TA的每日心情 | 擦汗 昨天 16:03 |
NI Vision Builder for Automated Inspection 2009 Win32Eng 自动化检测视觉生成器VBAI2009 LV2009
NI Vision Builder for AI 2009,VBAI2009,石鑫华视觉珍藏版。自动化检测视觉生成器是一款NI出品的不需要编程的标准图像处理软件,只需要工程师拖拉功能模块设置参数就可以完成检测功能,还可以做机种配方管理。
NI Vision Builder for Automated Inspection 2009 VBAI2009(2009.8.1):
ZIP版:
ISO版:
EXE版:
请注册视觉论坛会员登录后购买附件下载查看
NI官方下载地址(不一定有效或无法完成下载):
请购买附件下载查看
VBAI2009.txt
(411 Bytes, 下载次数: 48, 售价: 100 圆)
NI Vision Builder for Automated Inspection 2009 Readme
August 2009
This file contains important information about National Instruments Vision Builder for Automated Inspection (Vision Builder AI) software and is organized into the following sections:
Activation Instructions
Device Support
Additional Resources
To configure inspections using Vision Builder AI, the host machine must meet the following requirements:
| | Minimum | Recommended | | Processor | Pentium 4/M or equivalent | Core Duo or equivalent | | Memory | 512 MB RAM | 1 GB RAM | | Display | 1,024×768 resolution video adapter with a 24- or 32-bit display | 1,280×1024 resolution video adapter with a 24- or 32-bit display | | Operating System | Microsoft Windows Vista/XP/2000 | | Browser | Microsoft Internet Explorer 5.0 or later | | Hard Disk Space | 700 MB | Note: If you are using Vision Builder AI on a Windows XP system with Service Pack 2 installed, refer to Known Issues for information about how Service Pack 2 affects Vision Builder AI.
Complete the following steps to install Vision Builder AI:
Note: You must be logged in with administrator privileges to install Vision Builder AI.
- Insert the Vision Builder AI DVD into your DVD-ROM drive. If the DVD does not run automatically, open Windows Explorer, right-click the DVD drive icon, and select AutoPlay.
- Select Install Vision Builder for Automated Inspection on the National Instruments Vision Builder for Automated Inspection screen.
- Vision Builder AI prompts you to enter your user information. Select one of the following options:
- Install this product using the following serial number
- Install this product for evaluation
If you choose to enter a serial number, enter the serial number found on your Certificate of Ownership card. Vision Builder AI automatically uses this serial number when you run the NI Activation Wizard. - Continue to follow the instructions on the screen.
If you did not activate Vision Builder AI during the installation process, when you run a Vision Builder AI application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, Vision Builder AI runs in Evaluation mode and continues to prompt you to activate a license on each subsequent launch.
The evaluation period is 30 days. At the end of the evaluation period you must activate a Vision Builder AI license to continue using the product.
Note: While Vision Builder AI is in Evaluation mode, all features are available except Migrate Inspection to LabVIEW.
Vision Builder AI offers the following licensing options:
- Vision Builder AI Full-Featured (778649-01)—Allows full access to all Vision Builder AI features, which can be used to configure, benchmark, and deploy inspections. This license does not include the Vision Builder AI Development Toolkit.
- Vision Builder AI Run-Time (779799-03)—Allows you to deploy existing inspections to a host machine and modify the control values for steps in an inspection. This license does not allow you to add steps to or remove steps from an inspection.
- Vision Builder AI Development Toolkit (779343-03)—Licenses only the Vision Builder AI Development Toolkit, which allows you to create custom steps for use in any Vision Builder AI application.
Complete the following steps to activate the Vision Builder AI license:
- Launch Vision Builder AI.
- Click Yes when prompted to activate Vision Builder AI.
- Ensure that Automatically activate through a secure Internet connection is selected, and click Next.
- Enter your serial number, and click Next.
- Enter your registration information, and click Next.
- You can enter an email address to receive a copy of the activation code for your records.
