查看: 7917|回复: 5
[LV工具模块] LabVIEW Report Generation Toolkit for Microsoft Office 2009 LV报表工具包RGT2009
    昨天 16:03
    发表于 2013-3-7 20:41:13 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LabVIEW Report Generation Toolkit for Microsoft Office 2009 for LabVIEW 2009 报表工具包RGT2009适用LabVIEW2009
    RGT报表生成工具包,从LabVIEW2014版开始,有64位版本。在LabVIEW2014-LabVIEW2015版中(含相应的SP1版本),32位的标准安装包中,集成了RGT工具包,但是64位中没有集成该工具包,需要单独下载安装。从LabVIEW2016版开始,则在32位版本、64位版本中,都集成了RGT工具包可选择安装,不需要另外安装。(这里限标准的安装包,即大小一般1-2GB大小的安装文件,各种套件可能不包含RGT的情况。)
    June 2009
    LabVIEW2009-LabVIEW2013SP1版本的RGT工具包,都是单独安装的。从LabVIEW2014版后,在LV中集成RGT工具包,不需要再单独下载安装。
    The computer you are using must meet the following minimum system requirements to run the Report Generation Toolkit:
    Windows Vista/XP/2000
    40 MB of hard drive space
    LabVIEW 2009
    Microsoft Office 2007/2003/XP
    Note  You must have both Microsoft Word and Microsoft Excel installed before installing the Report Generation Toolkit.
    适用于LabVIEW2009
    文件大小: 38741223 字节 (36.95 MB)
    修改日期: 2019-08-07 13:29
    MD5: a1233560a881968c6fe3031ce6f0a7c2
    SHA1: 1cbc601faa2cb4ae3e7fe31ba6dcce944cc8b32f
    SHA256: ab6eb83c67a2d4ec678ac5554fab81d495a973646bbea7719675f8f8f2373da2
    CRC32: ec066f2b
    请购买附件下载
    RGT2009.txt (507 Bytes, 下载次数: 69, 售价: 10 圆)
    LabVIEW 2009 Report Generation Toolkit for Microsoft Office Readme
    June 2009
    This file contains important last-minute information about the LabVIEW 2009 Report Generation Toolkit for Microsoft Office, including installation issues.
    Refer to the National Instruments Web site for the latest information about the Report Generation Toolkit. Refer to the LabVIEW Help for more information about using the Report Generation Toolkit.
    Installation
    Upgrade Issues
    • Windows Vista/XP/2000
    • 40 MB of hard drive space
    • LabVIEW 2009
    • Microsoft Office 2007/2003/XP
    InstallationVersion 2009
    You can install all of your LabVIEW products—including the Report Generation Toolkit—using the LabVIEW 2009 Platform DVDs. You can find installation instructions for the Report Generation Toolkit along with activation instructions in the following locations:
    • LabVIEW 2009 Platform DVDs Readme, which is available on the top-level of LabVIEW Platform DVD 1.
    To request additional LabVIEW 2009 Platform DVDs, refer to the National Instruments Web site.
    Upgrade Issues
    The following issues only exist when upgrading from the Report Generation Toolkit 1.1.2 or earlier. If you are upgrading from version 1.1.3 or 1.1.4 to version 2009, the upgrade issues do not apply:
    • In the LabVIEW 2009 Report Generation Toolkit, the VIs use LabVIEW Classes. The report in control and report out indicator changed from reference number data types to LabVIEW class data types. If you did not create constants, controls, or indicators using the typedef refnum, the VIs might not work correctly.
    • The Numeric Array instance of the Excel Easy Table VI no longer contains the format string input.
    • If you save Report Generation VIs to a previous version of LabVIEW, the VIs might be broken when you open them in the previous version of LabVIEW. Rewire or relink the subVIs if this problem occurs.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the LabVIEW 2009 Report Generation Toolkit for Microsoft Office.
    -If you build an executable or shared library that uses the LabVIEW 2009 Report Generation Toolkit VIs, Application Builder places the files that have name conflicts outside of the application in folders. Remove the checkmark from the Use LabVIEW 8.x file layout checkbox on the Advanced page of the Application Properties or Shared Library Properties dialog box to fix this issue in LabVIEW 2009.
    133176VI with MS Office Report Express VI will be broken if the VI is recompiled
    121082number of copies input of Print Report.vi was changed from an int to a double
    138189New Report.vi keeps Template file open in LabVIEW 8.6
  • 签到天数: 2 天
    发表于 2014-1-16 23:17:00 | 显示全部楼层 来自:黑龙江省哈尔滨市 电信
  • 签到天数: 14 天
    发表于 2014-1-16 23:19:20 | 显示全部楼层 来自:广东省东莞市 联通
    发表于 2014-6-8 09:56:54 | 显示全部楼层 来自:江苏省南京市 移动
  • 签到天数: 5 天
    发表于 2015-9-30 09:41:55 | 显示全部楼层 来自:河南省郑州市 联通
  • 签到天数: 9 天
    发表于 2018-1-11 14:56:34 | 显示全部楼层 来自:广东省 电信数据上网公共出口
    GMT+8, 2026-2-24 23:47
