TA的每日心情 | 擦汗 昨天 16:03 |
发表于 2012-11-24 16:21:06
来自:广东省东莞市 电信
LabVIEW 2012 f2 Patch Win32多国语言 LV2012f2补丁-32位版
问题:
LabVIEW 2012 f2补丁修复了哪些程序漏洞?
解答:
LabVIEW 2012 f2补丁有LabVIEW 2012开发环境和LabVIEW 2012运行引擎的联合补丁,也有单独用于LabVIEW 2012运行引擎的补丁。
补丁修复了下列6个问题,也包含LabVIEW 2012 f1补丁中已修复的程序漏洞。 强烈建议所有LabVIEW 2012用户,尤其是LabVIEW FPGA模块的用户安装该补丁。 该补丁可通过NI更新服务获得,也可从下列程序和升级更新连接获得。
LabVIEW 2012 f2补丁修复的问题| ID | 说明信息 | | 368396 | Certain applications built with Application Builder fail to launch. | | 368375 | Compound Arithmetic node will produce incorrect results when operating on units in LabVIEW 2012. | | 365679 | LabVIEW 3D picture control does not work with AMD video card drivers. | | 364462 | Crash when changing value of typedef constant. | | 368115 | HTTP POST VI will always timeout when POSTing to a Web Service using NIAuth. | | 368230 | [LabVIEW FPGA] Compound Arithmetic node will produce incorrect results when operating on a combination of arrays or clusters, and scalars. | 百度网盘和NI官方下载地址:
LV2012_f2patch32.txt
(267 Bytes, 下载次数: 0, 售价: 1 圆)