Deployment Policy for Vision Builder AI
Pursuant to the National Instruments Software License Agreement, Vision Builder AI software is licensed to run on only one machine. Deployed applications that use Vision Builder AI require that Vision Builder AI be installed and licensed on each host machine. Therefore, you must purchase a separate Vision Builder AI license for each host machine. For more information, refer to the enclosed National Instruments Software License Agreement or visit ni.com/legal/license.
The following list describes the changes and enhancements in this release of Vision Builder AI:
- New Geometric Matching step—The geometric pattern matching step has been optimized to use an edge-based pattern matching algorithm which is more robust than the previous version. For backwards compatibility, the step includes the option to use the previous algorithm.
- New Color Classification step—The Color Classification step can identify a color for a region of interest based on a learned set of colors.
- New EtherNet/IP Adapter step—Vision Builder AI 2009 can function as a Class 1 adapter device in accordance with the EtherNet/IP standard, and supports I/O server communication. PLCs can establish implicit I/O data connection with Vision Builder AI 2009, and exchange assembly data at a specific rate.
- New particle filter for Detect Objects step—The Detect Objects step can now use more than 80 particle criteria to filter out or to select objects, producing a more robust inspection.
- New Model Vision System Variation tool—Vision system variation modeling allows you to test the robustness of an inspection. Vision Builder AI 2009 creates variations of sample images that you specify to simulate conditions that might occur in an inspection environment, such as lighting changes, motion blur, or changes in camera position.
- New ability to import steps and states—Vision Builder AI 2009 can import inspections saved on the system into other inspection state diagrams, which allows you to create reusable steps or states.
- New support for DirectShow-compatible USB cameras—The Acquire Image (1394, GigE, or USB) step supports DirectShow-compatible USB cameras on Windows.
- New keyboard shortcuts for commonly used menu items
- Improved View Measurements tool—The View Measurements tool now supports drag and drop, allows you to edit result values or variables, and provides statistical data for numeric results.
- Improved spatial calibration support—Image acquisition steps now include a Calibration tab with settings for creating or selecting a calibration. The Calibrate Image step settings have been optimized to allow you to adjust calibration values without editing the calibration file. Calibration files for specific cameras are saved on the system, and can be used in multiple inspections.
- Improved color image support—The following steps now support color images:
- Threshold Image
- Find Edges
- Find Straight Edge
- Find Circular Edge
| - Detect Objects
- Adv. Straight Edge
- Count Pixels
- Read/Verify Text
| - Classify Objects
- Read 1D Barcode
- Read Data Matrix Code
- Read QR Code
| Updates
The following list describes issues in previous versions of Vision Builder AI that are fixed in this release.
| ID | Fixed Issue | | 122375 | Migrating an inspection to LabVIEW takes longer than expected. | | 127573 | Zoom to Fit is disabled for Custom Inspection Interface templates. | | 129425 | When importing multiple custom steps from Vision Builder AI 3.5, Vision Builder 3.6 always opens the properties page for the same step. | | 130743 | Find Edges steps do not correctly update the image if a Find Edges step fails. | | 132691 | The Vision Builder AI main window undocks. | | 134637 | The Vision Builder AI inspection interface might not update properly when reconnecting to a smart camera running an inspection. | | 135107 | Copying and deleting states in very large inspections might delete inspection steps in other states. | | 138870 | After deleting a Set Inspection Status step from an inspection, the image remains and cannot be used. | | 139987 | The TCP I/O step returns a PASS result when a measurement is not available. | | 144332 | If an inspection includes a Simulate Acquisition step, the Image Logging step deletes the image source file if Simulate Acquisition - Current Image Name is selected as the File Name. | | 145104 | LabVIEW code generated for smart camera inspections cannot run after being deployed to a smart camera. | | 147998 | After saving a custom step for distribution, the resulting custom step plugin may not run. | | 