查看: 5652|回复: 0
[Patch补丁] LabVIEW 2012 f2 Patch Win64Eng LV2012f2补丁-64位版
    昨天 16:03
    发表于 2012-11-24 16:20:09 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    问题:
    LabVIEW 2012 f2补丁修复了哪些程序漏洞?
    解答:
    LabVIEW 2012 f2补丁有LabVIEW 2012开发环境和LabVIEW 2012运行引擎的联合补丁,也有单独用于LabVIEW 2012运行引擎的补丁。
    补丁修复了下列6个问题,也包含LabVIEW 2012 f1补丁中已修复的程序漏洞。 强烈建议所有LabVIEW 2012用户,尤其是LabVIEW FPGA模块的用户安装该补丁。 该补丁可通过NI更新服务获得,也可从下列程序和升级更新连接获得。
    LabVIEW 2012 f2补丁修复的问题
    ID说明信息
    368396Certain applications built with Application Builder fail to launch.
    368375Compound Arithmetic node will produce incorrect results when operating on units in LabVIEW 2012.
    365679LabVIEW 3D picture control does not work with AMD video card drivers.
    364462Crash when changing value of typedef constant.
    368115HTTP POST VI will always timeout when POSTing to a Web Service using NIAuth.
    368230[LabVIEW FPGA] Compound Arithmetic node will produce incorrect results when operating on a combination of arrays or clusters, and scalars.
    LV2012_f2patch64.txt (270 Bytes, 下载次数: 0, 售价: 1 圆)
    GMT+8, 2026-2-24 23:51
