查看: 7203|回复: 4
[LabVIEW] NI LabVIEW 8.5 Win32Eng LabVIEW8.5 32位英文版
    昨天 16:03
    发表于 2013-3-10 13:38:24 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    下载地址:
    百度网盘下载地址:
    EXE版本
    链接: 请购买附件下载查看
    提取码: 请购买附件下载查看
    RAR版本:
    链接: 请购买附件下载查看
    NI官方下载:请购买附件下载查看
    LV8.5ENG.txt (310 Bytes, 下载次数: 64, 售价: 50 圆)
    LabVIEW 8.5 Readme for Windows
    August 2007
    This file contains important last-minute information about LabVIEW 8.5 for Windows, including installation and upgrade issues, compatibility issues, a partial list of bugs fixed in the current version of LabVIEW, and changes from LabVIEW 8.2.x. Refer to the LabVIEW Upgrade Notes for more information about upgrade and compatibility issues and for a complete list of new features in LabVIEW 8.5. Refer to the LabVIEW Release Notes for installation instructions. After you install LabVIEW, you can access both of these documents by selecting Help»Search the LabVIEW Help in LabVIEW and navigating to the Technical Support and Professional Services book.
    You also can refer to the National Instruments Web site for more information about additional issues you may encounter upgrading from LabVIEW 8.2.x.
    Refer to the National Instruments Web site for the latest information about LabVIEW 8.5.
    Refer to the labview\readme directory for readme files about LabVIEW add-ons, including modules and toolkits.
    Supported Platforms
    Installing Another Language Version
    Installing LabVIEW Silently
    Licensing
    Additions to the LabVIEW Help
    Documentation Corrections
    Supported Platforms
    LabVIEW supports Windows Vista/XP/2000. LabVIEW does not support Windows NT/Me/98/95, any of the Windows Server editions, or Windows XP x64. LabVIEW does support Windows Vista x64.
    Refer to the LabVIEW Release Notes for a complete list of system requirements.
    If you have another language version of LabVIEW 8.5 installed on your computer, uninstall that version before installing the new language version.
    You can install LabVIEW without viewing any installation dialog boxes. Refer to the National Instruments Web site for more information about installing LabVIEW silently.
    Refer to the LabVIEW Release Notes for more information about installing LabVIEW.
    Licensing
    LabVIEW relies on licensing activation. You must activate a valid LabVIEW license before you can run LabVIEW. To activate LabVIEW, use the serial number you received as part of your installation package.
    Refer to the LabVIEW Release Notes for more information about licensing in LabVIEW.
    The following items are known issues in LabVIEW 8.5.
    IDKnown Issue
    Installation
    If you uninstall LabVIEW 8.5 and a previous version of LabVIEW remains on the system, the previous version of LabVIEW might try to repair itself the next time you open it. The repair process might remove any patches you installed for that version of LabVIEW. Make sure to reinstall any patches you have on the system after the repair finishes.
    Workaround—Refer to the KnowledgeBase at ni.com for more information about correcting this problem.
    If you install LabVIEW 8.5 and then install a previous version of LabVIEW on the same computer, Windows Explorer crashes if you use Windows Explorer to perform an operation on an LLB.
    Workaround—Select Tools»Options, select Environment from the Category list, remove the checkmark from the Enable Windows Explorer for LLB files checkbox, and click the OK button. Display the same Environment Options page again, place a checkmark in the Enable Windows Explorer for LLB files checkbox, click the OK button, and restart the computer.
    Compatibility
    The NI Publish-Subscribe Protocol (NI-PSP) networking technology is incompatible with the Windows XP Service Pack 2 firewall. You must disable this firewall for networking to function correctly.
    Workaround—Refer to the KnowledgeBase at ni.com for more information about the firewall.
    If you have Windows XP Service Pack 2 installed or use Windows Vista, a Security Alert dialog box appears when you launch LabVIEW or the NI Example Finder for the first time. If you select the Keep blocking this program option, the LabVIEW VI Server, LabVIEW Web Server, and any server written in LabVIEW cannot accept incoming connections from a remote computer.
    Workaround—Select the Unblock this program, despite the security risk option to configure your computer to launch LabVIEW without any changes in functionality. Refer to the KnowledgeBase at ni.com for more information about correcting this problem.
    VIs, Express VIs, and Functions
    The links to subVIs from the labview\vi.lib directory might break when you use File»Save for Previous Version to save application VIs for a previous version of LabVIEW.
    Workaround—Right-click the subVIs and select Relink To SubVI from the shortcut menu to relink the subVIs.
    If you move the Advanced Storage VIs to a LabVIEW development system with a different language, the VIs do not work because the object types and property names do not match the names in other languages.
    Workaround—To correct this problem, use the internal, language-independent object types and property names. Refer to the KnowledgeBase at ni.com for more information about correcting this problem.
    If you create a new, untitled VI while using the Storage VIs, the numbering of the untitled VI might be inconsistent.
    Workaround—N/A
    3YJ9J200Unable to drop the Database Variant to Data function
    If the Database Connectivity Toolkit 1.0 is installed, you cannot place the Database Variant to Data function on the block diagram.
    3W997BPTDelete Data VI does not delete data in tdm files
    The Delete Data VI does not work with .tdm files. If you use this VI with a .tdm file, the size of the file does not change, but you cannot access the data you try to delete.
    Workaround—Create a new .tdm file and copy the contents you want to keep to reduce the size of the file.
    3PD8N0M8LabVIEW uses large amounts of memory when reading an entire wave file at once
    The Sound File Read VI uses large amounts of memory to read an entire .wav file.
    Workaround—Read the data from the .wav file in sections rather than in one large file.
    3NRGJTI7Sound Output Set Volume VI doesn't set the volume on a per-channel basis
    The Array instance of the Sound Output Set Volume VI does not use the volume input to set the volume on a per-channel basis. Instead, this VI uses the first element of the volume input as the sound level for all channels.
    Workaround—N/A
    3NIBABK9Open VI Reference returns error 7
    If an example VI from LabVIEW 7.x or earlier opens another VI by specifying the example VI name as a path in the Open VI Reference function, you receive an error when you run that example in LabVIEW 8.x.
    Workaround—To correct the error, remove the String To Path function wired to the vi path input of the Open VI Reference function.
    3ZJCNQMQDynamically calling LabVIEW-built DLL in UI thread hangs LabVIEW
    If you configure a Call Library Function Node to call a LabVIEW DLL, LabVIEW hangs if you place a checkmark in the Specify path on diagram checkbox on the Function page of the Call Library Function dialog box and you select Run in UI thread in the Thread control. If you configure the Call Library Function Node to call a DLL written in C with these same settings, LabVIEW works correctly.
    Workaround—N/A
    4AJA41TQSome operations on integer waveforms lose dt value
    Some functions, such as Absolute Value and Logarithm Base 10 operate as you expect with DBL Waveforms, but when you apply the same functions to an I16 waveform, for example, the Absolute Value function works as you expect while the Logarithm Base 10 function loses the sampling interval dt value. LabVIEW resets the sampling interval dt value to 1.00.
    Workaround—Extract the Y-array of the waveform and perform the needed operations on Y before re-building the waveform.
    4709CDDVMatch Regular Expression function might cause stack overflow with some inputs
    Certain regular expressions might cause a stack overflow on large input strings. Some regular expressions might recurse repeatedly while LabVIEW attempts to match a large string that might overflow the stack eventually. For example, the regular expression (.|\n)*A and a large input string might cause LabVIEW to crash.
    Workaround—Rewrite the regular expression to avoid recursion. For example, to avoid recursion you can rewrite the regular expression (.|\n)*A as (?s).*A. The (?s) notation indicates that a period (.) matches new lines. You also could rewrite the expression more efficiently as [^A]*A.
    44CG88SNUpdate the Pulse Transition Measurement Express VI
    The terminology and measurement definitions for the Transition Measurements VI comply with IEEE Standard 181-2003, IEEE Standard on Transitions, Pulses, and Related Waveforms. However, the Timing and Transition Measurements Express VI does not comply with this IEEE Standard.
    Workaround—The Slew rate refers to the transition slope. The Preshoot refers to the pre-transition undershoot (rising pulse) or the pre-transition overshoot (falling pulse). The Overshoot refers to the post-transition undershoot (rising pulse) or the post-transition overshoot (falling pulse).
    41CE6I39Storage VIs do not recognize DIAdem date/time channels
    The Storage VIs do not recognize the date/time format used in DIAdem date/time channels. When you use the Storage VIs to read data from a DIAdem date/time channel, LabVIEW converts the date/time data to a double-precision, floating-point number that represents the number of seconds since 01/01/0000.
    Workaround—After LabVIEW converts the DIAdem date/time data to a double-precision, floating-point number, you can convert the double-precision, floating-point number to a more meaningful value.
    Block Diagram Objects
    3P7CBB4QUnsigned int32 losing value in formula node when most significant bit is written to
    If you wire a hex value greater than x7FFFFFFF as an unsigned, 32-bit integer to a Formula Node, LabVIEW coerces the value to 0.
    Workaround—N/A
    3NHFKMSUActiveX event unregistration did not execute properly after the VI goes idle
    If you register an ActiveX event, you must unregister the event explicitly. Otherwise, memory leaks might occur because the ActiveX control does not know that the client has disconnected.
    Workaround—N/A
    401FEQTLThe device ID input of the Play Sound File VI does not work on Windows
    On Windows, LabVIEW ignores the device ID input of the Play Sound File VI. This VI plays sound only on the default sound card.
    Workaround—Use the Sound Output Configure VI and the Sound Output Write VI with the Sound File Open VI and the Sound File Read VI or the Sound File Simple Read VI. Refer to the Sound File to Sound Output example VI for an example of this workaround.
    4388O1FIUsing a higher number of shared variables in a VI makes the VI respond slowly during development.
    A VI with many shared variables on the block diagram, for example, 50, might respond slowly if you place another block diagram object, for example, a numeric constant on the block diagram.
    Workaround—Place the Shared Variable node inside a subVI and use the subVI to access the Shared Variable node. If you already have a Shared Variable node on the block diagram of a main VI and you have already wired inputs and outputs, you can right-click the Shared Variable node and select Create SubVI from the shortcut menu. If you experience any additional issues after creating a subVI from the Shared Variable node, consider making the subVI reentrant.
    4BFH3J00Timed Loops start returning error -800 before reaching the limit of 128 in memory
    Placing Timed Loops on the top-level block diagram, you can get up to 128 instances before receiving errors, but when the Timed Loops are in reentrant subVIs or instance VIs, the error happens before LabVIEW loads 128 instances.
    Workaround—If multiple VIs are in memory, close a few VIs and try again. You also can replace some Timed Loops with While Loops for emulation purposes.
    2BCDF100Remote Panel not correctly displaying hidden/disabled controls when server is a built app.
    Clients viewing a front panel remotely might see different behavior depending on whether the front panel they are connecting to is from a built application. Specifically, if the front panel is from a built application, any programmatic changes to the front panel made before the client connects to the front panel are not reflected on the client computer. For example, if a Property Node changes a caption on a control before a client connects to that front panel, the client will see the original caption of the control, not the changed caption.
    Workaround—Refer to the National Instruments Web site for more information about this issue.
    4AOEJ5F2FP:Get Image, FP:Get Image Scaled, Print:VI to HTML, Print:VI to RTF, and Print:VI to Printer methods do not properly generate off-screen cluster images
    These methods generate an incorrect image of the front panel when it contains off-screen clusters and the contents of all off-screen clusters appear blank in the generated image. This issue only affects the FP:Get Image and FP:Get Image Scaled methods when the Visible Area Only parameter is set to False.
    Workaround—N/A
    4BMANBJ1Multi-frame structures do not switch frames on undo
    If you place a multi-frame structure (Event Structure, Case Structure, etc) on the block diagram, edit a frame in the structure, switch to a different structure and then press ctrl-z to undo the edit, LabVIEW does not switch to the frame that contains the change that you are undoing.
    Workaround—N/A
    DataSocket
    2VO0SF00DataSocket/OPC Leaks Memory using ActiveX VIs to perform open-write-close repeatedly
    If you call the DataSocket Open, DataSocket Write, and DataSocket Close functions in succession repeatedly, LabVIEW leaks memory.
    Workaround—To correct this problem, call the DataSocket Open function once, use the DataSocket Write function to write multiple times, and then use the DataSocket Close function.
    3BS49JS8dialog box and open datasocket conflict
    If a dialog box is already open, you cannot use the DataSocket Open function.
    Workaround—N/A
    38ECIGX3DataSocket HTTP protocol does not work in a LabVIEW built DLL
    You cannot use the http protocol with the DataSocket VI and functions in LabVIEW-built shared libraries.
    Workaround—N/A
    3OLE2573DataSocket and Fixed Size Array Do Not to Work
    You cannot use front panel DataSocket data binding with fixed-sized arrays.
    Workaround—N/A
    3LTEKT00Pre-defined booleans in Data Socket Server Manager
    If you use the DataSocket Server Manager to create a Boolean object, the DataSocket Server Manager converts the Boolean object to numeric data in the configuration file.
    Workaround—N/A
    4A37JOV9DataSocket functions do not handle Domain security correctly.
    The DataSocket Open function returns error 1179 for any attempt to connect to a shared variable that has security enabled, even if the correct user is logged in.
    Workaround—N/A
    Environment
    QH3BA000
    A blue field does not surround the palette icons for Express VIs from LabVIEW 7.x and earlier that you open in LabVIEW 8.x. For example, if you use a LabVIEW 7.1 toolkit in LabVIEW 8.x, a blue field does not surround the icons for Express VIs on the toolkit palette.
    Workaround—You must mass compile the Express VIs to display the blue field around the icons.
    3MRDJ300Subpalettes need to be context aware, i.e., need to show/hide when owning library is locked/unlocked
    LabVIEW does not correctly hide subpalette menus that belong to locked project libraries.
    Workaround—N/A
    2JQ91R6ILabVIEW's Hierarchy Window does not show the labels of the VI's for print out
    When you print the VI Hierarchy window, LabVIEW does not print the VI labels.
    Workaround—N/A
    3EIB4MS5No prompt to add a comment in the revision history on close
    If you select the Prompt for a comment when the VI is closed option on the Revision History Properties page, LabVIEW does not prompt you to add a comment to the History window when you close the VI.
    Workaround—Select the Prompt for a comment when the VI is saved option on the Revision History Properties page.
    47MA31QOVI in web browser with top-level window or dialog window style does not draw
    If you create a VI and select Top-level application window or Dialog options from the Window Appearance page in the VI Properties dialog box and publish the VI to the web, when you view the VI the VI uses the default window style instead of the style you selected.
    Workaround—Do not set the window style of a VI to top-level or dialog if you want to publish the VI to the web.
    4BCH23FNDragging a Variable between projects if a Multiple Variable Editor window is open can hang LabVIEW.
    If you've got a Multiple Variable Editor window open, and drag a variable from one project to another, LabVIEW hangs.
    Workaround—Close all open instances of the Multiple Variable Editor window before dragging variables between projects.
    3YJ87JCMWrite to Clipboard Method takes minutes and a lot of CPU
    If you try to copy a large amount of data from LabVIEW to the clipboard, LabVIEW slows significantly and might become unresponsive.
    Workaround—N/A
    452FUSJ1Infinite recursion of VIs causes computer to become unresponsive and likely crash
    It is possible to build VIs that infinitely recurse through VI references or dynamic dispatching VIs in LabVIEW classes. If this happens, LabVIEW continually tries to allocate new instances of the VIs until LabVIEW consumes all available memory. The result is that the computer may become very slow as it fills virtual memory. Eventually the computer runs out of memory and, depending on where this memory loss happens, it may not be handled correctly and result in a crash.
    Workaround—If you write recursive VIs, make sure you handle the recursion termination case.
    3PCAD0J1Save As»Substitute Copy affects all projects in memory, not just the one that does the Save As operation.
    If you have Alpha.vi loaded into two separate projects, these are two independent VIs in memory. If you do Save As»Rename then, LabVIEW correctly renames the VI in both projects since the actual source on disk has changed. However, if you do Save As»Substitute Copy, only one project should change.
