查看: 6354|回复: 1
[LV工具模块] LabVIEW 8.6 VI Analyzer Toolkit 1.1.1 Win32Eng LV8.6VI分析仪工具包VIA1.1.1
    前天 16:03
    发表于 2013-4-6 22:10:39 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    LV8.6平台DVD,软件开发与部署-VI Analyzer Toolkit 1.1.1 VI分析器工具包
    VI Analyzer(VI分析仪)工具包有利于提高LabVIEW代码的整体质量和可靠性。 通过交互式向导或可编程接口,可以配置超过60种不同测试以便分析VI并确定性能、样式和维护等问题。 VI Analyzer工具包有利于在代码中快速查找样式或功能问题并且帮助开发人员使用正确的LabVIEW编程技巧。
    注意,该版本为LV8.6平台级DVD中提取组件,不含其它如许可证管理等组件。
    百度网盘下载地址:
    链接: 请注册视觉论坛用户,登录后购买附件下载查看,充值请联系在线客服  提取码:请注册视觉论坛会员登录后购买附件查看
    VIA1.1.1.txt (119 Bytes, 下载次数: 0, 售价: 10 圆)
    LabVIEW VI Analyzer Toolkit 1.1.1 Readme
    June 2008
    This file contains important last-minute information about the LabVIEW VI Analyzer Toolkit 1.1.1, including installation issues.
    Refer to the LabVIEW Module and Toolkit Compatibility Information page on ni.com for information about which version of the VI Analyzer Toolkit to install depending on your LabVIEW version and operating system. All versions of the toolkit are available on the installation CD.
    Contents
    Installation
       Version 1.1.1 for LabVIEW 8.6 (Windows Vista/XP/2000)
       Version 1.1 for LabVIEW 8.x (Windows, Mac OS X, Linux)
       Version 1.0 for LabVIEW 7.x (Windows, Mac OS X, Linux)
    Using the VI Analyzer Toolkit
    Changes from Version 1.1 to 1.1.1 (Windows)
    Note about Spell Check
    InstallationVersion 1.1.1 with LabVIEW 8.6
    VI Analyzer Toolkit 1.1.1 is compatible with LabVIEW 8.6 on Windows. If you want to use the VI Analyzer Toolkit on Mac OS X or Linux, you must install VI Analyzer Toolkit 1.1. Refer to the Version 1.1 for LabVIEW 8.x section for information about installing VI Analyzer Toolkit 1.1.
    (Windows Vista/XP/2000) You can install all of your LabVIEW products—including LabVIEW and the VI Analyzer Toolkit—using the LabVIEW 8.6 Platform DVDs. Refer to the LabVIEW DVD Installation Instructions or the LabVIEW Release Notes, which are available in your LabVIEW box, for information about the LabVIEW Platform DVDs.
    Complete the following steps to install the VI Analyzer Toolkit 1.1.1 for Windows from the LabVIEW VI Analyzer Toolkit installation CD.
    Note  Some virus detection programs interfere with the installer. Disable any automatic virus detection programs before you install. After installation, check your computer for viruses and enable any virus detection programs you disabled.
    • Insert the LabVIEW VI Analyzer Toolkit 1.1.1 installation CD and follow the instructions that appear on the screen.
    • Activate your LabVIEW products using the NI License Manager.
    You must install VI Analyzer Toolkit 1.1 to work with LabVIEW 8.0, 8.2, or 8.5 on Windows. You must install VI Analyzer Toolkit 1.1 to work with LabVIEW 8.0, 8.2, 8.5, or 8.6 on Mac OS X or Linux.
    (Windows Vista/XP/2000) Complete the following steps to install the VI Analyzer Toolkit 1.1 for Windows.
    • Insert the LabVIEW VI Analyzer Toolkit 1.1.1 installation CD and browse to the LabVIEW_8.0-8.5\Windows directory.
    • Double-click setup.exe and follow the instructions that appear on the screen.