148621 | Vision Builder AI crashes when opening a Vision Assistant script. | | 150924 | The Vision Assistant step returns an error when trying to rotate a region of interest in a color image. | | 150937 | Selecting the Hide All option in the Setup Overlays dialog box does not hide the Read 1D Barcode ROI overlay. | | 155378 | The Adv. Straight Edge step may crash if the ROI is partially outside of the image. | | 155719 | The Error List dialog box lists no errors when the Calculator diagram is broken. | | 156643 | After editing the Custom Overlay step, if the step uses previous measurements that are not available, the step settings are corrupted. | | 156648 | After closing Vision Builder AI, Vision Builder AI processes may continue to run. | | 156650 | Formula node syntax and functions are not documented in the Vision Builder for Automated Inspection: Configuration Interface Help. | | 157697 | When Vision Builder AI is in inspection mode, the image displayed on the host may not correspond with the inspection result if the Display Image step and the Set Inspection Status step are in different states of the inspection. | | 161522 | A new inspection variable does not appear in the Index List of the Index Measurements step until the inspection is saved. | | 162380 | The image displayed while editing the Acquire Image (1394, GigE, USB) step uses 16-bit image display mapping options that are different from those specified in the Options dialog. | | 162500 | The ActiveX interface limits the number of measurements returned to approximately 32 results. | | 162863 | Deleting a state deletes all transitions leading to the state. | | 163839 | If the inspection uses a Serial I/O step, switching from the inspection interface to the configuration interface may hang the smart camera. | | 170053 | In the inspection interface, stopping and restarting an inspection starts the inspection from the point at which it was stopped instead of the beginning of the inspection. | | 170293 | The region of interest logged for a Vision Assistant step might be incorrect if the step is configured to process the entire image. | | 174957 | The remote target serial communication baud rate changes when the host connects to a remote target running an inspection. | | 177142 | If a Set Inspection Status step is configured to use a result from a specific step result and that step is deleted, the Set Inspection Status step may indicate an incorrect Fail result. | Device Support
Vision Builder AI supports various image acquisition devices, NI 17xx Smart Cameras, the NI CVS-1450 Series Compact Vision System, the NI EVS-1460 Series Embedded Vision System, NI digital I/O and data acquisition (DAQ) devices, IEEE 1394 industrial digital cameras, GigE Vision cameras, DirectShow-compatible USB cameras, and serial devices.
Image Acquisition Devices
This version of Vision Builder AI supports the following National Instruments image acquisition devices:
- NI PCI-1405
- NI PXI/PCI-1407
- NI PXI/PCI-1409
- NI PXI/PCI-1410
| - NI PXI/PCI-1411
- NI PXI/PCI-1422
- NI PCI-1424
- NI PCI-1426
| - NI PCIe-1427
- NI PXI/PCI-1428
- NI PCIe-1429
- NI PCIe-1430
| Note: If you are using an image acquisition device, you must install NI Vision Acquisition Software before you install the image acquisition device. NI Vision Acquisition Software gives you access to Measurement & Automation Explorer (MAX), which is software you can use to configure National Instruments devices.
DirectShow-Compatible USB Cameras
Use the Acquire Image (1394, GigE, or USB) step to acquire images from a DirectShow-compatible USB camera that is connected to a Windows system. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
If you are using a USB camera, verify that the camera driver supports DirectShow and that the camera driver is installed correctly. For specific information about drivers and camera compatibility, consult your camera manufacturer documentation.
IEEE 1394 Cameras
This version of Vision Builder AI supports the following National Instruments IEEE 1394 host adapters:
- NI PXI/PCI-8252
- NI PCI-8254R
- NI PCIe-8255R
Use the Acquire Image (1394, GigE, or USB) step to acquire images from an IEEE 1394 camera. The Acquire Image (1394, GigE, or USB) step requires NI-IMAQdx, which can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
You must configure the camera to use the NI-IMAQdx driver. Complete the following steps to use MAX to configure the camera to use the NI-IMAQdx driver.
- Launch MAX.
- In the MAX configuration tree, expand Devices and Interfaces to obtain a list of installed devices.