    Workaround—Close any projects that you want to contain the original VI before performing the Save As»Substitute Copy operation.
    3QHGOFBQCannot use Japanese characters on LabVIEW using Japanese system locale on French OS
    LabVIEW cannot render language-specific characters correctly if the codepage and locale settings do not match. For example, if you set the system codepage to Japanese but you set the locale to something other than Japanese, LabVIEW does not render Japanese characters correctly.
    Workaround—Make sure your system codepage and system locale match.
    4A8CI3BWImport Web Service Wizard hung generating wrapper VIs
    The Import Web Service Wizard hangs due to a recursive process when you include a method or property that returns an object of the same class.
    Workaround—
    • Try selecting only those methods that you want in the web service, and deselecting methods that you do not want to include. You also can select a single method, then after the wizard generates a wrapper VI which includes an open and close method, you can manually add a Invoke Node, then select the method you want.
    • If the wizard does hang, the selected methods might have a chain structure as a parameter. Web Service Import Wizard does not support that datatype. Click the Cancel button and exit the wizard.
    477DKPBQLabVIEW does not maintain child-only item setting when dragging an item within a tree
    If you have a tree item with the child-only setting, and then drag it within the tree, LabVIEW loses the child-only setting.
    Workaround—N/A
    47FGSQCSCannot save VI as the same name as missing library member VI
    If a library contains a VI and the VI is missing, you should be able to save a VI as the same name as the missing VI in order to rebuild the missing VI. Currently, LabVIEW does not allow this.
    Workaround—Delete the item from the library, save the new VI as the same name as the missing VI and then move the VI into the library.
    LabVIEW MathScript
    If you select File»Save for Previous Version and save a VI that contains a MathScript Node for LabVIEW 8.0, the VI is broken when you load it in LabVIEW 8.0.
    Workaround—To correct this problem, load the VI in LabVIEW 8.0 and then modify the script in the MathScript Node. For example, add and remove a space. Then click the block diagram outside of the MathScript Node. When you click the Run button, the VI runs correctly.
    3YLB3DDXInstance VIs can be reported bad in mass compile log
    If you mass compile VIs last saved in a previous version of LabVIEW and the VIs contain MathScript Nodes, LabVIEW might return error messages, but LabVIEW compiles and saves the VIs correctly.
    Workaround—N/A
    If a LabVIEW MathScript contains a findobj or gco function, LabVIEW ignores the function and executes the remainder of the script as normal. LabVIEW does not return errors or warnings for these functions in a script.
    Workaround—N/A
    490EII2JMathScript realmax returns Inf instead of max pos real value.
    MathScript realmax function returns Inf instead of the maximum positive floating-point number.
    Workaround—N/A
    4B24T15IWhen trying to write to a read-only .m file, MathScript does not show an error dialog box
    When trying to write to a read-only .m file, MathScript does not show an error dialog box.
    Workaround—N/A
    4BMGP200Closing the MathScript Window causes problems with the MathScript Probe variable display
    If you close the MathScript Window while the MathScript Probe displays the contents of a variable, the current variable display of the probe stops working. The display no longer responds to changes in the value of the variable.
    Workaround—To restore the display after it stops working, deselect the variable in the probe by clicking on the name of the MathScript node and then reselect the variable.
    LabVIEW Object-Oriented Programming
    3Y18O59IThe private data control can get into a permanent locked state when class loads into multiple application instances
    If you delete a control, indicator, or constant of a LabVIEW class, the backup object keeps the LabVIEW class loaded in that application instance. This backup object can cause a problem if the LabVIEW class is loaded in more than one application instance.
    Workaround—To edit the LabVIEW class, make sure the class is loaded in only one application instance. The backup object might be the only reason the LabVIEW class stays in memory in an application instance. To remove the backup object for the LabVIEW class, save or close the VI(s). Refer to the KnowledgeBase at ni.com for more information about correcting this problem.
    49GE2P00Stand-alone application cannot load a class that includes polyVIs
    A LabVIEW-built application that uses a LabVIEW class which contains a polymorphic VI does not function if the build options are set to include unused polymorphic VI instances, or if the polymorphic VI is in a plug-in to a built application that is outside the application.
    Workaround—Choose to exclude unused polymorphic VI instances by selecting the Remove unused polymorphic VI instances option on the Additional Exclusions page.
    4A4GRP00Cannot create override of password-protected VI unless you have the password
    You cannot create a VI to override an ancestor VI in a LabVIEW class if the VI you want to override is password-protected.
    Workaround—Create wrapper VIs that are not password-protected to override.
    3W6K2TMQUndo on a private data control can leave you in a state where File»Apply Changes is needed but disabled
    Editing a private data control and then undoing the edits removes the documentation modification on the class. However, while the owning class is broken and expects you to apply the changes you made, the File»Apply Changes menu option is disabled on the private data control.
    Workaround—Select File»Save or File»Close to save or close the private data control.
    3WGFQJ2KLabVIEW class save prompts sometimes come at incorrect times.
    If you right-click a control in the Project Explorer window and selcct Convert Contents of Control to Class from the short-cut menu and then undo the conversion, LabVIEW might think the class still exists and you may not be able to load a class of the same name as the control.
    Workaround—Save all files that referenced the class you created from the control. This clears the backups of the files and allows the class to leave memory.
    48OAL61WView»Browse Relationships»This VI's Callers is disabled for dynamic dispatch VIs.
    LabVIEW disables the View»Browse Relationships»This VI's Callers option for dynamic dispatch VIs. Because LabVIEW calls dynamic dispatch VIs dynamically, the VI Hierarchy window does not recognize dynamic dispatch VIs as callers because there are no calls until run time.
    Workaround—N/A
    40M9C8N8After you flatten a LabVIEW class to variant data, the private data control hangs if opened from the VI Hierarchy window
    If you open the private data control of a LabVIEW class from the VI Hierarchy window, LabVIEW might hang when you try to close the Control Editor window for the private data control. This issue occurs if the only LabVIEW class data in memory is contained in variant data. For example, you might delete all LabVIEW class controls and constants and then remove all LabVIEW classes from the LabVIEW project, but variant data with class data still might exist in memory.
    Workaround—Close the VI that contains the variant data with the value of the LabVIEW class.
    45ME5NJ1Cannot create an override member VI for both a child class and a grandchild class unless you first save the VI that contains the child class
    You cannot create a VI that overrides the functionality of a child class and then create another VI that overrides the functionality of a grandchild class unless you first save the VIs you want to override. Thus, if you right-click a LabVIEW class in the Project Explorer window and select New»VI for Override from the shortcut menu to create child:A.vi, you cannot select New»VI for Override for the grandchild class to create grandchild:A.vi until you save child:A.vi. This issue occurs because you cannot have two VIs in memory with the same filename that have never been saved.
    Workaround—Save the VI before you try to override any LabVIEW classes in that VI.
    3XHF1O2KRunning a dynamic dispatch VI as top-level and another VI that calls the dynamic at the same time can cause unexpected termination of VIs that running
    If you set a dynamic dispatch VI to be the top-level VI in an application, and another VI calls the top-level dynamic dispatch VI at run-time, the dynamic dispatch VI might become idle. Eventually, any VIs using the class that the dynamic dispatch VI belongs to might break.
    Workaround—N/A
    4ARD3OV2Inserting Bundle by Name function into the LabVIEW class wire behaves differently than cluster
    If you right-click a class wire and select Insert»Bundle by Name, LabVIEW inserts the class wire into the value input of the Bundle by Name function, not the type input.
    Workaround—N/A
    4AKFM1J1Changing the label of controls in private data control does not update actual class data type
    If you use the Bundle by Name or the Unbundle by Name functions on a LabVIEW class and you change the name of a control in the private data control, the elements available for bundling or unbundling do not change. LabVIEW does not register the name as changed unless or until you make another more substantive change to the data type of the private data control.
    Workaround—N/A
    4B8DH7J1Race condition exists between loading a LabVIEW class and unflattening an LabVIEW variant
    When LabvIEW unflattens a LabVIEW variant, there is a race condition that might lead to a LabVIEW crash if the following conditions exist:
    • The data LabVIEW is unflattening is a class that is not in memory.
    • In a parallel thread, LabVIEW is loading the class into memory.
    Workaround—N/A
    Shared Variables
    3KAEOHC3Private variables are accessible outside their Library
    You can read from and write to private single-process shared variables.
    Workaround—N/A
    3Q9DN1ZUDeployment fails for all Variables in a Library if one Variable has a bad binding
    LabVIEW fails to deploy all shared variables in a library if one shared variable has an invalid binding.
    Workaround—To correct this problem, either delete the shared variable that has an invalid binding or unbind the shared variable.
    3Y4HCE00
    If you select File»Save for Previous Version and save a VI that contains a Shared Variable node for LabVIEW 8.0 and open the VI in LabVIEW 8.0, the VI might not return correct results.
    Workaround—If you open the VI in 8.0.1 or later, the VI returns the correct results. Refer to the KnowledgeBase at ni.com for more information about correcting this problem.
    3R8EFNKYVarClient on cFP reports "variable does not exist" if the variable is published by a host that has two ethernet adapters
    Network-published shared variables do not function properly if multiple network adapters are enabled on the same computer.
    Workaround—N/A
    Import Shared Library Wizard
    4B9MOUMXImport Web Service wizard fails to expand the .NET reference when the reference is in an array
    The Import Web Service wizard expands the .NET reference and returns all its properties. However, when the .NET reference is in an array, it returns only the reference, not its properties.
    Workaround—Use the Index Array function and a Property Node to get the properties of the .NET reference.
    4AIGSL00The progress bar in the Import Shared Library wizard appears to hang
    When you use the Import Shared Library wizard, LabVIEW displays a progress bar. This progress bar might appear to hang, even though the tool is working correctly.
    Workaround—N/A
    4999TKGIImport Shared Library wizard cannot recognize a function if the function declaration contains a default value
    In the Import Shared Library wizard, LabVIEW cannot recognize a function in a header (.h) file if the function declaration contains a default value for a function parameter.
    Workaround—Remove the default values of parameters in the header file. Instead, add the default values to the Configure VIs and Controls page of the Import Shared Library wizard.
    44CEN7MQImport Shared Library wizard cannot recognize multiple function declarations in a row
    If you have a header (.h) file that contains multiple function declarations in a row, the Import Shared Library wizard recognizes only the first function declaration.
    Workaround—Separate the function declarations in the header file.
    45I650CIThe Import Shared Library wizard does not support macros inside of function declarations
    The Import Shared Library wizard does not support macros inside of function declarations in the header (.h) file.
    Workaround—Move any macros outside of function declarations in the header file.
    Windows Vista
    4API8A00Logos fails on Vista when PC-cillin is installed
    If you have a version of PC-cillin Internet Security installed on Windows Vista, Logos does not work. Because of this issue, you cannot communicate with Ethernet instruments, such as FieldPoint modules, that use Logos.
    Workaround—N/A
    43QESS00Applications can no longer start services under Windows Vista
    You cannot start and stop the following services from the command line on Windows Vista using the -start and -stop parameters or the Windows net start and net stop commands:
    • Shared Variable Engine
    • National Instruments PSP Server Locator
    • NI Lookout Citadel Server 4.x
    • Citadel 5.x Database
    • National Instruments Time Synchronization Service
    • National Instruments Domain Server
    Workaround—To start and stop these services, use the Services utility, available by selecting Start»Control Panel»Administrative Tools»Services. Also, NI applications no longer start these services automatically if the service is not running already.
    43FF6NQ6Many cosmetic problems due to new Vista default fonts
    Because the default fonts on Windows Vista are different than the default fonts on previous versions of Windows, you might notice cosmetic issues, such as overlapping or truncated text strings, in VIs and LabVIEW dialog boxes.
    Workaround—To correct this problem, change the theme of the operating system to Windows Classic in the Theme Settings dialog box and then restart LabVIEW. Select Start»Control Panel»Appearance and Personalization and click Change the theme to display the Theme Settingsdialog box.
    For compatibility reasons, the LabVIEW installation process enables write permissions for any folders, files, and registry keys that LabVIEW might write to during normal operation.
    Workaround—N/A
    453BD7Q6LabVIEW crashes on Japanese Vista if system locale set to a Western European codepage
    If you have a user name that uses Japanese characters and change the system locale to something other than Japanese, LabVIEW crashes.
    Workaround—Make sure your locale and user name match.
    Miscellaneous
    3OGLNTCILabVIEW code with Xmath script hangs when server is offline
    If the server on which the Xmath license is installed is offline, LabVIEW hangs when you open a VI that contains an Xmath script node.
    Workaround—N/A
    If a remote panel server is a LabVIEW development system, when a client requests a VI, LabVIEW saves an in-memory image of the VI and sends an up-to-date VI image to the client. Therefore, the remote front panel and the local VI front panel look the same. However, if a built application is a remote panel server, LabVIEW acquires the VI image from disk and sends it to the client. In this case, the VI image that the client receives might be out of sync with the in-memory image of the VI on the server computer if the client connects to a VI that has already been running. The remote front panel might not show an updated version of the VI front panel on the server computer.
    Workaround—Refer to the KnowledgeBase at ni.com for more information about using remote panel servers with built applications.
    23CA2A2ILogos might not do what you want when the computer has multiple ethernet cards
    If you have more than one Ethernet card, Logos is automatically assigned to the primary Ethernet card.
    Workaround—To assign Logos to a different Ethernet card, switch the Ethernet cards.
    3N68LE002GB file size limit of datalog files
    The maximum size of datalog files is 2 GB.
    Workaround—N/A
    3IKBUP99Zip build provider and Zip VIs do not support multi-byte character encodings.
    The Zip build provider and the underlying Zip API provided in the File I/O palette do not support paths with multibyte character encodings. Some upper or lower bytes of multi-byte characters decode into disallowed ASCII characters when not pointed to correctly.
    Workaround—Ensure that the full filepath to zipped files does not contain multi-byte characters.
    3J0A89J1Zero element clusters not reported as an error for Type Defs/Custom Controls
    Type Defs should not contain zero element clusters, but LabVIEW does not report an error if you have a type def with zero elements.
    Workaround—Do not save a zero element cluster.
    4AIFC0R0Internal error related to locked tab control at fpsane.cpp line 369 and line 367.
    If you lock a tab control that is already locked using Group»Lock, you might see two internal errors and LabVIEW may crash.
    Workaround—Do not lock a control that is already locked.
    477M7K00Large amounts of data in combo box can appear to hang LabVIEW.
    If you place a large amount of data in a combo box, on the order of megabytes, LabVIEW appears to hang by taking a long time to calcualate wrapping.
    Workaround—N/A
    4AIBSAFFWhen synchronous display is enabled, disconnecting and reconnecting to a LabVIEW 8.5 RT target performing image display in a loop causes the RT target to hang
    If you enable synchronous display on an image display control and then update the control in a loop on a VI running on an RT target, LabVIEW hangs after disconnecting and reconnecting to the target. This issue might occur when you want to run an application that can perform a headless operation, but you still want to perform image display in a loop.
    Workaround—Right-click the image display control and select Advanced»Synchronous Display from the shortcut menu to disable synchronous display.
    42NAR8SACenter justified tables display improperly when overlapping with the front panel origin
    When you add a table control to the front panel so that it overlaps with the vertical origin of the front panel, LabVIEW displays center justified columns off center when you type text.
    Workaround—N/A
    • A .NET or ActiveX property that returns a reference to a class outside the current type library cannot be made into a dotted property. When you view the property in the Class Browser window, a blue glyph does not appear next to the property name in the Properties and Methods list.
    • You can access LabVIEW data files from DIAdem regardless of the format in which you stored those data files.
    • If you configure source control in LabVIEW, LabVIEW does not report an error when you save a VI to a directory outside the SCC specification.
