查看: 19892|回复: 0
[LV工具模块] NI Vision Development Module 2014 SP1 Win32/64Eng 视觉开发模块VDM2014SP1 适用LabVIEW2014SP1
    昨天 16:03
    发表于 2015-3-18 10:33:29 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    NI的视觉开发包,VDM2014SP1版,英文(视觉开发包没中文版),适用于LabVIEW2014SP1的32位、64位等多版本,含中文、英文、日语、韩语、法语、德语等多国语言版本。
    链接: 请注册视觉论坛会员登录后购买附件下载查看
    提取码: 请购买附件下载查看
    NI官方下载地址(EXE版为NI早期压制,ZIP版为NI后期压制,内容一样):
    标准下载:
    请购买附件下载查看
    下载器下载:
    请购买附件下载查看
    VDM2014SP1.txt (483 Bytes, 下载次数: 95, 售价: 10 圆)
    NI Vision Development Module 2014 SP1 Readme
    February 2015
    This file contains important information about National Instruments Vision Development Module, including installation instructions, new features, fixed issues, and known issues.
    Updates and Improvements
    How to Activate the NI Vision License
    Deploying Vision Applications
    Documentation and Examples
    The NI Vision Development Module provides hundreds of image processing and machine vision functions. Along with programming libraries, the NI Vision Development Module also includes NI Vision Assistant. Installing this software may remove previous versions of the NI Vision Development Module that are currently installed.
    Note: The NI Vision Development Module overwrites existing NI Vision examples and NI Vision VIs. Move modified examples or VIs that you want to save to another directory before installing the NI Vision Development Module.
    Refer to the NI Vision website at ni.com/vision for the latest information about the NI Vision Development Module.
    The development computer must meet the following system requirements to run the NI Vision Development Module.
    MinimumRecommended
    Processor233 MHz Pentium or equivalentPentium 4/M or equivalent
    Memory256 MB RAM512 MB RAM
    Display1,024 × 768 resolution video adapter with a 16-bit display1,024 × 768 resolution video adapter with a 24- or 32-bit display
    Free Hard Disk Space
    3.2 GB
    Operating System
    • Windows 8.1 (32- and 64-bit)
    • Windows 8.0 (32- and 64-bit)
    • Windows 7 (32- and 64-bit)
    • Windows Vista (32- and 64-bit)
    • Windows XP SP3 (32-bit)
    The following table lists the NI application software versions, including service packs, supported by the NI Vision Development Module. The installer specifically allows side-by-side installations of Vision Development Module for each of the supported versions of LabVIEW, enabling you to use the NI Vision Development Module with multiple versions of LabVIEW. National Instruments recommends that you install LabVIEW, LabVIEW Real-Time, or any other supported development environment, before installing the NI Vision Development Module.
    NI Application SoftwareVersions Supported by NI Vision Development Module
    NI LabVIEW
    2011, 2012, 2013, 2014
    NI LabVIEW Real-Time Module
    NI LabVIEW FPGA Module
    2014
    NI LabWindows™/CVI™
    2010, 2012, 2013, 2014
    NI Vision Development Module .NET Support
    NI Vision Development Module 2013 SP1 was the last version to release updated support for the .NET Framework 2.0, .NET Framework 3.5, and .NET language integration into Visual Studio 2005 and Visual Studio 2008. Visual Studio 2010 and later are not supported.
    New versions of NI Vision Development Module will not provide new .NET feature support or development. It is recommended that you begin new development in other supported development environments.
    This release of the NI Vision Development Module includes the following new features:
    • Support for LabVIEW 2014 SP1 (32- and 64-bit)
    • New Vision FPGA VIs:
      • IMAQ FPGA SimpleEdge
      • IMAQ FPGA LineProfile
      • IMAQ FPGA Equalize
    • Support for using the Vision FPGA Transfer VIs in LabVIEW 64-bit with a LabVIEW bitfile that was previously compiled with the LabVIEW FPGA Module to transfer image data between the host and the FPGA
    • 1D barcode grading using the IMAQ Read Barcode 2 VI
    • Support for the NI CVS-1458RT
    • The Image Display Control can now be used to display images in NI Linux Real-Time with embedded UI.