    (Mac OS X) Complete the following steps to install the VI Analyzer Toolkit 1.1 for Mac OS X.
    • Insert and browse to the LabVIEW VI Analyzer Toolkit 1.1 installation CD and open VI_Analyzer1.1.pkg located under the LabVIEW_8.0-8.5\Mac OS X directory.
    • Select Continue to run a program to determine if the VI Analyzer Toolkit can be installed on your system.
    • Follow the instructions that appear on the screen and continue to the Select Destination dialog box.
    • In the Select Destination dialog box, click Choose and select the version of LabVIEW (8.0 or later) you want to install the VI Analyzer to.
    Note  You must select the Choose button for a proper installation. If you do not select a location where LabVIEW is installed or you select a non-compatible version of LabVIEW, the installation will not complete.
    • After you select the destination directory, click Continue to complete the installation.
    Complete the following steps to uninstall the VI Analyzer Toolkit 1.1 for Mac OS X.
    • During installation, the VI_Analyzer_Uninstall.sh uninstallation script is created in the same folder as your version of LabVIEW.
    • Drag the uninstall script to the prompt in a Terminal Window. Press Return and follow the instructions provided by the script.
    • After uninstalling the VI Analyzer Toolkit, you must manually delete the uninstallation script.
    (Linux) Complete the following steps to install the VI Analyzer Toolkit 1.1 for Linux.
    • Use mount /mnt/cdrom to mount the CD. On some systems, the CD is mounted automatically.
    • Enter the following command to navigate to the LabVIEW directory:
      cd /usr/local/natinst/LabVIEW-8.0
    Note  The preceding command assumes that you installed LabVIEW 8.0. Modify the version if you installed a different version of LabVIEW.
    • Enter the following command to extract the toolkit to the LabVIEW folder:
      tar xvf /mnt/cdrom/LabVIEW_8.0-8.5/Linux/VIAnalyzer1_1Linux.tar
    • Enter the following command to navigate to the Example Finder directory:
      cd "/usr/local/natinst/share/example finder/1.0"
    • Enter the following command to extract the Example Finder files:
      tar xvf /mnt/cdrom/LabVIEW_8.0-8.5/Linux/VIAn1_1ExFndrLinux.tar
    You must install VI Analyzer Toolkit 1.0 to work with LabVIEW 7.x. The installation process for version 1.0 is very similar to the process for version 1.1 except that you launch the installer from the appropriate OS directory under the LabVIEW_7.x directory of your CD.
    After you install the VI Analyzer Toolkit, select Tools»VI Analyzer»Analyze VIs to run the VI Analyzer. You also can use the VI Analyzer VIs located on the Functions palette. Refer to the LabVIEW Help and the LabVIEW VI Analyzer Toolkit User Guide for more information about using the VI Analyzer Toolkit.
    • The VI Analyzer functionality is now available in LabVIEW if you install and activate an add-on that contains VI Analyzer tests.
    • With the VI Analyzer Toolkit 1.1, you can make VIs you write with the VI Analyzer VIs easily accessible from two locations:
      • Accessible from the Tools»VI Analyzer»Quick Launch menu—Copy the VI to the labview\project\VI Analyzer\Quick Launch directory
      • Visible in the VI Analyzer user interface—Copy the VIs to the labview\project\VI Analyzer\_tests directory
      These paths have changed in version 1.1.1:
      • Accessible from the Tools»VI Analyzer»Quick Launch menu—Copy the VI to the labview\project\_VI Analyzer\Quick Launch directory
      • Visible in the VI Analyzer user interface—Copy the VIs to the labview\project\_VI Analyzer\_tests directory
    For a listing of the copyrights, conditions, and disclaimers regarding the automatically generated inflection database, refer to the agid-readme.txt file.
    © 2005–2008 National Instruments Corporation. All rights reserved.
    发表于 2013-4-7 19:34:22 | 显示全部楼层 来自:广西桂林市 电信
    支持石鑫华视觉,支持机器视觉论坛!
    GMT+8, 2026-2-25 01:24