    • In LabVIEW 7.x and earlier, if you wire dynamic data to a waveform-based polymorphic VI that has Automatic selected in the polymorphic VI selector, LabVIEW selects the 1-channel instance. In LabVIEW 8.x, LabVIEW selects the N-channel instance. The N-channel instance returns arrays of measurement data instead of a single measurement, so VIs that use a waveform-based polymorphic VI might be broken in LabVIEW 8.x. If you want to process only the first signal in the dynamic data, you must manually select the 1-channel instance in the polymorphic VI selector.
    • The LabVIEW Fundamentals manual and the LabVIEW Quick Reference Card did not change for LabVIEW 8.5. Therefore, the content might not reflect changes made in LabVIEW 8.5. Refer to the LabVIEW Help for the most updated information.
    • The Getting Started with LabVIEW manual does not reflect the most updated version of the DAQ Assistant in Chapter 4.
    • The place and find buttons in the Unzip and LV Object Constant topics do not function properly.
    • The LabVIEW Upgrade Notes incorrectly states that in LabVIEW 7.x and earlier, the Active Cell Properties:Cell Size:Height and Active Cell Properties:Cell Size:Width properties return one less pixel for each line in the tree control than in LabVIEW 7.x.
      The text should read:
      In LabVIEW 7.x and earlier, the Active Cell Properties:Cell Size:Height and Active Cell Properties:Cell Size:Width properties return one less pixel for each line in the tree control than in LabVIEW 8.x.
    • The LabVIEW Help should state that the parameter maximum and parameter minimum arrays in the parameter bounds input of the Constrained Nonlinear Curve Fit VI accept values of Inf and –Inf.
    • The LabVIEW Help should state that the merging VIs feature new to LabVIEW 8.5 is available in the LabVIEW Professional Development System only. You access the merging VIs feature by selecting Tools»Merge VIs from the front panel or block diagram to display the Merge VIs dialog box. You also can use the Merge.exe utility in LabVIEW Professional Development System only.
    • The LabVIEW Help incorrectly states that you can use the properties dialog boxes to configure the range and desired delta for fixed-point numbers in constants, controls, indicators, and the outputs of certain functions. You can configure only the encoding, word length, and integer word length for fixed-point numbers. LabVIEW displays the corresponding range and delta in the properties dialog box when you configure the encoding, word length, and integer word length for a fixed-point number.
    • The LabVIEW Help does not list a possible value for the Wakeup Reason data node in the Nodes of the Timed Loop topic. Value 2 is Asynchronous wakeup.
    • The LabVIEW Help should state that the /3GB option to extend virtual memory is available on Windows XP only, not Windows 2000. Also, you should have at least Windows Service Pack 2 installed on the Windows XP system.
    The following items are the IDs and titles of a subset of issues fixed between LabVIEW 8.2.1 and LabVIEW 8.5. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of LabVIEW.
    49OA8M00Only part of the front panel can be accessed.
    43175200Issues with waveform graph example
    48592300C++ NI-Reports VS2003 does not deploy correctly when installed as "Just Me"
    49080069Event Handling Example Needs to be Updated
    1HO7K8X4Slider with multiple thumbs can not preserve values when unit is applied or removed
    2R4G20GQBrowser does not bring modal subvi window to front
    2RJ7RPN4Wiring problem
    2S2DS6S4Find dialog: DAQ Channel Name, IVI Logical Name, and VISA resource name constants cannot be found.
    2SHEGGQQReplace text does not work on listbox controls
    2SHEI800Replace text does not work on Graph controls
    2SHEIP00Replace text does not work on table controls
    2WC9H400Broken wires into property node when loading
    2WDAKK8ZFloater Window Behavior acts same as Floater/Auto-Hide on OSX
    2X072200Add Height and Width properties to the control/indicator property box
    30K2R2TPChanging System Time causes DataSocket Server 4.1 error 56 in LabVIEW
    31NEJ9RQFeedback nodes don't align.
    3219N8DVAlt key behavior incorrect when watching for MenuActivation? event
    33C83T2KUser "Panel Resize" events behave differently/incorrectly on different platforms when doing Maximize/Minimize/Restore
    35Q5FK5EEmpty pages when printing VI documentation
    369CTJ83New timing primitives 'expand' whatever structure they are inside when a copy operation is done.
    36GCPMJ1In [Formula] Express VI, the configuration dialog does not let focus follow mouse clicks
    377925WJSet Properties creates a new channel when incoming DDT has different name
    378A92WJError -2553 when reading an empty channel
    37S7AU7Wdoesn't work correctly with arrays of different lengths
    381F3DWWA timed loop based on a G based timing source always finishes late if Tick is generated faster than ~250Hz.
    39IELUM0Read LabVIEW Measurement File returns Error 4 if called on the same file twice without unloading the VI
    3AS9FNWQVI: Cannot use variable "i" in same formula as constant "pi". Also, renaming variable "i" to "k" replaces "pi" in formula w/ "pk".
    3B0AEO00Formula Waveform (used by LabVIEW SignalExpress) does not return error for some invalid formula
    3B76NDOCPlacing IMAQ Image Display inside Control Refnum crashes LabVIEW
    3BPACBTQTransient Measurements "Auto-select" does not work correctly
    3C5E21JETerminal References get invalidated when PolyInstance Changes
    3DS9A1R0Express VI Configuration dialogs do not have OK button as default (i.e. tied to Enter key).
    3E73LCFIBundle by name bug when using multiple clusters inside a cluster.
    3EAC9Q00performance Problems with ACL::getAccessRights(ipAddr)
    3EIA5I08coloring of connector nodes carries over between instances
    3EPA6B3ULabVIEW does not refresh default printer after it has been opened.
    3F18KIJELabVIEW Compiler Error when using EXT datatype with Storage VIs
    3FACNL8ZControl Names Don't Match Name User Sees
    3FI9CGPJNativeDialogSetup disables all VIs including the ones in the Native Dialog
    3FTBF0QOIn palette editor, if I close these palettes then there is no way to get them back.
    3G1H098VValue Change Event Does Not Fire With Combo Box Set to Update While Typing
    3G87AKGIBroken Wires in IVI Write Property Node (Intermittent Issue)
    3HJ94BMODifficult to back out of a bad choice made during "Save" interaction.
    3HPA4100Type descriptors and DDO names are different due to trailing white space
    3IEFAIP2SCL/OSX: Listbox on "Find VIs on Disk" don't seem to update when moving window.
    3IFA64WNProject library properties: icon for new VI under library is not enforced
    3IFEFU56Cannot create a cluster using IFlexData
    3IGFHGUKRead Measurements File "Generic Text" Option is wrong
    3IR5KC00Losing Description and Tip when converting Control to Constant
    3IRCOHR0Read from Measurement File & Write to Measurement File - Tab Order problems
    3J0DUGP2Enable state of "Apply window" control in configuration dialog of [Amplitude and Level Measurements] Express VI is confusing.
    3J7741P2Project toolbar is not correct after canceling File>>Open
    3J7E8SJ1Finding a domain ... the Find button is not linked to the Enter key
    3J8D6NBDColor scale on meter cannot be reset when colors go off spectrum
    3KBC5EVIChange ACL validation so that more specfic wins
    3KLD901IDigital Conversion VI needs better error message
    3KOFR31OLabVIEW 7.1 for Linux - When I create a constant on the block diagram, it decrements the value of the constant if I left-click over the constant.
    3L2G1AF2Cosmetic and Functional Issues with Configuration Dialogs for Timed Loop and Timed Sequence
    3L3HA5WNMysterious blocking of timed loops on hyperthreaded machines.
    3L89JJWQLabVIEW for Linux may have lurking crash due to handling of preferences for multiple LabVIEW versions.
    3LC8EJR0Unbundle by Name reports warning of unnamed or duplicate member for all instances of the node.
    3LICRQ00Viewing "This VI's SubVIs" for an FPGA VI diagram produces an unexpected list of subVIs.
    3LO8NFP2VI doesn't break or show an input when configuration cancelled.
    3LQ8T2P2Label snapping does not take array constant index into account.
    3M9A6CJMFeedback node doesn't react when you add space on you diagram.
    3M9CGL6RVIs that were converted from Express VIs can still have "toolkit" creation info.
    3MJ6PENWLabVIEW runs out of memory when it calls a LabVIEW built dll from another version
    3MJMKBSGExecutable doesn't support all cursors when using the Cursor VIs
    3MR7FLRMDLL Node dependencies are not handled correctly in Project Window
    3MSD3BMQFind/Replace All ignores matches within the same string (in regexp mode)
    3N591RJ1Trailing space in ring selector makes entering new value tough for enum values (auto completion comes out wrong)
    3N78Q5HHWait for RQS VI Should Not Lock GPIB Bus
    3N8EJFJ1Create SubVI does not respect the "Resize new ctls to grid" option in Tools>>Options
    3NBAFLF2No Hourglass Cursor When Performing Big "Replace All" Operation
    3NBD4PJ1NI Security: Login to Domain has domain/username/password in wrong order
    3NBDANJ1NI Security: Default values for "password expiration" are strange/illogical
    3NBF9RJ1NI Security: UI feedback for "User Properties" -- Membership tab
    3NBFH4J1NI Security: UI Feedback for Group Properties dialog
    3NDF2J8PTHD Example benchmark test runs significantly slower in 8.0 than in 7.1
    3NIE2300Window problems with synchronizing VIs across application instances
    3NJ6S81WError list messages indicate wrong VI broken
    3NK8DCN8Find and replace dialog shows ugly instance VI names
    3NQBMIP2"IsBreakPtSet?" & "AutoGrow" property returning wrong value for Timed Sequence.
    3O1AFOS5Loading corrupted VI crashes LabVIEW
    3O3FBA8ZPane Events Have Two Differently Named Event Data Fields That Are Actually the Same
    3O7DD8P2There needs to be a reliable way to tell the type of Express VI when traversing for SubVI.
    3O7FB9GQMenu Shortcuts page doesn't allow you to enter Ctrl-Z, Ctrl-X, Ctrl-C or Ctrl-V
    3O86UKP2Data Range and Format and Precision tab come up empty when selecting properties of controls in refnums.
    3O89QP00LV8J - Icon Editor for Application Builder: trailing byte of Japanese characters appear as black dots
    3O8AP328I/O Server needs to be localized.
    3O8BCLGQWindow order problem with property pages
    3OA8OF1WViewing terminals as icons doesn't show type
    3OAHA2N8Instance VIs are not reproducible
    3OB9O72KEvent Registration Refnum branch warning is set and listed incorrectly
    3OE89R1WInitializeOutputDeviceRing.vi returns error 4803 on my test machine
    3OEFACLGWhen a vertical fill slide is inside of a tab control and the scale is changed programmatically, the scale doesn't update unless the window is refreshed.
    3OI8D300Auto Configure Button on [Create Histogram] Works Poorly for Integer Inputs
    3OI9FCN8Font tables are not saved in an easily predictable manner
    3OIBNEN7Graph scale markers values not displayed when using nonzero offset
    3OOB4NS5Printing Problem Assistant resets path that user entered to default value
    3OOBC6S5Printing Problem Assistant - long paths don't scroll
    3OOE6R3AExpress VI modifies dt of signal
    3OTANL28Domain Manager window needs to be localized
    3P1CLBV9Variable Manager does not handle or display IO servers correctly
    3P58NAGIRMS Measurement Incorrect for Complex Waveform
    3P68FELJNeed to remove the ability to add a target on remote subnet from a networked device.
    3P6CR6NRBinary to Digital Poly VI does not adapt to type
    3P7BIJSQFormat Into String incorrectly formats into string
    3P7BPBJ1Conditional Compile node means subVI nodes won't necessarily update during a Save As on subVI even if caller VI is in memory
    3P7EA300No Help for Automation Close Function
    3P7FCAF2Dragging Object onto Diagram From Project, Then Pressing Delete, Deletes Object from Project
    3PEFDKCSRecent Projects menu does not show full paths if duplicate names in projects
    3PF9BVNRtimeseq.cpp line 1509. VI insanities after attempting delete of a timed sequence inside a timed loop
    3PIBM9MPBreaking then fixing a wire connected to an input tunnel on Sim Loop results in an incorrectly broken run arrow.
    3PKBG6HLHelp window does not update description when hovering over VIs in the project window
    3PMBTSBWListing unsaved changes of untitled library results in internal warnings
    3PP78E00Table/Ring Editor: [from beta site] Ring Edit Items problem
    3PP937BQExpress VI has a weird signal name
    3PPF3S7GSim Installer doesn't put icon on splash screen
    3PR7TPYZlabel on timed sequence disappears while typing new one
    3PREJBSQVery Slow Editing Behavior when using multiple TDM file storage VIs.
    3Q2906VIPath Leak in k_PathList Case of CPrefBag::GetStringProperty in PrefBag.cpp
    3Q2GKQZAHelp does not launch from the options dialog within Variable Manager
    3Q3GPD7FXControl Base version test problems.
    3Q4DEN00NI Service locator security settings
    3Q51MPTMThe TimerQueueImp should be more efficient when the Queue is empty.
    3Q691JUZReplicateConpane call is failing when a RealMatrix Control is wired to Connector pane
    3Q6D816EWhen I right click on the poly-vi selector for the DAQmx Write VI, the selection doesn't change
    3Q6G2N00Sometimes floating palettes are not in the correct format after relaunching LabVIEW.
    3QADHG9IAborting the caller of a custom XControl method while the method is being debugged does not work
    3QB75DAPFind All Instances for a VI sometimes doesn't find static references
    3QD7T7OECopy-Paste behavior in the project window is not consistent with Windows
    3QKEHPKULabVIEW does not refresh the control after its visibility changes
    3QPDR5PKduring download, VIs are being asked to save when there are no user edits
    3QPFL5KZSet Properties Storage VI Overwrites Channel Name
    3RDH5NHAProject add file operation on a library did not fix variable source linkage.
    3RLAKUM8Need to implement "restore buffer" on LabVIEW sound.
    3RS8AOYZCannot debug XControl in subpanel VI
    3S0FP100Enable debugging ini token doesn't get written if build spec uses ini file from project on mac and linux
    3S1BA9ZCmanager/extcode.h conflicts with WDT
    3S7EHR54auto run vi without scroll bars resizes when going idle
    3SFGBN0PVariant control contains a blinking cursor when dropped
    3SJ9FOJ1The Signal input to "Write Data" block of the Storage VIs should be Required input
    3SL9KCSHMathScript function "whos" does not return bytes information
    3SLBDUBWLibrary property returns error in runtime -- needed by instr drivers.
    3SQ957O7When you click CTRL + right-mouse to open the functions palette, this will open Express VI's FP but
    3SSGL672Wrong calling convention setting in CLN crashes LabVIEW
    3T282I1Wmarching ants around non-rectangular regions
    3TBBS99ZVI Diff does not notice difference in block diagram cluster constant values
    3TID16BFDiff of identical VIs shows event structure differences.
    3U19DT7KOverhead of call to .NET assembly performance in LabVIEW
    3U59JQJ1Source distributions should allow renaming files
    3UMFP5V9Security - You can configure "disable special keys" even if the kbdfilter driver is not installed
    3UMG32CEclean the code of filename parser
    3UR7MCCIImplementation of Matrix Left/Right Division
    3V1FJOYE"Write data" storage VI dialog does not allow some waveform properties
    3V5BLTOCOnly part of the Front Panel can be accessed
    3V68J1FNHovering Over Primitive Terminals Looks Strange
    3V6D4V84IDVI Creator -- created VI doesn't show scrollbar scroller
    3V6E7JF2File>>Exit does not work after launching Tools>>MathScript Window...
    3V7GOJ3O"Unset Busy" mouse cursor function does not work right
    3V8AECN8Pop-up for combo box selection isn't case sensitive when pre-highlighting what was selected
    3V8FC83PDAQmx Base Drivers not able to be weakly linked
    3V9BL9SQProgrammatic Front Panel State from Maximized to Closed Transition has a Standard State in between.
    3V9E44R6Question marks show up on a standard LabVIEW palette after editing it
    3V9EMJN8File dialog function context help links to file dialog express VI help
    3V9ESAN8express VI gives an error with an ugly source (instance VI names) if you push cancel
    3V9F1DN8example referenced by the File dialog express VI help contains the file dialog function, not the VI
    3VGF5A1WVI not added to save pending list when edited with control prop page
    3VKA8FNBVISA prims constants "create" not working for all cases
    3VKEBLNRIf you launch the MathScript window immediately after the getting started window, you can't make VIs or projects.
