数: 0, 售价: 1 圆)
    GMT+8, 2025-12-8 07:59