- Expand NI-IMAQdx Devices to obtain a list of available cameras.
- Right-click the camera and select Driver»NI-IMAQdx IIDC Digital Camera.
National Instruments no longer supports Legacy NI-IMAQ for IEEE 1394 Cameras. Installing NI-IMAQdx from the NI Vision Acquisition Software DVD included with Vision Builder AI uninstalls Legacy NI-IMAQ for IEEE 1394 Cameras. If you have an existing inspection that uses the Acquire Image (IEEE 1394)step or you want to use the Acquire Image (IEEE 1394) step to acquire images from an IEEE 1394 camera connected to the host computer, you must download and install Legacy NI-IMAQ for IEEE 1394 Cameras. Visit ni.com/info and enter the info code legacy1394 for information about how to install Legacy NI-IMAQ for IEEE 1394 Cameras.
You must configure the camera to use the Legacy NI-IMAQ for IEEE 1394 Cameras driver. Complete the following steps to use MAX to configure the camera to use the legacy NI-IMAQ for IEEE 1394 Cameras driver.
- Launch MAX.
- Right-click the camera and select Driver»NI-IMAQ IEEE 1394 IIDC Digital Camera. The camera should appear in the MAX configuration tree under Legacy NI-IMAQ IEEE 1394 Devices.
For additional information about migrating from NI-IMAQ for IEEE 1394 Cameras to NI-IMAQdx, refer to the NI-IMAQdx Readme.
GigE Vision Cameras
This version of Vision Builder AI supports the NI PCIe-8231, NI PCIe-8235, and NI PXIe-8234 Gigabit Ethernet host adapters.
If you want to use GigE Vision-compliant industrial video cameras with Vision Builder AI, you need NI-IMAQdx 3.0 or later driver software. NI-IMAQdx can be installed from the NI Vision Acquisition Software DVD included with Vision Builder AI.
Vision Builder AI supports all NI Smart Cameras, allowing you to remotely configure and control the device.
Vision Builder AI supports the NI CVS-1450 Series Compact Vision System, allowing you to remotely configure and control the device.
Note: To use Vision Builder AI with a NI CVS-1450 device, you must you must use Vision Builder AI to configure the NI CVS-1450 device. For more information, refer to Getting Started with the NI CVS-1450 Series, included with every NI CVS-1450 device.
Vision Builder AI supports the NI EVS-1460 Series Embedded Vision System, allowing you to remotely configure and control the device.
Note: To use Vision Builder AI with a NI EVS-1460 device, you must use Vision Builder AI to configure the NI EVS-1460. For more information, refer to documentation included with the NI EVS-1460 device.
Analog and Digital I/O Devices
This version of Vision Builder AI supports digital and analog I/O from any National Instruments data acquisition (DAQ) device using NI-DAQmx Global Channels. To support NI DAQ devices, Vision Builder AI requires NI-DAQmx 8.0 or later.
Serial Communication
To support serial communication, Vision Builder AI requires NI-VISA 2.6.0 or later, which is included with Vision Builder AI. You can use the serial ports built into the PC or one of the following NI serial interfaces: NI PCI-232/x, NI PXI-8420/x, or NI PXI-8422/x. You do not need to install NI-VISA to use the serial port on a remote target.
National Instruments is aware of the following issues you may encounter while using Vision Builder AI.
General- Vision Builder AI may not display an inspection image if the image is large and your computer is low on available memory.
- To detect a remote target on a system running Windows Vista, the system must have only one network adapter or you must temporarily disable all but one network adapter.
- The Run LabVIEW VI step works only with VIs that have a connector pane that consists of a single unwired terminal. In Vision Builder AI, select Help»Context Help and select the FAQs tab for more information.
Windows XP Service Pack 2- When you choose Select Network Target in Vision Builder AI while the Windows XP Service Pack 2 Internet Connection Firewall is enabled, a dialog box may open, giving you the option to allow Vision Builder AI to receive information over a network. National Instruments recommends that you select Unblock this program so that Vision Builder AI can configure your remote NI CVS-1450 Series device. You must be logged in with administrator privileges to configure this networking option. Visit ni.com/info and enter winxpsp2 for more information.