    3VL9RI00Invalid characters in Tools>>Options>>Web Server:Browser Access and VI Server:Machine Access cause icon to not display in access list
    3VLEO3SQADO access causes VIs to recompile if timestamp differs between machines.
    3W38AH1WUI issues with Acquire Sound config page
    3W3AFLZURenaming a project actually creates a copy of the project file
    3W3FGPIQUnpredictable results when clearing waveform chart.
    3W4G45ZUBrowse on the FieldPoint I/O control without the FieldPoint support VIs installed causes LabVIEW to search for FPLVMgr.dll
    3W5HFSBSLibrary Additem Method has a vague error message
    3W69OR7RExecutable Created in LabVIEW Open Two Taskbar Items
    3W99SSKUNeeds documentation
    3W9CS3WBImplement more robust naming scheme for imported Web Services
    3W9ELDHLOld bounds does not get invalidated when Update Image and Bounds is called.
    3W9H1871Free cursor on MSG doesn't update correctly when plot area is resized.
    3WA6N34IExpress VI - preview is not displayed for frequency of 100k
    3WAES700Some Examples that ship with Base package should not use analysis VIs
    3WBA04FKRT App Builder is not writing over Read Only files when rebuilding an exe
    3WBAKOU1Rename from Input/Output Terminals of script nodes does not work as expected
    3WJETBPWMathScript build application causes name collision warning
    3WOA5CHOVarMan has trouble with processes that have dots in their names
    3WODMQX7Web Service Importer doesn't add to the project
    3WOE9EGQInternal warning with really long text
    3WRBFH00Build-->Source Distribution-->Preserve Hierarchy behaves incorrectly
    3WSI5DMQDrag and drop sometimes makes VI windows stop responding
    3X0GLPMQCreating a .c file from a Call Library Node outputs code that doesn't follow coding conventions
    3X19RNZUProject opened from example finder appeared behind the getting started window
    3X2DIGNBAdding icon from Build app dialog, does not check out project
    3X3FCIN8Open VI Reference function gives error 2 (memory is full) if the user presses the stop button in the loading dialog
    3X4BA800Crash when not enough space for intensity graph y scale
    3X77JIVRDouble-clicking title bar restores window even if Resize is not allowed
    3X7BJIXCCan't get ALL VIs in memory any more in LabVIEW 8.0
    3X7CTDBWdll wrapper: If custom control selected, users must provide cust control path
    3X7DLM00LabVIEW 8.0.1 error log file: fuctionbrowser.cpp line 4561
    3X86KM7RSlow Performance with Event Structure and Array
    3X8AO4OZInit Joystick VI fails
    3X8CM0NQNo scroll bars on block diagram
    3X8D92P2Behavior of "Result Name" configuration section in [Time Domain Math] Express VI is odd.
    3X8EMNPIConditional disable symbol poor error message if no value entered
    3XBA4NAORemove Broken Wires shouldn't touch the Disabled frame of a Diagram Disable structure
    3XBBRHJ1Cross-context undo confuses autosave
    3XBE61R2Import Shared Library dialog does not grey out the Next button if destination field is cleared
    3XCIAAMQDragging mail item onto project window crashes LabVIEW
    3XFABCBWvoid return values should not result in a generated control
    3XFAHUBWselecting "enter" when in description field moves to next page
    3XFDJORSData on control differs if dragged from .ctl and from project
    3XGCOFFRSdf saved in desktop target doesn't rescript when opened in FPGA target
    3XGDQSMQCLN brings up search dialog even when it should know where the DLL is
    3XH6461WMass compile method should have a "cancelled" or "stopped" output
    3XHDID0SClicking 'Edit' without choosing any controls (or indicators) causes an error in 'Front panel binding mass configuration' dialog
    3XIF7TA3DLL Wrapper tool should remember the last DLL and header file used
    3XIFG9A3Input output pairs should have corresponding positions on connector pane
    3XM7IS8Wtype command does not work with built-in functions
    3XMFHJJ1A password-protected lib can be dragged into and out of an owning library without supplying password
    3XMHKJ3ECannot select Library file for updating.
    3XP7QAAPChange to control does not keep data on fixed constants
    3XP9L5QOActiveX Property node hangs when passed an invalid refnum
    3XPCODE9MathScript Butter function does not accept common syntax variation
    3XPCP1E9MathScript cheby1 does not accept syntax variation
    3XT9HLPJSave As.. should not be disabled on unsaved projects.
    3XTEHM7FReturn value setting page of functions
    3XTHBM9AApply changes is sometimes enabled when it shouldn't be (or is not disabled when it should be disabled)
    3XU8G9BWSuggestion: Set icon in lvlib properties to match VI banner
    3Y091URMSize of Constant array parameters should be enforced
    3Y0AIOSQFront panel covers windows task bar when the "Window has title bar" property is NOT set and VI is maximized.
    3Y0B5AVIChanging to run-mode in dialog VI will "un-maximize" it and will not restore when complete
    3Y0BLPBWWrite Data Storage VI: table selection and edit UI issues
    3Y0BQJJ1The source palette feature isn't working for VIs in the Connectivity>>SCC palette
    3Y0CB6MOGlobal variable created from palette not reflected in the project.
    3Y0CKI3ZTabbing in causes error
    3Y0DHCBQKnob doesn't lock if scale min/max doesn't fit in numeric representation
    3Y0EARMQfini() and init() should probably just be ignored.
    3Y0EAUMOSubVIs that don't show up in a VI hierarchy show up when you print VI and subVIs.
    3Y0EL2NMInternal error in drawmgr2.cpp: 350 (ValidateImage() failed)
    3Y19IO1Wbad error for conditional disable without a default frame
    3Y19PFFNRenaming Grandparent Class Makes Test Fail
    3Y1BM41Wconditional disable test needs updating
    3Y1DAHLGLabVIEW 8.0.1 error log file: support2.cpp line 800
    3Y1G8DCSLibrary "project" window has Save As disabled
    3Y4G9200TDM User Defined Properties -- When dataType is set to double, numbers like 1.23e-8 is not accepted.
    3Y5AFB1Wsetting tab order of controls on a typedef'd Tab Control doesn't work
    3Y5AK61Wconverting tab control to typedef moves its owned controls
    3Y637D00array allocation
    3Y69LT2Jimpz carries forward previous freqz magnitude response
    3Y6AMOP2Right-click replace menu on Express VIs don't have quick menu.
    3Y6BLOLGMultiple event structures crash LabVIEW when dynamic events used incorrectly on a Dual Processor computer
    3Y6FO5AFVI screen position does not reflect VI properties
    3Y78SG5UDisplay Path to Palette File... needs to be more user friendly
    3Y79QFU9LabVIEW 8.0.1 error log file: fpselsup.cpp line 3669
    3Y7A348Wtitle command adds second title, not primary
    3Y7AOMF7Some menus on project window intermittently go invisible
    3Y7CKU00crash when closing a custom probe that leaks remote app references
    3Y86TQ0XVI names with noncompliant Windows names
    3Y8DJ6MIxlabel function returns an error in MathScript
    3Y8DM2MIylabel command returns errors in MathScript
    3Y8DP7MIThe title function returns an error in MathScript
    3Y8DSSMIThe legend command returns error 'invalid number of output parameters'
    3Y8ERRNRSource Distributions under My Computer and other targets default to the same destination directory.
    3Y8FJTMIThe legend command returns an error in MathScript
    3YB5QP00Invalid Reference Error 1055 When Calling a .Net Constructor in a Re-entrant VI
    3YB9O271Cannot change y-scale to binary from property pages.
    3YBE53ORdec2base should pad zero on the left
    3YBGGJK9Error Window lists no error while VI is still broken
    3YBGQNORmat2str returns incorrect result for NaN input
    3YC9G21WUnexpected data in controls from Import Shared Library if going forward, then back
    3YCA3GP2Scrollbars on picture control don't move while image does.
    3YCABDRMNew... gets the frontmost project for default instead of project for frontmost window
    3YCAO1OZLabVIEW Project New... presents a LabVIEW load dialog while loading
    3YCBAJOZThe LabVIEW Search Dialog takes a very long time to present the first time
    3YCBOKBWDLL build provider. Define Prototype button not disabled when it should be.
    3YCCH900Build Provider: Remove panel option enabled for dynamic VI when it shouldn't
    3YCCQ8YZScroll bars not active
    3YCEF207Creating New from Template breaks template VI if it is open
    3YCGGOGQNo specific help on Graph or XY Graph preview panes
    3YDA5KJ1File>>Close All while stopped at breakpoint in XControl Facade permanently locks UI
    3YDDRSDPSize defined for non-double type matrices
    3YDESR3AUsing Typecast Functions Inside of a Diagram Disable Slows Performance
    3YEAQSUGUsing up/down arrow keys on radio buttons in a subpanel causes focus loss
    3YEEEV9AIssues with VIs with variables patching up correctly to their variables, especially when the variable library is open but not in the project
    3YEELDMQLLB dialog allows multiline filenames
    3YFA7Q3Zfprintf command has an extra output.
    3YFCOTBWVI not added to default app context so doesn't show up in SCC
    3YHEKT00The Browse for Domains Dialog Box doesn't have a help button nor does it react to F1
    3YHFS06Rreturns an unknown symbol error when using the command linewidth
    3YI6OCPKFail(or warning) to connect to RT Target from the different machine than the one which deployed VIs.
    3YIDD900Slide markers fill glitch
    3YIF8A1WSave As Rename to move a file without changing its name doesn't update display format of MRU list
    3YIFOMMIMathScript fprintf function returns error in LabVIEW 8.2.
    3YIG97Q2LabVIEW Host crashes after running a few hundred of tests on RT when it attempts to programmatically close a test project and references to its VIs
    3YJ7P8DPMatrix Conversions in MathScript are never "Correct Complex"
    3YJCDLBWicon editor: Can get in state where copy from button incorrect
    3YJCS3P2listmenu.cpp, line 4291 internal warning when showing LabVIEW Class hierarchy window.
    3YKA31P2User access error in Perforce Command Line Project Options dialog when browsing users.
    3YKBP23ALabVIEW 8.0.1 error log file: Transact.cpp line 1378 results from an event structure and local variable
    3YKCP7P2Library-only project gets dirty dot after revert after an undo check out.
    3YKFCSZUIf I copy a single-process Variable in the project tree, and then edit the library using the multiple variable editor, the variable will have the default network variable attributes set in the multi-column listbox
    3YL76N00pane background image uses junk data to remove the background.
    3YL7F7GQConfigure User Defined Properties F1 doesn't work.
    3YL9L00CPrinter Setup (Linux) Dialog Box component needs label
    3YLD9HC3Good/Bad internal warning when loading a recursive Typedef (proptype.cpp line 411)
    3YLDO700Next Available File Name Continues to Increment After Files are Deleted
    3YLDRRC7Write Data Storage VI Test Issues
    3YLEAI1WRename of untitled VI in different to an existing name should fail
    3YM9OIN8system VIs and other things that shouldn't show up under dependencies for a closed VI
    3YMA5P00Problems building application from if LabVIEW Class uses typedefs when disconnecting typedefs
    3YMBE4P2Listbox in Browse dialogs of Perforce Project Options does not go back to top when toggling filter checkbox.
    3YOHCMBWID VI Creator: Copying from a template is slow.
    3YP5R9U1LabVIEW shows a curious error message when trying to view DAQmx event help
    3YP75S1Wblock diagram window state not honored when instantiating templates
    3YP9NPJ1"New>>Override VI" needs to preserve a lot more aspects of the source VI
    3YPAHD7XFix label of Window runs transparent option in Customize Window Appearance DB
    3YPCFD7XNew Directory or LLB dialog box and New LLB dialog box have empty labels
    3YPD711WFind - select VIs by name shows ugly Express name
    3YPDCE00Import tool gives wrong error if it fails to open shared library
    3YQ8RCTOError 1019 when canceling save for subVI with SCC
    3YQA62CSFormat and Precision Advanced editing mode claims %.0f is invalid
    3YQAA0J1Two internal warnings when owning library cannot find sublibrary
    3YQBEJXELabVIEW error log file: 8.0.1 exec.cpp line 2483
    3YQDAMV9Apps can programmatically launch a Project window
    3YQDOKQOWindows menu should clip window captions at a sane length
    3YQFM32SMSG cursor movement buttons aren't draggable on Front Panel
    3YR8O71ILabVIEW project build specification issues after upgrade from 8.0
    3YRAUKP2bdselect.cpp line 6991 when changing context with block diagram wire selected
    3YRB75DPfminbnd Suffers from Initial Condition Selection
    3YRCPICSFind All Instances right-click on dynamic member VI finds nothing
    3YS86200Properties panel of a system listbox control
    3YSD39P2Loading dialog displayed when drag/dropping source controlled files to project.
    3YSDOLAOA VI that has been created and saved programmatically doesn't have Block Diagram scroll bars, even if they're needed
    3YSEHHYZLibraries incorrectly placed when adding folder
    3YSFEJTOlabel property for pane option is not settable
    3YT9H2QXSlow performance with LabVIEW 8.0.1 using a dual processor machine
    3YTAQ9XELabVIEW 8.0.1 error log file: IntCmds.cpp line 1324
    3YTCDISFMathScript fprintf function doesn't work with strings
    3YTCE0MXDestinations don't work correctly when project file is moved if path relative to root is shorter
    3Z294MCEfopen doesn't return error correctly
    3Z2CKRORmulti-line plots should not use 'w' option
    3Z4APGMOI can't multi-select feedback nodes.
    3Z4LF5WJwaveform graph starts infinite loop
    3Z5CANYZNew control under library does not get library icon
    3Z5D7I0SArray of String type not supported?
    3Z5DM57PPlease confirm English string for custom Run-Time Menu Items
    3Z5EQU0SSetting "single writer" variable option problematic
    3Z5FDSTOSource distribution Build provider UI verification.
    3Z5GSP54internal error, bdselect.cpp, 6993
    3Z5KFOEVConfig file reading significantly slower in LabVIEW 8 than 7.
    3Z68R900Complex waveforms are not supported through ActiveX interface and C-Interface
    3Z6B4HDPIncorrect empty string comparison
    3Z6D39KYVarMgr: Using some menu options in Variable Manager causes a crash on exit
    3Z6DG7P2Closing project item references takes relatively long time when many project items are selected.
    3Z6IGEC3Internal warning when wiring 2 broken wire segments
    3Z98GSXECan't resize Listbox columns when connected to Perforce
    3Z9A9HRSNo detailed help for droppable sub-VI
    3Z9AIV00Timed-loop scheduler does not properly handle errors due to invalid priorities, periods, etc.
    3Z9CFPWBWeb Service Import Tool Leaks Report Reference
    3Z9DKJLBError 1055: Object Reference is Invalid When Passing an Image Control Reference to a Property Node in the Run Time Engine
    3ZA82CQ3Internal Error fpsane.cpp line 394 when creating an indicator for a RefNum
    3ZAAD2QWQuit menu item becomes permanently disabled
    3ZAGOOIJPartial Fraction Expansion Fails
    3ZAHFM9AWe are somehow leaking a VI server reference with strictly typed static VI references
    3ZBBLT4USource palette is incorrectly cached across targets
    3ZBDC4LJCategory visibility is not consistent across all palette view.
    3ZBDFPBDWriting an array of paths to a network shared variable throws an exception and the values fail to transmit
    3ZBDT1A3Sound DLL examples should reference Sound VIs
    3ZC8RKMOProject properties window doesn't describe the project well.
    3ZCD7CBWImport DLL Wizard: Selecting Output Only for struct doesn't work well
    3ZCDKOSQLabVIEW 8.0.1 error log file: TDArray.cpp line 451
    3ZCER7X2Cannot copy/paste text from LabVIEW text control to KDE app
    3ZCF7KJ1Build Setting to NOT remove additional exclusions fails when library has missing members, and error message is not helpful
    3ZCG4DJ1Build app reports insane instance VIs in debug build only
    3ZCGQDP2appserver.cpp line 2632 when repeatedly starting and canceling compiles
    3ZCKNB54save project for previous has items under dependencies
    3ZDAJ8CSVI panic stops - cannot find dynamic member VI
    3ZDC8F1Wsync context button appearing on private data control
    3ZDDI354running vi to evaluate conditional disable structure during load can lead to crashes
    3ZDE2C00Calls to Defer/Resume ErrWinUpdates can be unbalanced
    3ZDGGR00Property nodes with bad references to DLLs cause LabVIEW confusion
    3ZG7HD1YCursor Movement Tool Only Moves X-Axis for Intensity Graph
    3ZGF8D1WSetting destination blending function to "source alpha saturate" internal warnings
    3ZGFP4SQMulti-Plot Cursor on Mixed Signal Graph Doesn't Snap to Plots - Instead Follows Function Corresponding to the X-Scale Multiplier Value
    3ZGGP7BDex_getDAQmxAttrFromRcFile fails to mass compile in LabVIEW
    3ZH7GSD0There is no prevention of installing one locale of LabVIEW over another.
    3ZH7URVIEdit Items property page has horrible performance when editing large rings/enums
    3ZH824VIEdit Items from properties has warning message appear that prevents user from being able to commit enum/ring control edits
    3ZH9DBV9LabVIEW will crash if you try to programmatically deploy a non-library file
    3ZHD1M00memory.cpp line 342 internal error when opening a VI on German OS
    3ZI8DUBDMouse property cluster of the picture control allows user to change to write, even though the real property is read-only
    3ZI9214JTo undo several deleted XControls hangs LabVIEW
    3ZICBLDXpersistent doesn't work for more than one input
    3ZIEH1FNAdd To Source Control on Top Level VI Adds Extra Dependent Files From LabVIEW Distribution
    3ZJ91BW0Enum Property "Named Numeric Color" missing in LabVIEW 8.0
    3ZJ9C3C3Missing buttons Load/Search/Save dialog box when Mass compiling
    3ZJC7EGXXcontrol doesn't update when writing to its value property while panel updates deferred
    3ZJDR1MQthe build spec's Item_Init VIs are not being called when there are multiple build specs
    3ZK8IIRMBuilt dll does not have get info description
    3ZKC3M41Interpolation of plots
    3ZKDRJN8Target Folders can't be dragged/ctrl-dragged between projects, but they can be copy/pasted
    3ZKDT2N8ctrl-dragging a target folder within the same project lets you create one with a duplicate name, corrupts project
    3ZKF8T54crash loading certain project
    3ZKIEQBUBuiltTargetBuildSpecification.vi doesn't work correctly when run in a project context
    3ZNC2Q3AUser interface interactions block the Write Data Storage VI.
    3ZNEFJKTDirection Cosine Matrix to Eular Angle VI gives a wrong result when theta equals to zero.
    3ZO7H0RMUsing a stock osg library on the mac will crash LabVIEW when using scene stuff
    3ZO7JQN8VI open in two contexts has green arrows and is broken
    3ZOA7KN8IO Node gets out of sync with project item changed during edits to the VI in anther context that are later undone
    3ZOAGDORmeshgrid should return complex result for complex input
    3ZOALI9ZStatically depending on a LabVIEW built dll will sometime crash on load (with an access violation)
    3ZOB6H1Wpasting image in control editor doesn't cause apply changes
    3ZOCJMYZWaveform label moves when components of control moved
    3ZODFHORisdir always returns error
    3ZOF48N8error dialog canceling the renaming of a lvclass
    3ZOFG7M0Source Distributions that exclude vi.lib exclude any files in any directory vi.lib not just the LabVIEW vi.lib directory
    3ZOFOLRMnative pictures (PICTs) are not visible (picFrame rect endianess problem)
    3ZOFQ8N8convert contents of control to class lets you add a class to a locked library
    3ZP8EHN8OMUDClassLinker.cpp after copying and pasting the private data control of one class to another class
    3ZPA6100If you change a Variable's Data Type(from non native to non native) and then redeploy, the prototype for logos doesn't get updated.
    3ZPAH8TMwe should only rely on TagMonad attribute helpers to handle unknown version case in situations where we can't determine the version
    3ZPCSOM0Build Text [Express] VI is always broken after user enters incorrect Text with Parameters in Percents
    3ZPE77RMMulticast UDP cannot have multiple connections
    3ZPFK900Context Help was not imported for Read/Write to Spreadsheet File VIs
    3ZPGHRPWMathScript tries to call a function if variable index is out of bounds
    3ZQ6HH1WUnopened SubVIs menu doesn't scroll in text mode
    3ZQA41CEVI running very slow on dual core CPU.
    3ZQC7MCSUndo does not restore window bounds
    3ZQFTLG8Write data storage vi stores incorrect timestamp value
    3ZRBJ5RCCopying and pasting a LabVIEW chart axis to Word
    3ZREKDKQMathScript - Bitget (0,1) returns wrong number
    3ZRG46MQStatic VI refs can lead to permanent reservation of VI
    3ZTJ0C00Build specification has trouble specifying a destination
    3ZUA16P2Selecting radio buttons of Call Setup on an unconfigured Call By Ref node does nothing.
    3ZUD6OFKBuild All function does not show a build status window for each target
    3ZUE8TMPAdding a project variable to My Computer causes VIs with large hierarchies to deploy very slowly
    3ZUG1BXEDynamicBreaksAtMaxMin.vi not allowing the edits for numeric and string constant
    400C6EP2"Convert Build Script" menu item shows up in FDS version w/o App Builder and can cause hang.
    400D32ZUTagMonad::attemptLiveEdit() should destroy unneeded source connections if the tag no longer requires up front connections
    400D7T8VQuit LabVIEW doesn't work in conjunction with Exit Application (Application Instance Close) event
    401E4R9AListErrors is not called after a popup click selection
    4029NIYRIf lvlib contains a bad path, Mass Compile neither reports the issue nor fixes the path
    402C2SGBCopy Data results in image with data not inside chart window
    402GS0J1Class Properties>>Change Inheritance dialog needs to use Defer Panel Updates
    4036J31WAdd to SCC prompts to add dependencies that are already in SCC
    403CT2PWStrange behavior of generated graph indicator on ExpressVIs
    403FDTRMDynamic Input Type Propagation to Dynamic Output does not pass through Disable Structure enabled diagram
    4069F7TQFilter Express VI - Default instance does not export 'Lower cutoff' as input parameter
    406AKPOFMinor problem with BODMAS rules on Function Parser shipping example
    4079OHORclear plot window should also reset Palette:Active Tool
    408EB5PWParent VIs without block diagrams are still broken when its subVI is finished running
    409F1MXEBad things happen when the Destination file path is
    40A225QQGraph's don't autoscale in inactive tab
    40A9OABWImport DLL Wrapper - XML file only remembers info in last run.
    40ABD81Wmemory leak / performance issues with 3D picture control (render window)
    40AFBLBWTools Options page -- needs to handle broken pages more gracefully
    40C9HTYVLabVIEW localized installers don't have description for the LabVIEW main feature.
    40DF5I1WFP Close not handled in TDMS File Viewer
    40E8RAV9Front Panel Binding Methods should work at Run-time
    40E99HO7Cannot have two different examples, for different drivers, with the same name
    40EB37IQLabVIEW 8.2 error log file: drawmgr2.cpp line 127
    40EC8JP2Cosmetic issues with Context help window image of Call Library Node.
    40ECNNP2Path input on Call Library Node is misnamed and had incorrect icon image on node.
    40EECLPWMathScript matrix indexing doesn't expand column vector correctly
    40EGPQPWMathScript handles empty matrix indices incorrectly
    40FG0BDLDiagram-enabled Sim nodes have some discrete subVI functionality
    40GADAG0Opening a Project from the Example Finder Doesn't Add Project to Recent Projects
    40GALSU7LVOOP Example VIs are not mass compiled
    40GG7QORtext is not remove correctly in subplot
    40HA3R4JXControl example can NOT work in Web Server, crash LabVIEW
    40HD8V9AUse of member variable after this has been deleted in HeapToVINamedLinkRef::RemoveRef
    40HFH700List Folder does not resolve symbolic links
    40K7M7QGFormula Node Error not recognized
    40KEODJ1m_cacheValid insufficient for hash testing for most TDImps
    40KGTT0QLabVIEW hangs after using the exit ( X ) button to close the Tools>>Security>>Login dialog or the "Tools>>Security>>Change Password" dialog
    40L8C4APinternal warning compare.cpp line 935 comparing some VIs
    40L8NEAPCrash doing compare VIs on some VIs
    40MA3PCDClicking on Domain menu of Domain Manager when no local domain exists crashes Domain Manager.
    40MC40MOWhen I select Run on a VI in the project, nothing happens.
    40MET2LYCall library nodes don't maintain parameter list properly
    40MF93UZVI server method App.Get VI Version generates file permission error when file is not a VI
    40N6PON8changing the private data and then manually changing version of a class without saving leads to "corrupt" VI , class left hanging in memory
    40N96DVFAttempting to Use ftp or http DataSocket Protocols Causes LabVIEW to Crash
    40OCQ300VI Server method GetVIVersion does not propagate the error code and message when called through LabVIEW ActiveX server
    40OG895PCall Library node creates wrong .c file
    40OHB5O1VISA Property Node Cannot Compile after Being Copied
    40P4335WIncorrect behavior in the XControl shortcut menu
    40RD2561Control with empty label will make LabVIEW crash
    40RFKAMPPinned palettes stop working after creating a constant from a timed loop configuration node
    40S8A0JGConvert tdms to tdm.vi does not work if tdm file does not exist
    40S9BSJGExecutable gives labview.lib was not called from a LabVIEW process error when Enhanced DSC support included
    40S9BTPWMathScript indexing expands scalar incorrectly
    40SDE400LabVIEW 8.2 fails to save for previous with SIT 2.0 client upgraded to SIT 3.0
    40SE51BRProblems with InRangeCoerce and arrays of clusters
    40SFLMV9Configuration settings for disabled Shared Variable properties should not be deleted
    40U91O00LabVIEW should not let users do project tree operations while a rename is in progress
    40UB9KAPRun button on reentrant clones not updating correctly in some cases.
    410AJSJ0The # Modifier for Time Format Codes behaves incorrectly in LabVIEW PDA
    41486QLGTracking loop not aborted when modal VI comes to front
    4149KSCMUnable to choose a custom control residing in a LLB when creating a variable
    414APBJWGraph axes with cursor movement
    41598HHHBowl Latest Agilent 34401 Instrument Driver
    415ECP00RTE hangs when loading a VI that calls a LabVIEW built dll
    415FHQN8instr.cpp line 6242 and crash doing "Open Front Panel" on a newly created instance VI
    4169D2J1GetType.llb does not have any type inspection support for LVClasses
    416FODTTImport Shared Library Wizard Hangs with a Struct Containing an Array
    417FGHN8undo.cpp line 4428 inserting a diagram into a subpanel in a VI that immediately finishes executing
    417FGLKQLabVIEW 8.2 error log file: transact.cpp line 244
    41A784P2Remove searching of subVIs in disabled frames of CDN and DDN.
    41ACKJCISTL Files Take Too Long to Load
    41ACT3N8Open.VI From Buffer method shows a dialog warning of new locations of subVIs
    41AD3TN8Open.VI From Buffer method throws an error dialog if given a path inside a .llb
    41AEMRPWMathScript write indexing of non-existent variables using colons
    41AFFJLGAccording to "All VIs in Memory" property, open vi reference doesn't seem to finish loading sub vis
    41BA0BLNMulti-Line Scripts [Ellipses + Enter] require Shift+Enter in the command window
    41BA9HLNlegend off
    41BAQFXCHard to see block diagram of a VI in a debuggable EXE when using a custom menu
    41BBAO6QAdvanced Refinement does not return correct results for 2nd order polynomial.
    41BCS9LNMathScript - call EXE
    41BCSMLNMathScript - history window
    41BCUJLNMathScript - error message in conjunction with path
    41BD0DLNginput
    41BEEHIJPartial Fraction Expansion doesn't give the right # of poles
    41BH1VBSNI PSP Server Locator causes Safenet's Sentinel Protection service ( spnsrvnt.exe ) to crash
    41C839TZWebService Methods with More Than 8 Parameters can NOT be Imported
    41CAIEP2Minimum size control for C String Pointer setting on CLN parameters tab has unclear usability.
    41D5GEXIChanging the value of a slider using the increment/decrement control generates two value change events
    41D9NL3ZLabVIEW 8.20 Search Feature is Unreasonably Slow
    41DCMKN8LabVIEW claims to not have enough memory to compile this (fairly small) VI, exec.cpp line 2229
    41DCONP2Controls are visible in VI Metrics page when resizing window.
    41DGI1R0Number of threads/priority hard coded to 4 - even on 8 core machine.
    41DH7DKZShared Library Import Wizard Hangs and Crashes
    41E76FCILeft/Right Division in MathScript Should be Improved
    41E9LKYZProgrammatically relocated VIs in library still show SCC icon when moved
    41EBTL3QStrict Typedefs in VIs hinder Source Code Management
    41HBISJ1Project always gets docmod when loading LVClass from any pseudopath
    41I8K8ZUThe IConfig interface does not prevent callers from creating processes with restricted names
    41I9GSA3Internal warning when hitting "Skip Subroutine Call if Busy" from subVI's popup
    41ICA31RInconsistent Scale with Panel Behavior in Panes
    41ID3200Option for clear indicators when called
    41J8PLX7Web Service Importer does not handle proxies
    41JAI3DLCreating a new Subsystem crashes LabVIEW
    41JCCDLGLabVIEW 8.0.1 error log file: transact.cpp 238
    41JF4UQWProfiling gets wrong numbers for times.
    41K7AIKQeval function needs to be blocked from the run-time engine
    41K7RTIQUnexpected results with smoothing filter (filter express vi)
    41L13OXRProject aliases file is deleted when you build an EXE in the same directory as the project
    41L94H2KLVClass Custom Probes slow down LabVIEW launch considerably
    41LF9DN8Empty error list with bad link obj, plus a internal error in compiling NXT toolkit VI
    41LFEPDLMutated Subsystems search for instance VIs
    41MI193QSetting Timed Loop Priority Above 65535 Generates Error -820 or -818
    41NHT2ZQOpen SubVI front panel height increases after execution
    41OD9TMXCustomize VI settings dialog can hang LabVIEW
    41OE5KR7Apparent crash in EditablePaletteMenu::CreateTempCategoryMenu()
    41OFP3Q4LabVIEW crashes in LinkRef.cpp, line 875.after doing Save As on a reentrant VI
    41OG52LGLabVIEW 8.0.1 error log file: transact.cpp line 238
    41P6RV1Wconstant folding options don't work in a project
    41PE6IDURing control's "Show increment/decrement buttons" item grayed out in property pages
    41PELAC3Cannot use a custom probe that's a member of a class.
    41PEO6C3Dynamic VIs should not be listed as valid probes
    41Q2I390DataSocket Server Manager does not commit changes to Predefined Data Item's data type
    41Q9GA9ZTab Control not handling localized strings correctly
    41QF95GIshould not generate structure if it is passed as a pointer
    41S82NIZLabVIEW 8.2 error log file: ctrledit.cpp line 2829
    41SA5OWAReordering items moved in project tree
    41SAHJN8In Range and Coerce primitive with visa resource wired to it has void terminal
    41SD625UFunction Block and menu items are not saved or loaded properly.
    41SE8NN8VI can't be dragged from project window to library window
    41SEB1N8LabVIEW 8.2.1 error log file: viwind.cpp line 1057 exiting LabVIEW
    421B08MXLinkerInfo returns Unknown Type for nonVI files in a library when linkerOption is Include All
    421D7PPWMathScript 2D write indexing of vector with one colon index doesn't allow valid sizes
    421DFQ00Renaming class method and then renaming it back leaves VIs broken
    422C4RPWMathScript Indexing: 1D deletion always returns row vector
    422E4ON8if visa open to remote device fails in parse, it shouldn't turn around and attempt open anyway.