- "When using the Vision Builder AI ActiveX component while the Windows XP Service Pack 2 Internet Connection Firewall is enabled, a dialog box may open, giving you the option to allow VBAI_Server to receive information over a network. You must select Unblock this program to use the Vision Builder AI ActiveX component. You must be logged in with administrator privileges to configure this networking option.Visit ni.com/info and enter winxpsp2 for more information.
Vision Builder AI Development Toolkit- When using the Vision Builder AI Development Toolkit, you must close all open LabVIEW VIs before attempting to create a new step or importing a step from a previous version of Vision Builder AI.
- When using the Vision Builder AI Development Toolkit, if you import a Vision Builder AI 2.6 step that uses previous measurement results, when the step executes, the array of measurements in the User Interface and User Programming VIs will be empty. Refer to the NI Vision Builder for Automated Inspection Development Toolkit Tutorial for information about using previous measurements in Vision Builder AI 3.0 or later.
Vision Builder AI ActiveX Component- To use the Vision Builder AI ActiveX component from LabVIEW, you must use LabVIEW 8.2 or later.
- Vision Builder AI installs ActiveX examples written in LabVIEW and Visual Basic 6. For examples of how to use the Vision Builder AI ActiveX component with Microsoft Visual Studio 2005 or later, visit ni.com/info and enter the info code vbaiactivex.
- When using the Vision Builder AI ActiveX component, the NIVBAITargetMode setting is not available. Therefore, the connection to a target always allows full control.
- When using the Vision Builder AI ActiveX component, if the connection to a local target fails the first time you try to connect to the local target, restart the computer and retry the connection.
Additional ResourcesHow do I get started?
Read the NI Vision Builder for Automated Inspection Tutorial, which provides exercises for learning how to perform basic machine vision techniques using Vision Builder AI.
Where can I find reference information?
Reference information for Vision Builder AI is available from within Vision Builder AI by clicking the Show Context Help button, or selecting Start»All Programs»National Instruments»Vision Builder AI»Documentation.
The following documents are provided with Vision Builder AI as online help:
- NI Vision Concepts Help—Contains basic concepts of image analysis, image processing, and machine vision. This document also contains in-depth discussions about imaging functions for advanced users.
- NI Vision Builder for Automated Inspection: Configuration Help—Contains information about the Vision Builder AI Configuration interface, managing inspections and images, and creating steps for an inspection.
- NI Vision Builder for Automated Inspection: Inspection Help—Contains information about using the Vision Builder AI Inspection interface to run inspections.
- NI Vision Builder for Automated Inspection: ActiveX Component Reference Help—Contains information about the ActiveX objects available to embed Vision Builder AI inspections into ActiveX applications.
Use the Search tab in the help files to quickly locate specific information. For information about how to use the search functionality, refer to the Using Help»Searching Help topic in the help file.
The following documents are provides with Vision Builder AI as Adobe PDF documents:
- Vision Builder for Automated Inspection Tutorial—Describes Vision Builder for Automated Inspection and provides step-by-step instructions for solving common visual inspection tasks, such as inspection, gauging, part presence, guidance, and counting.
- NI Vision Builder for Automated Inspection Development Toolkit Tutorial—Contains instructions for using LabVIEW to create custom steps for Vision Builder AI.
Where can I find examples?
Examples of common Vision Builder AI inspections are installed to the \Examples directory, where is the location to which you installed Vision Builder AI.
Where else can I go for Vision Builder AI information?
Visit ni.com/vision and the NI Developer Zone at ni.com/zone for the most up-to-date information about Vision Builder AI.
© 2002–2009 National Instruments Corporation. All rights reserved.
For patents covering the National Instruments products, refer to the appropriate location: Help» Patents in your software, the patents.txt file on your DVD, or ni.com/patents. |