    423B8U9ZRead from Binary File does not indicate the default value of the count input
    4248T5SFMathScript should have the fseek function
    42492SSFfile functions should work in RTE
    4249DBSFContext help for File I/O >> Storage VIs takes too long to appear
    4249HON8property node causes Error 2: Memory is full on a downstream invoke node
    424DMMPWMathScript help for user-defined functions only finds lower-case functions
    424EKTN8quick palette in right-click for rendezvous, semaphore wires is File IO palette
    4258ORZNDisconnecting typedef VI server method returns an error when invoked on a control
    425G1MJ1Internal error creating a new VI if the new VI name collides with a library's VI name when the VI isn't in memory currently
    4284R490Unable to edit cluster label once the position default is set to "Left-Middle"
    4289P9CIDrop a VI on Front Panel With Controls Grouped Crash LabVIEW
    428AM4B4Opening and closing a clone VI results in performance degradation.
    428BOG2Jfprintf in MathScript should not require a variable to be specified.
    42A9HMRMProgrammatic Build DLL returns bogus error
    42B7JIP4Increasing text size of a label or floating text draws extra lines and corrupts the text (changes to "=")
    42BG33W4App Builder sets EXE description field to be filename without extension
    42BI4OO5LabVIEW 8.2 error log file: save.cpp line 821
    42C9GJ00VIs in project\webdoc.llb are not set as system VIs
    42F7IUIQLabVIEW 8.2 error log file: lvexcept.cpp 127
    42F97CIQLabVIEW 8.2 crashes with a SplitPanels.cpp line 1148 error when dragging string into sub panel
    42F9B6SQStrange Inplaceness Error when using Solve Linear Equations VI
    42FBS9N8private data control of class ends up with green arrows that won't go away
    42FCGHN8editing a typdef that's used in the private data control of a class can unlock the private data control
    42FDT100Crash opening VI that thinks its owned by a class by the class doesn't own it
    42FK13KQLabVIEW 8.2 error log file: CopyAccumulator.cpp line 39
    42G9TTK9Adding controls to an existing dir.mnu removes the function palette info
    42GABRIGLabVIEW 8.2 error log file: graphcrs.cpp line 1724
    42GGBA0SLabVIEW tab control doesn't display correctly at LabVIEW first launch
    42H1PS00get type and creator vi - bug on Mac-intel platform
    42HG4DN8disconnect from typedef method on a control crashes
    42I81T9ZWaveformgraph cursor locked to multiple plots is not drawn correctly
    42I82IKUBehavior of ILogosRealTimePoint2::GetBufferUsage
    42I8910SLabVIEW window can NOT get correct size change information from Flat Sequence Structure
    42I8HFV2XControl misses first property node call if another one is called while the Facade VI is still running
    42IB3FEKPrompt For User Input Express VI doesn't warn user when dropping on a cRIO-9012 RT target
    42IC6IK8LabVIEW 8.2 error log file: ThEvent.cpp line 152
    42IF117FFloating palettes not open in palette editing mode.
    42IHGKJ1Dynamic dispatch VIs with subroutine priority mess up the New>>Override VI system
    42J8I1MXLabVIEW crashes when I close the front panel of a VI with tree control.
    42JDKEGILabVIEW 8.2 Slide Control Cannot Be Changed to Hex Display
    42M1NJXNLabVIEW 8.20: X-Scales on Waveform Graphs can't be customized when Plot Names from data are used
    42M6QJ1WIndex array acting like an O(n) operation in particular use case
    42M9EJL3Fatal Error "undo.cpp", line 4356 when Creating Subvi from graph or chart reference
    42MDSRMXLVClasses can't be saved in the support directory if they contain override VIs
    42MF24J0LabVIEW 8.2 error log file: find.cpp line 1058
    42N3SHZPExecution Speed of "Color to RGB.vi"
    42NC7KXCUpdate the provider INI files with 8.2 license version for App Builder
    42NE8E5UBlockNode.cpp assumes node has 1 or more terminals
    42ODKF00LabVIEW 8.2 error log file: load.cpp line 3448
    42PDLIBDUndo quits working if you move an L:V Class function twice on the block diagram
    42PE02V9Static VI refs are lost in constant folding when diagrams are removed
    42PFD3BWCheck for .NET Framework 1.1 fails on Windows Vista 64
    42Q9KH5Mediting of nonexistent items is allowed in configuration dialog
    42QCCMZLExe Build Error 1003 - The VI is broken. Open the VI in LabVIEW and fix the errors.
    42QDJ9MQClipping warnings break SoundFileWrite
    42T7HT1Wtype descriptor shows wrong name in variant indicator
    42UETBZLChanging VISA Resource Name Class Crashes LabVIEW
    42UF33LGY autoscale scales axis incorrectly for multiple plots when some plots are hidden.
    4307S6P2There should be a popup menu on a block diagram FP terminal to open it's associated typedef.
    4308UJTZLabVIEW8.2 Crash/Hangs if CLN configures LabVIEW 8.0 DLL Several Times
    430FHR8Wfreqz function can output incorrect frequency axis (x axis) scaling
    430FQ7RKLabVIEW 8.2 error log file: cursorlegend.cpp line 666
    4313F7A4Debug Deployment Version String on print when using Easy Print VI Panel or Documentation .vi
    4317O6N8help for broken wire because of class conflict with user defined tag isn't helpful
    4317QAJ1Race condition in XControls when setting initial value using a local variable
    431823NQToplevel VI with BD removed breaks and stays broken if one of its subVIs is called as Top Level
    4319E900Changing class inheritance causes recursion error when call parent node present
    431DIQP2Performing a Save As:Rename on a VI in an LLB does not remove the original file.
    431EL9XXLabVIEW crashes when trying to 'Save As' (substitute or rename) subroutine subVI of a clone with its panel open
    431F6AXADigital Waveform Graph does not expand multiple buses
    4327HPU4LabVIEW 8.2 error log file: heaproot.cpp line 198
    4327IUN8UDP Multicast Open primitive has a help link that goes nowhere
    432DQPKJSound Output Set Volume.vi behavior incorrect
    432DTAPWMathScript 'le' function doesn't work
    4357EON8user data is settable on IO name control while VI is running
    4368PI3WIncorrect Floating Window Behavior When Setting Floating Property
    436A8OXCLabVIEW takes a lot longer to launch with classes in user.lib than it does with other files in user.lib
    436CDP00Import Web Service: Document needed when Cannot regenerate files in current LabVIEW session
    436FPTJ1LVClass automatic downcast not happening for polymorphic VIs
    4376S6UQSetting a Waveform Chart's YScale.Maximum, the Change Doesn't Always Take Effect
    43788G7UBuilding Source Distribution when preserving hierarchy puts distributed files in incorrect locations
    437BPDCIRamp Pattern Should Have More Generic
    438CE1PWApp builder can't find startup VI when building on Linux with project created on Windows
    438DUHF2SyncDisp Property of the Control Class Should Be Public
    43988U00LV Class in Palette has a big impact on palette loading speed.
    4398RUCSSource distribution lost my custom window size property
    439C1LXCLoading VIs that use LV Classes is much slower than loading regular VIs
    439CA5J1Updating project "Dependencies" with dependent LVClasses causes search for private data control
    439F7OCSCan't use Properties to edit items on an instance of a non-strict typedef ring
    43C2FGLFWriting NaN to Scale->Range->Start of a numeric control/indicator crashes LabVIEW
    43CA7LVBGet Image on a Cluster Loses Background Color Information
    43CCK4F2Make sure LabVIEW adheres to the right standard for whether menus fade in or slide in.
    43CGK1U4Menu Separator Error in Event Handler
    43D6K0N8datamgr.cpp line 1044 dragging an IO name control(with no user data) between contexts
    43DBOKP2Canceling path control browse button causes synchronize arrows to show.
    43DCCRP2Just in time checkout does not work for library only projects.
    43DGCUK8FindFolder to LVPath.vi works on PowerPC, returns error on Intel machine
    43DGJNFRInfinite docmod when loading LVClass VIs
    43E8H1J1Opening single VI gives multiple load warning dialogs for LVClasses
    43EBAAN8comparing an IO Name control with user data set to one without crashes LabVIEW
    43EEUKGQScrollbar control fires too many events.
    43EIIIQR- Library XML parser/generator inconsistency in Network:AccessType property
    43F77GN8CompareTDUserData() can't get a reply from TargetTagInfo()
    43FATIP2Arranging files under the Dependencies node causes project to become dirty.
    43FCKE00X-Scale label on graph in built apps becomes blank.
    43FCNN00Loading the enclosed project messes up the build specification
    43FCQVQ3D Picture Control: Find Object function closes scene reference when it has no children
    43FDQ4GQScrollbar control old value isn't right when operated by center thumb.
    43FEGF2JError in generating MathScript subplots
    43G78DP2Radio buttons on Dependencies node of Source Distribution:Source File Settings page are enabled when owning checkboxes are not.
    43G91GF2Unexecuted Code Gives "Memory Is Full" Error
    43G9K90SVI server method "AddItem to Library" crashes LabVIEW when the lib path is something like "aaa\.lvlib"
    43GDDIPIWeb Server is trying to open a text file that is being written to in read-write mode
    43GDMTTQSound VIs: Problems with simultaneous IOs
    43J5UL4IAn application's ini built using a configuration file other than LabVIEW.ini cannot be viewed on a client computer using a web browser.
    43K9CIE9Problems plotting of Booleans
    43KA46E9Export Simplified Image Color Problems
    43KA4S00VI names with non-compliant Windows names
    43KA7G00VI names with non-compliant Windows names
    43KAFD00VI names with non-compliant Windows names
    43KAFH00VI names with non-compliant Windows names
    43L7O5C1load VRML file does not load *.wrl file with color information
    43L8NBK8LabVIEW 8.0.1 Error Log File: ZUtility.cpp 219
    43MGADCEXControl do not support filter event
    43Q8RKC8GetLVRTHandle() call in eventRegisterFunction callback does not return the correct LabVIEW handle.
    43QDMRK8Write to cluster element in array via reference to the cluster element causes writes to the array via local variable to be lost.
    43RAJ3C5LabVIEW 8.2 VirtualInstrument.cpp line 2345 crash when shownonavdialog set in ini file
    43RCQI39unit_string does not contain the unit information
    43RE16RMFPathCpy called with NULL m_helpPath
    43REAIP2Decrement button is not below the increment button on custom control
    43RFGCN8setting user data on a IO name control clears the selected class
    43S2N4M7Running VI with XY graph crashes on graphcrs.cpp (line 1724)
    43S7R3ZUThe LogosRTClient plug-in should not use a replacing poster
    43S9EEZURace Condition in the ReplacingPoster can cause data to be lost
    43TAAHLNMathScript - eval - compiler loaded as dependency
    43TCNGW9U32 values greater than 2147483647 invalid as case selections
    4409N1N8TypeManagerObjects.cpp line 927 setting the same user data on a IO Name control twice
    440F7FN8IO Name control created through "Create SubVI" loses user data
    443AJ900LabVIEW development environment fails to load VI, but its RTE can load it just fine
    444876NKIgnore waveform time stamp on x-axes does not take effect
    4449TCP2Source distribution renames class members causing calling VIs to be broken.
    444A7TP2Source distribution preview returns error when using classes.
    444B2GO5LabVIEW 7.0 error log file: typemgr.cpp line 1018
    444CDDJ0Can't find a VI template called within a LabVIEW .DLL
    444HTHJ4MathScript Multi-dimensional Array Graphical View should have Multiple plots option
    4459PJVIFunction palette leaves permanent "shadow" on the block diagram
    445E3LXCImport Build script doesn't import correct directory locations for support files
    445E9JXCApp Builder needs to do a better job handling the project changing names
    445EF0BWInput/Output selections should have matching terminal positions
    445EMIBWBest to increase terminal pattern count than wire indicators to left side
    445FTUN8TypeManagerObjects.cpp line 927 dropping an IO name control as a constant
    445G12N8various internal warnings creating an indicator from an IO name control through a tunnel
    446987U7Need ability to add "detailed help" links in IVI rc files.
    446F9M00VI Corruption -- prop.cpp line 1661, insane typeID, and crash with a property node accessing the default value and user data of an IO Name control
    447GMSSNFIR Filter.vi does not give correct answer when coef length is 1
    449B6AHROverride VI is not created properly when created from a Read-only VI
    44A83LKQNested XControl crashes LabVIEW in instr.cpp line 8601 while doing Close-All
    44AC2R1RSet Scaling Method Fails In Run-Time
    44B8O5ZCPolyFit C entry point returns incorrect error when the requested poly order > 90
    44BAII00Pull LabVIEW Error Codes. Error when VISA not installed should say "VISA might not be installed"
    44BD4AG0extcode Template Files Point to LabVIEW 8.0 Directory Instead of LabVIEW 8.2 Directory
    44BG6LTDThe function drotmg API should be coherent in MKL and glapack.
    44BGAH00Update default values for Sound VIs on Macs
    44BGBM00Copy error messages for sound VIs into LabVIEW core error code list
    44C9E7BKGarbage in Waveform Attributes Coming from Shared Network Variable
    44CD1KTDMore strict check is needed because the error code returned by NumericArrayResize maybe positive.
    44CD7OGKCrash saving a VI with a primitive with a ring control input inside a conditional disable structure
    44CDCQCYEasy Print VI Panel or Documentation.vi throws error when margin measurement system is set as Default
    44CE92Q6German LabVIEW 8.2.1 Help>>Web Resources link takes you to English page that talks about LabVIEW 6.1
    44CGOBQ6Exe Builder error when browse to certain icon files (Vista)
    44DAF4JMFeedback node doesn't properly adapt to type when wired to compound arithmetic
    44DE5IO5LabVIEW 8.2 error log file: appserver.cpp line 3145 and LabVIEW Crash
    44DFNIF2Calling "Insert Node" Method to Insert a SubVI on a Wire Crashes LabVIEW
    44DFRN41Eval Formula String vi enters infinite loop when user enters incorrect syntax
    44DG7P7UUsers Can't Get References to the Main Application Instance or Project Application Instances
    44EA41N8IO Name control compare datatypes function and comparison primitives
    44EAMV00LabVIEW Application Builder stops working when adding a Vista icon to my build specification
    44EG9MPILabVIEW 8.2 error log file: window.cpp line 6922
    44H8HSHEMemory is full error occurs only in an executable when my for loop is not included within a subvi
    44H946ZUThe iak installers need to start our services
    44H9K76QFirst Call? should be inside the error handling case structure
    44HD2DCSSource distribution: LVClass to a custom destination doesn't put .lvclass file there
    44HGMCF2GetFrameIndex method on CaseStructure Class Does Not Work
    44HGPKF2RearrangeFrames and RearrangeFramesByIdx methods Do Not Work on Case Structures
    44I6SU00LabVIEW; throws ipcmeths.cpp(1612) internal warning
    44I9CHCIODE Predator Prey example does not match text with G
    44ICEMPQX Control properties don't update when on non visible tab control page
    44JAAQ7PGPIB Status Bool Array.ctl is missing in _visa.llb
    44JCGUUKLabVIEW Palettes don't recognize VI as an Express VI in certain cases
    44JCLPYULabVIEW 8.2 error log file: window.cpp line 21149
    44K1L1BWLabVIEW 8.x hangs when changing XY graph properties in edit mode
    44KBM5RWSome applications built with Enhanced DSC Support option (need DSC installed to enable this) display VI path warning, VI load search and file save dialogs
    44KE36XXLabVIEW 8.2 error log file: graphobjs.cpp line 70
    44KFJPNMshows up all black the first time you launch it.
    44LDHHYULabVIEW 8.2 crash in panel.cpp line 5403 when editing the range of a gauge control in an array
    44NF2SPJLabVIEW Generates lots of handled Access Violations when LabVIEW SignalExpress is doing stuff.
    44OGCN00Left/Right Division in MathScript Should be Improved
    44SB4H00LabVIEW 8.2 error log file: lvexcept.cpp 127
    44SB6700LabVIEW 8.2 error log file: lvexcept.cpp 127
    451GNJ00Crash related to Call VI By Ref and LVClasses and Context Help
    452CI7J1Performance & Memory profiler hard to use with class methods
    452G38E9MathScript: Default Search Path is hard to find & Path command doesn't stick between sessions
    4537JNOCCustom margins are changed when updating VI from 7.1 to 8.2
    453B40R0Error Log LabVIEW 8.2.1 in ObjDataPtrMethods.cpp 946
    453C5DU4Handling object references is much slower in LabVIEW 8.x than in 7.x
    453DI9LGLabVIEW 8.2 error log file: vitypedef.cpp 147
    4547N7VIClosing remote VI reference causes open control references to go invalid and possible crash client
    454AJOVICannot call "\picture\jpeg.llb\Directory of Top Level VI.vi" remotely or from C Interface
    454AMDN8UID mismatch when moving decoration to back
    456FHC00Difficulties with positioning executing front panels
    457764VIRemote VI Server Control Reference goes invalid in weird looping case
    457JG9ORfread does not read double data correctly
    459A9KBDError dialog invoked during editing of Formula Express VI cannot be closed, effectively hanging LabVIEW
    459CI9TRSpecial Functions: Use of NaN to reflect unwired inputs creates problems.
    459DHC14Probes for some I/O controls never update
    45A81SN8clicking on Show Error in Code Generation Errors Dialog doesn't un-minimize/bring-to-front the VI's front panel
    45AA0APWMathScript isprime function only works up to (2^31)-1
    45ACRMX6cFP-1808 Returns Runtime Error R6025 when running Performance and Memory Analysis
    45AFQM7NThe actual ripple is larger than the ripple output by Parks-McClellan.vi
    45AG6DU4LabVIEW 8.2 error log file: memory.cpp line 342
    45B9II00Logos servers will fail if we are unable to establish a socket for classified ads registration
    45BARPQECall by reference node caches Error 1026 error terminals not wired
    45E7QFX2LabVIEW 8.2 crashes when replacing waveform graph with XY graph in Cursors_with_Scales.vi
    45EC5AWJproperty value output sometimes not cleared
    45FCMGZCSome calls to LoadExternalLib are not synchronized
    45GCBKDEAdd Hyperlink dialog box OK and Cancel buttons not shown completely
    45GI243WWrite to Measurement File Express VI Does Not Close TDMS Files in a Multi-file Session.
    45HBGLZQLabVIEW 8.2 error log file: OMUDClassLinker.cpp line 238
    45HDBKOUComplex Number not displayed in fprintf command
    45HDOKF3Update container's properties will make LabVIEW crash when putting the XControl in a reentrant VI
    45HDOKP2Can't connect to debuggable DLL using LabVIEW exe.
    45HDPEP2Write Icons to Application.vi does not work for Vista icons.
    45HFM9OKWe're getting a linkobj.cpp error when I exit SigX.
    45HFQRCYRemove Panel property application builder checkbox not properly updated
    45HGPPHEModifying the cursor.YScaleOriginal property of a waveform graph creates a new cursor but does not clear the original.
    45IADVE1LabVIEW crashes when attached VI is run
    45JCAULBInternal error using unit label on sim diagram constant
    45L77R00Save a copy of a class bug
    45L9NIVBWrite to Spreadsheet File Uses the Integer instance when Extended is wired
    45ME92V9- Add stack trace and variable name to error cluster on shared variable read/write
    45MFMPC7Crash while building .EXE rule
    45N6RGISource control error when diff
    45NBJGISource Control is unavailable for some VIs
    45NDI9P2Apply Mask to Pixmap.vi does not handle 32-bit images
    45OA8C7PSCC Check in Error.
    45OFG8MXBuilding a 4000 VI hierarchy into an EXE will cause an Error 2 (out of memory) in the BuildApplication method
    45OFJ6F3The XControl example will crash LabVIEW when deleting the XControl from FP in a new empty VI
    45OGBJ7PThe download link in DIAdem Report Express VI is incorrect
    45OK25RKPoint to Row-Col.vi has different behavior in LabVIEW 8.x than previous
    45P9JOOUMathScript: function 'fprintf' will not accept a string as its input.
    45PCAHGFWhen Default Value terminal of Get Variant Attribute is unwired terminal is not cleared from previous run
    45RB7L1YBitget function in MathScript returns incorrect output
    45SC9IBWLaunching admin apps through System Exec.vi returns Error 740
    45TCCISFMathScript Range Creation Miscalculation
    45TH092AOpening a VI with the same name as a VI in the project causes incorrect behavior
    45UDQEU7LabVIEW 8.2.1J - Palette loading error message cut off
    45UEA5X6Mixed Signal Graph plot disappears upon changing scales programmatically
    45UFI1F2Investigate Memory Full Errors in the Control Editor Source Code
    45UGG6F2Right-click > Rename on a LabVIEW Class in the Project Window Should Skip Save As Dialog
    4608K8D0Runtime Engine fails to work when registry key is not set
    460AK8OUMathScript: 'fir1' function does not accept Kaiser Window input 'kw'.
    460AP1OUMathScript: 'clc' function cannot be called from within a function file.
    460BNFOUMathScript: 'remezord' function will not run without sampling frequency as an input
    460D29F2Strange SCC Error when Attempting to Add Folders to SCC
    460DD3IGClass Dynamic VI Cannot be Deleted from Block Diagram
    460GMDM0LabVIEW Crashes when Loading Two VIs that reference dlls with the same name using VI server
    4610AE00LabVIEW crashes when closed while XControl containing VI is running
    46121AN3LabVIEW 8.20 Crashes without an Error Log When Placing a Decoration on an XControl
    4617ADP2LabVIEW crashes saving attached VI for previous.
    46193M008.2.1 Run-Time Engine's memory gets corrupted when running a VI with a Scene Graph Control
    4619FF008.2.1 Run-Time Engine's memory gets corrupted when loading a VI with a Scene Graph Control
    461CRB00The iak installers need to start our services
    464975OUMathScript: 'freqz' function does not accept complex variables
    4649CTOUMathScript: 'hold' command behaves differently with zplane
    4649ECOU'input' function does not accept vector input in the form of [x : y]
    465B6E5UPreserve hierarchy flag is lost when loading a 8.0 project in 8.2.1.
    465DTSVICrash When Close Project Reference on Remote App Ref
    465EMC77DtNetAppDomain.cpp, line 242 Error
    465G1QI7Print documentation prompts for passwords of protected VIs
    466952R2German LabVIEW 8.2 crashes when closing VI saved in LabVIEW 8.0.1
    466AK577LabVIEW Crashes after mass compiling folder containing dlls built with a previous version of LabVIEW
    466COB00Front Panel Goes Off Window When Un-Maximized After Setting Monitor Programmatically
    466FL400App Instance Close event is fired on project's app when programmatically creating a LabVIEW library
    466K97C5Listbox control rows property set number of rows for wrong listbox
    46793SZLPseudoInverse Matrix returns invalid results after LabVIEW 7.1
    4679ISB4LabVIEW 8.2 crashes in bookkeep.cpp line 887 when saving a VI that uses XML Load Document
    467CJT00Autoscale not autoscaling with Scope-like data.
    467EDOVQVI becomes broken during build process with error 1502 when not disconnecting type defs
    46B2C0ZPCompile error when connecting error inputs and outputs of call library node
    46B9MTLGProperty node for extended precision does not update front panel
    46BAJTHANasty gencode bug in build array
    46BB49YGExpress VIs are not dropped properly from palette
    46BD5A9OSimulate Signal Express VI Hangs after Reconfigure dialog
    46BEEP2ALabVIEW Project using LVOOP will not build with Application Builder
    46BF8SR0Internal Error at transact.cpp, line 1323 when manually edit scale value of gauge while start position is moving.
    46BGSU00Problem editing Text Labels on System Vertical Pointer Slide
    46C9MUCIMass Compiling Simulation Folder gives Broken VIs
    46CE55LGFiles with .var extension in LabVIEW project explorer throw an error.
    46CF3NRSLicense DLL can't write to the registry
    46CGNKG0LVOOP VI Attempts to Load VIs that do not Exist but the VI will Still Run
    46D8QP00Special Functions: Use of NaN to reflect unwired inputs creates problems.
    46DDGG2NLocalized VI names listed in English when English developer uses caption.
    46E8AMNRApp Builder - there is no error if versioning doesn't work.
    46EFGN00lvclasses with non-LabVIEW file types don't get relinked correctly during build process.
    46F6KB00SubVI reference not updated when a method VI name changed
    46F9LO39TDMS does not fill wave form properties correct and adds redundant properties
    46FE7IM9Vista UI issue in "Scaling and Mapping" Express VI
    46I24900Crash when debugging an application
    46I26500Unable to add LVClasses as resource files in an application build
    46I99AXCABAPI UniquifyVIName.vi loses file extension
    46ID64X0Tagger crashes if it can not get a hold of the event logger service
    46IDFIYULabVIEW 7.1 error log file: fontmgr.cpp line 837
    46IDLB1Wsetting VI Search Path to empty programmatically crashes LabVIEW
    46IDQ700crash while quitting LabVIEW
    46IEOR84Race condition in Open VISA Session Monitor.vi
    46IGEMFNweird error message when using a wrong decimal separator in the Formula step on a localized OS
    46K0DOSKWindow Runtime position and maximize button conflict
    46K7EP1Wundo history lost when autosaving CTL in customize mode
    46KG2U84ArchiveExtractFile can set wrong mod dates
    46LEJ400Fix non-ASCII characters for English LabVIEW on non-English OSes
    46LGGB41Y Scale on Waveform Chart does not redraw although Auto-Scale is turned on
    46M2K9W3Unable to set timeout to -1 on Synchronize Timed Structure Starts
    46M398FQVI containing just a graph under LabVIEW 8.20 uses 100% of the processor for ~30sec
    46MBAECSLabVIEW can't load 32-bit bitmap (BMP) files?
    46MBBRPWTraverse method doesn't work on MathDiagram
    46MCR7OU'fwrite' requires more input parameters than expected.
    46MDMKVBXY Graph Cursor Legend Does Not Update On Unselected Tab
    46MEMJIGReshape Array Buffer Allocations Vary with Inputs
    46P8ALJ1Replacing LVClass control marked as dynamic dispatch with another control does not clear dyn disp on terminal
    46P8RMORfscanf can not handle more than two specifiers in a single format
    46PB68CSLLB Manager won't let me put a .lvclass file into an LLB
    46QD6RCIInternal warning cloneVI.cpp, line 541
    46RCODRSCoupling between LabVIEW 8.0 RTE and LabVIEW 8.0 over licensing?
    4701F431Hang when loading a VI
    470AHBA3XML Scripting leaves style constant set to .NET Container behind
    470G1AKJ"Detailed help" of the invoke node of xcontrol always links to the LabVIEW help
    470GT126No broken arrow upon wrong data type connection
    471GNJNQLibrary properties and methods do not work in Runtime engines
    47496MN8Magic pattern is not inplace in LVOOP
    475DNJFKConfusing error message in Preview pane when file is missing
    475ENR00App Builder licensing check should be for any version of LabVIEW not just current
    475ES800Build Application method needs to check for the 8.2 appbuilder license not the current one.
    4764QT7QYScale.Range Property Node doesn't return the correct range value.
    47699L00product dll - App Builder licensing check should be for any version of LabVIEW not just current
    476CHQAHActiveX Server property node Read Only in LabVIEW 6.0 or Later
    477BKLDVString comparison fails even though strings are equivalent
    477F5L00Cannot deploy DataSocket app to Vista correctly
    47B9Q6PJRenaming Library with .ctl causes searching for renamed .ctl
    47BA3VOU'filled' attribute not behaving correctly in 'stem'
    47BAQTCSAppend File to Report.vi is using obsolete Read Characters from File.vi
    47BB5D2AEMF file format distorts vertical text when using Export Image method of Graph
    47D92LTMni::dsc:;osdep::ForceFQDN fails if the DHCP controller is on a different Domain than the computer you are on
    47E6N8SQLabVIEW 8.2 built executable with DSC functions crashes
    47E71BXCNeed more information in Error message when a source Installer isn't found
    47E74JH2LabVIEW Optimization code causing incorrect value to be returned from subvi
    47EB70RKXControl Mouse Down? event alters behavior of Listbox Scroll bar
    47EE9500File primitives set permissions on newly created files when they shouldn't
    47F52DTQUndoing actions (crtl-z) on certain grouped controls in a cluster causes panelsup.cpp line 134.
    47F9DJIQLoad VRML File VI does not work properly in an executable in LabVIEW 8.2
    47FBKA00Cannot Use Windows Explorer to Open LLBs When Internet Explorer 7 is Installed
    47ICS4XJIncorrect Control/Indicator Documentation
    47IDRGU1LabVIEW crashes when using Classic and Modern Style Slider in the same VI
    47IHMI2WOut of regs no spill candidate found, reg 164!
    47JC4NV9Setting FP binding options on a front panel that doesn't exist causes LabVIEW to crash
    47KGBBG0Error 1502 Building EXE with .NET used in LVOOP Class VIs
    47LFSBKJScan String For Tokens Function Behavior Incorrect While Using "," As Decimal Symbol
    47M95VFNHard crash in print preview for certain system controls
    47MC4TV9Crash when dropping an XControl
    47PAIL00Receiving Variable Manager Error 1143 When Interactively Editing a Variable Value
    47Q7N71WUnused poly instance changing doesn't cause typeprop on callers of poly VI
    47QE3C00Constants in vi.lib\express\express output\ExFileWriteBlock.llb\ex_CreatePacketHeader.vi not localizable for LabVIEW SignalExpress
    47RBTH2BLabVIEW 8.0 Student Edition (Macintosh) will not load/save to External HD
    47S853MYDiagram Disable Structure and an Express VI Crash LabVIEW 8.2.x When Profile Performance and Memory is Started
    47S9FROFInstalling Visual Studio Network Variable Setup Application Stops the Variable Engine Service
    47SA95G0Edit Cell? event does not return if another unregistered mouse event occurs in another control
    47SDM600Fix non-ASCII characters for English LabVIEW on non-English OSes
    4818OGXRClose "Write to measurement File" with red cross crash LabVIEW
    4822EC9MLabVIEW 8.2 ActiveX server methods ExportVIStrings and ImportVIStrings are missing
    4832SQW8Fatal internal error in "extfuncdlg.cpp", line 2212 when loading a DLL in LabVIEW 8.2.1
    483FLEP2write to measurement file express VI has incorrect behavior
    4849LPPJOpening a VI should look for missing VIs in open projects.
    484AROJ1Explore... popup menu item should jump all the way to the file, not just open the containing directory
    485AQS00XControl do not support filter event
    488CI400Make sure Express VIs get load-localized
    489C7EOUfunction firpmord not supported
    489CB900Unopened SubVIs doesn't filter out express VIs when in text mode
    489GI56MImage pasted onto front panels of sub vi's do not display correctly in an executable.
    48BCQAXAProgrammatically setting Enum Justification property causes cpp error at line 399
    48BE1VI8unexpected error when reading the attached TDMS file
    48CAFGDLSim Embedded not working
    48CDIUSFstr2double function not supported in RTE, but not blocked (or documented)
    48F0MHE8Unflatten from string give bad output in while loop with shift register
    48FER6HAGenerator need to support Name bundler unwired(nmAllowUnwiredMask) mode.
    48GFAAOUpsd function not supported
    48GGMOF2LabVIEW 8.2.1 Boolean Text:Vertical Arrangement returns error or crashes fpsane.cpp line 401 and 399 (intermittently)
    48H2DBYNSource Distribution does not work when run arrow is broken
    48H7IEN3Error LabVIEW 8.2 AppEntryPoint.cpp 202
    48H92C00str2num returns incorrect result
    48HDJ9KQSub Panels don't resize correctly when "Scale all objects on front panel as the window resizes" is on
    48LAAIU1The attribute "Bold" does not show any effect
    48M87UFNRun-Time Menu Shortcut changes received by remote panels will randomly set the 'Ctrl' requirement
    48MGOHW41077 Error setting Waveform Graph Properties on LabVIEW 8.2.1 under Windows Vista
    48O9LLXRCannot set the Window min and max size in Application
    48OA3M8GFile dialog prevents/halts execution of a Open/Create/Replace Datalog File function in parallel
    48OF4KCYLabVIEW._Application class throws error 3005 at Automation Open.vi if 8.2.1 full installer is used.
    48OIA7UDVI created from template of dynamic VI causes created VI and template VI to break.
    48PD3S3ADataSocket method not threadsafe - results in LabVIEW crash
    48PE6HOUcontour will not output to variables
    48PE9QOU: fopen file permissions not supported
    48TDRGL5Simulation Translator crashes LabVIEW when translating the following model
    48TGCODLCannot select VI with Subsystem as startup VI in built app
    4916EI2AStudent version of LabVIEW does not install the LabVIEW Help files
    491GL29IErrors on XControl custom methods do not propagate to the Invoke node.
    492995TYError Clusters in Xcontrol Method's Don't Propagate
    492EQ8FNRemote panels across platforms: Keyboard shortcuts that can't map should behave better...
    492IDNTYCustom error messages in xcontrol property nodes do not show when passed through general error handler
    4930ORU4Click into any ring/enum/menu ring in LabVIEW 8.2.1 led to 100% CPU efficiency , when used in a VI with XControl
    4936MH9TLabVIEW crashes on Invoke Node call
    49372BFNLabVIEW generates incorrect events for the F16 key.
    493G3O68LabVIEW 8.2 insane object error fpsane.cpp, line 392 when changing radix to hex
    4967H9FNSome windows missing from windows list
    4968O700Dynamic VIs can not be used as probes
    4978BAXCInternal warning in window.cpp line 6184, when opening a project
    49794JWJTDMS file sharing problem
    497ANJZQLabVIEW 8.2.1 Application Builder does not create Application ActiveX Type Library Correctly
    49882DJ1ThEvent.cpp internal warning on LabVIEW exit with Notifiers (and sometimes crash)
    499FSF00Upgrading UDP causes connection ID confusion
    499I20CRSet Time and Date VI from VIDialog.rsc not in modal mode. LabVIEW 8.0, 8.2 and 8.2.1
    49AC32V9Qualities/values aren't getting pushed out of the OPC plug-in output queue
    49EBITJ1Race condition between dynamically loaded child class and unflatten prim
    49EDEBG0U64 Datatype Type Casts Incorrectly from Smaller Datatypes like U8
    49F8JDJ1Labels for LVClass DDOs appear in wrong location when dropped
    49FA5M00VI throws two internal warnings on load: compiler.cpp, 367 and fpsane from signal
    49HH05G0Registering an updated ActiveX COM library breaks VI and requires relinking all Invoke Nodes
    49MAAC00Tag monad is not sending out quality updates for a disconnected source if you have a write connection
    49MAC100An undeployed variable does not show bad quality when deleted from an opc client
    49MEGI00LabVIEW Crashes when loading Instrument Control Parsing.vi
    49MFN87VMulti-channel continuous resample VI (used as decimation) output size issue
    49MH2LGIThe full version of LabVIEW 8.2.1 installer does not contain Import Shared Library tool
    49N6HF00Appbuilder requires License and Readme files to be writeable
    49O9E2ORSort Complex Number VI returns incorrect result
    49OEPRRMDeadlock when clicking help button while editing palettes
    49OERORMPalette in a class cannot be added to the class's library
    49RF6AORException occurred when calling Peak Detector VI with initialize FALSE.
    49SDCN00Writing to control label properties other than size causes control label to disappear
    49T33UU1Using .NET components in combination with an XControl has odd issues
    49TEIHOUpause functionality
    49TFT00LabVIEW VI to unwrap phase returns incorrect results.
    49UCQ200Internal error creating a new VI if the new VI name collides with a library's VI name when the VI is in memory currently
    4A03LJIIClicking a locked Xcontrol crashes LabVIEW
    4A08H6JFCrash when dragging variable from project to front panel cluster
    4A0AMSJ1Unflatten From String requires the output string to be wired to *something* for LVClasses or returns error 1403
    4A4B8RXCDefault value of an input on Resample Waveform (Single Shot).vi changed from 8.0 to 8.2 and didn't mutate old code.
    4A6FJA2KProbes for LVClass data saved in user.lib/_probes/default/ show up many times in ProbeDefaultCache
    4A7HP3VBFatal Error When Running a LabVIEW Executable with .NET Assemblies
    4A8DL200Closing a generated VI after running causes LabVIEW to crash
    4AA7QNMYLabVIEW crashes by opening the VI
    4ACD9G00LinkerInfo returns Instrument Type for nonVI files in a library when linkerOption is Include All
    4ACFDM3AGet Waveform Subset VI LabVIEW 8.0 has incorrect actual start output
    4AEDQLX5Newer versions of sort do not accept "+" as an option
    4AHF71DLFormula express VI on a subsystem crashes during mutation
    4B2F5400supC.cpp internal warning sub-problem
    4B8DAAF2Duplicate Case Needs to Perform Correct Copy of Function Block
    4B9C4QJ1Generic probe of classes that uses subclasses shows incorrect data; can lead to crash
    3G07ED00Tree/MCL/SCL: Current-Windows Selection - Typeahead Does not Match OS
    1E0AS5CZReplace: Replace unbundle with unbundle by name does not preserve connections properly.
    22PCTNQ1"Snd read wave file.vi" returns bad data for compressed wave files.
    3QH7FO5LExample finder shows broken arrow after replace queue.llb and notifier.llb
    3DG8GK00File»Page setup dialog option 'Print header' does not work in Run-Time environment.
    37HAN7NRCustomized waveform graph does not draw all the point
    35KAHO6FUse of LabVIEW 7 File Dialog Continues to Access Floppy Drive After VI is Stopped
    3UMDHA00Subtly different behavior when canceling a config page depending on how it was opened
    3OBH7GQQPicture to Pixmap.vi Truncates Images
    3L2DSLO7Silent Uninstall Does Not Uninstall LabVIEW Runtime Engine
    3J6G648VLabVIEW Does Not Resolve Mac Alias When Opening VI from Library
    3CMA2AA3Does not warn about unsaved VIs until you build
    3BK9K6Z2LabVIEW discards the last frame of animated gifs
    36BH2H00Quit does not work in ExampleFinder
    37BFL71WLabVIEW Modal Dialog shows strange behavior is it opens while another dialog is open
    402DGLTMI/O Server Items of complex datatypes do not show up in the source browser picture control.
    3OHFUSX7.NET typedefs are not updated when the assembly is changed
    3MC9QHC3In MDI unsaved changes are shown in separate save changes dialogs
    3KADI41INo data displayed in digital graph for 1d DWDT and picture control
    3WK9A6J1Untitled Project should have writable "Name" property
    3U67BV00LoadExternalLib on Mac not returning appropriate errors
    3SI966HAA Control with Blink property set does not work correctly in a tab control.
    3Q978ELGDraw Rect.vi shifts rectangle when changing pen width.
    3Q6CI6OICannot resize columns of a multi-column listbox, or table control on a VI opened thru a LabVIEW Project
    3PCDNC7U\examples\project\viserver\(subVIs) need VI Descriptions
    3OOASHS5Printing Problem Assistant hyperlink to help is bad
    3OHFTOX7Project Dependency shows ? for .NET Assembly
    3O8DJN07Load Library Failure (Windows XP) test reports two errors instead of one
    3O8DD2X7Need to handle the same assembly selected in a different directory
    3NKFAEO4Large Fonts: Scroll-bar in just-in-time help dialog in non-responsive
    3NIA7Q4USetting LibPath property to invalid value does not work right
    3ND94JCEMathScript: freqz
    3ME9B600Ring's Radix Visible Property not exposed thru Property Node
    3M99SQN8Resource manager version number is not checked against current version
    3M281CYZAdding custom controls is far too complex
    3LUDR000Searching status shown when dropping a poly VI that cannot find its default instance.
    3LUAHT1WIncorrect word order in menu shortcuts warning message
    3LNE6634Issues with example finder in CVI alpha
    3L9AC3QODragging a variable from the project tree onto a front panel places the new control at a weird spot
    3L8B29UKTools»Options»WebServer-Visible VIs dialog is inconsistent with previous versions of LabVIEW
    3KODCKHHCreate New Driver Wizard: Progress Bar Improvements
    3KODC7HHCreate New Driver Wizard: Progress Bar Needs a Way to Exit/Cancel
    3JUHM1K9SDF Time to Multirate VI Leaves Original VI on the Block Diagram
    3JKBOO54Search/replace string input failure
    3J9CG91WMy web examples should show up in Example Finder
    3IHBQTZUIf I bind a Variable to itself, Tagger processor usage spikes
    3HC8S0RSRemove Evaluation check on Just-in-Time Advice
    3GS97ACEMathScript: Spline
    3F1BDTGQRunning test VI results in failure for Chart
    3ERBR99AGraphs do not autoscale on "reinitialize to default value"
    3CUED6N4New_GraphTypeObject
    3CB852WBProperty pages framework should monitor the escape key
    3BM9GSEOShould be able to configure a variable from the reference
    39OA7G9TImporting 8-bit bmp image into RscEdit.exe is not successful
    3P6H4CUZGetting Unknown Interface ID after uninstalling LabVIEW 8.0
    3ND98KCEMathScript: no output function
    3ND90FCEMathScript: grpdelay
    3NCC3Q1WAggHandler leaks its scratch VI
    3N7CQNCEMathScript: mesh
    3N7CMUCEMathScript: surf
    3N0DJLCEMathScript: hist
    3N0DH1CEMathScript: stairs
    3MJCGR1WDocmods showing up unnecessarily in poly VI dialog
    3MEGM100Dialog tab control not printing on Mac in Postscript.
    3MDBS08WNumerical differences in MathScript versus pure G
    3M6G9SBRSearch and replace string is now case insensitive by default whereas in 7.1 is was case sensitive
    3M6CRHF2Viewing same VI in multiple browser windows of IE (part of the same IE process) on the same client machine fails
    3L2D6NAPAutowiring does not work
    3KACPLCEMathScript: More parameters for the gcd function
    3K59S508Provide information for inline MathScript function if supported
    3HPEGQJ1Fill in specific error codes for LabVIEW Class data unflattening
    3O8FKQ70The graph cursor moving tool from the cursor legend does not respond to the automatic tool selection
    3MDG050QMixed Signal Graph: Cursor becomes Text tool when you hover over cursor legend
    3MDDR200Waveform Chart/Waveform Graph/XY Graph: After making the x and y scales invisible and selecting arbitrary x markers, I cannot redisplay the axes
    319GFL9IBuilt-in Menu Keyboard Shortcuts page lists dynamic menu items like Open Windows, but the shortcut set on those items does not work.
    3Q4EFN00Why My Computer and no hierarchy on MacOS?
    3YFF433QPrinting.Page Headers? Property Does not Work in a LabVIEW Executable
    3WN5AL7UError in aligning a object in cluster with object outside the cluster.
    3SQ9AMHLProject Save As... does nothing.
    3WO99TVIEscape key has weird behavior in "Select Files to Recover" dialog
    3WKCSH00[MathScript] Incorrect use of MathScript error wiring code
    3VLATLSFIncorrect use of MathScript error wiring code
    3UCDG2J1GetVILoadErrorStr has "RefClass == viClass" which is the wrong enum to be evaluating against
    3U2B1JJ1Remove antiquated DataTool stuff
    43F8LS7UInvestigate Internal Error dialog opens manual investigation page when clicking anywhere outside the table
    424CHIWAError with Save As from the project tree
    41BF5LX7Cleanup use of HKCR
    415DE40CChange name of Clear Color property of SceneWindow and SceneGraphDisplay
    40MCJC4UVISA I/O control does not allow comma in name
    3ZGGAABDAcquire Temperature Solution example VI is broken unless traditional DAQ is installed.
    3ZAAQOPWClearing MathScript node script doesn't cause re-scripting
    3Z6ERF54Opening project from future says 'vi' is ...
    3YTC4RMQFile primitives set permissions on newly created files when they should not
    3YHFH5J1InitExtSigVIRef in confnode.cpp needs to handle error from UnFlattenTDR
    3YFDL800Code generated by the Call Library Node for 64 bit integers will not build in CVI
    3YE9HJMQSound File Write does not take single waveform (requires array)
    3Y7AKHCEMathScript'load' function doesn't read zero size matrix correctly.
    3XSA92A5"Unsigned" should be parsed to "unsigned int"
    3XG8DJBWConfusion about predefined symbol warning.
    3XE8J707ExampleFinder is showing some examples with no software glyphs
    43MGBCORRoutine cblas_i?amax should return index value in range [0,N)
    41OCH8PWMathScript node does not support automatic error handling
    415F4C54Instantiating a vit causes static callbyrefs to be unable to open subVIs
    3ZQCE700Get Palette Menu Information method is getting slower with every version of LabVIEW
    3ZB92VBDMainCreate_DeleteTSrc failing
    3ZB77O1WViewing comments for web examples fails
    3YQCSOVIODF Editor should alphabetize classes
    3YP7NEBWID VI Creator: Copied subVIs do not get updated icon banners.
    3YLC7OZAID VI Creator - cannot add VI open in same context.
    3XIH42ZUGet rid of hardcoded time server in LogosManager.cpp on embedded targets
    430ELTPWDLL Versions test needs to be updated for Vista
    1ZB8P2WKOpening VI Template File from Mac Finder opens template rather than creating new VI
    3G7BQ7RMAliases no longer work in file/path operations
    3PT8RKNRReplace unwired shift register with tunnel and you get two internal warnings, showerr.cpp, line 3063 and 852
    3LAOLGQOpening this VI internal warning
    437FAKZUWe need to redefine the SAL_SOCKET type for 64-bit platforms
    42H7KEVBLabVIEW 8.2 error log file: undo.cpp line 6977
    3ZKEP23ZUnable to build a LabVIEW DLL that returns an Int64/UInt64 value
    3Z56HMN8fpsane.cpp line 394 after changing to Large Fonts while LabVIEW is still open
    3Y5CHU00Opening InfClose.vi throws fifo.cpp internal warning, line 752
    423EGDBDLabVIEW throwing xstuff.cpp (line 641) and Tunnel MergerImpl.cpp (line 144) internal warnings; change also breaks storage tests
    40N74MBD_commitTransaction.vi throws LVInstantiations.cpp (341) when opened or mass compiled
    3Y6A471RError -808 Running Multiple Timed Loops or Timed Sequence
    43EH08IVlkTimeSync service fails to stop with error 1922 upon MAX uninstall (removing NI Logos 4.6)
    3Z9FKDW9LabVIEW 8.0 crashes at run time after being converted by CVT
    3Q4BJQRMCrash on Exit
    3YQC76LGLabVIEW 8.0 error log file: cloneVI.cpp 566
    3YCGGQXELabVIEW 8.0.1 error log file: oleautomgr.cpp line 527
    40L9T4MQLabVIEW hangs when using Ctrl+--> in a string input set to Password Display
    3Y4E9R00LabVIEW crashes on exit from Getting Started window if circular references present
    © 2003–2007 National Instruments Corporation. All rights reserved.
    For patents covering the National Instruments products, refer to the appropriate location: Help»Patents in your software, the patents.txt file on your CD, or ni.com/patents.
    发表于 2013-6-27 11:34:14 | 显示全部楼层 来自:加拿大 Rogers
    昨天 16:03
     楼主| 发表于 2013-6-27 15:58:05 | 显示全部楼层 来自:广东省东莞市 电信
    发表于 2013-7-25 11:15:46 | 显示全部楼层 来自:上海市 电信
    发表于 2017-9-1 18:58:29 | 显示全部楼层 来自:陕西省西安市 联通
    GMT+8, 2026-2-24 23:51