      When using the Image Display Control in this context, the following features are available:
      • Property node support for zooming
      • Property node support for setting snapshot mode
      • Property node support for setting 16-bit display mapping and palettes
      • Menu support for zoom to fit
      • Menu support for palettes
      The following features are not supported:
      • ROI functionality
      • Scrolling functionality
      • Mouse event support
    NI Vision Assistant includes the following new features:
    • 1D barcode grading using the Barcode Reader step
    • Added support for the following FPGA functions:
      • Line Profile
      • Simple Edge Tool in the Edge Detector step
      • Equalize in the Lookup Table step
    • Improved FPGA Express VI user experience. The Express VI generates the algorithm behind the Express VI code and also the transfer VIs, single-cycle time loops (SCTL), and FIFOs needed for the project.
    • Added the Gradient and Sigma filters in the Filters step for all platforms
    • Implemented code generation progress bar
    The following list describes issues in previous versions of NI Vision Development Module that are fixed in this release. If you have a CAR ID, you can search this list to validate that the issue has been fixed. This is not an exhaustive list of issues fixed in the current version of NI Vision Development Module.
    479943The standalone NI Vision Run-Time Engine installer EXE cannot be invoked silently.
    510146Code generated from the Vision Assistant executable does not properly connect FPGA synchronization signals when the last step of the script does not modify the image.
    509724Code generated from Vision Assistant executable for FPGA targets does not create project files when the destination folder does not already exist.
    509722Required terminals cannot be deselected in the Vision Assistant FPGA code generation dialog.
    509415The Vision Assistant Express VI cannot transfer template files to NI Linux Real-Time targets using the WebDAV protocol.
    507452The default number of buffers available in the Vision Assistant Image Buffer step is too low for some applications.
    499011The Vision Assistant Golden Template Comparison step does not reposition the template ROI properly when working with large images.
    512065The Calibration Axis is not set properly in the Vision Assistant LabVIEW code generated or Express VI, resulting in wrong real-world coordinates returned by subsequent VIs, when the Axis Reference Mode is set to Origin and Angle, and the Axis Reference is Direct.
    480317FPGA generated code from the Vision Assistant executable for grayscale images contains Bayer decoding operations when the last image type to generate code from was a color image.
    479862The Vision Assistant Grayscale Filter step Limit Low Pass filter allows even values for Filter Size on FPGA targets.
    504920, 490843A crash occurs when trying to learn an OCR file with a big image with large amounts of text on multiple lines.
    411398The IMAQ Learn Pattern 4 VI errors out when a negative angle range is provided.
    509833The IMAQ Find Pattern 4 and IMAQ Find Coord Sys Pattern 3 VIs are not available in the Vision palettes in LabVIEW 2012 and later.
    124545, 130848, 141678, 197242, 392053, 440452, 475967A LabVIEW-built executable or DLL built in LabVIEW 2011 or later containing licensed NI Vision functionality returns error -1074396157: Unlicensed copy of NI Vision if NI Vision Development Module is installed and is unactivated or expired, even if NI Vision Run-Time Engine is activated. Refer to Using the NI Vision Run-Time Engine for more information.
    Installation InstructionsInstalling from the LabVIEW Platform DVDs
    If you purchased LabVIEW, you can install all of your LabVIEW products—including the NI Vision Development Module—using the LabVIEW Platform DVDs.
    To request additional LabVIEW Platform DVDs, refer to the National Instruments Web site.
    Installing from the NI Vision Development Module Installation Media
    Complete the following steps to install the NI Vision Development Module from the NI Vision Development Module installation media.
    • Insert the NI Vision Development Module installation media.
    • (Optional) Activate NI Vision Development Module when prompted by the installer, or activate at a later time using the NI License Manager.
    When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch.
    Complete the following steps to activate the NI Vision license through an Internet connection.
    • Run the product you want to license.
    • Click Yes when prompted to interactively activate your product.
    • Enter the product serial number, and click Next.
    Tip: Enter your email address to receive a copy of your activation code for your records.
    Deployment refers to developing an application so that it can be distributed, or deployed, on a different computer than the one on which the application was developed. The NI Vision Development Module provides everything you need to deploy custom NI Vision applications to target computers. The NI Vision Development Module provides the following options:
    • The ability to create NI Vision Run-Time Engine installers, which integrate with the LabVIEW Application Builder, applications built in LabWindows/CVI, or a custom installer.
    • The ability to install the NI Vision Run-Time Engine directly from the NI Vision Development Module installation media.
    • One NI Vision Run-Time License, which allows you to install a custom application on a single machine.
    The NI Vision Development Module installer contains the runtime engine installer for NI Vision. The runtime engine installer is installed at \Run-Time Engine, where is the location to which the NI Vision Development Module is installed. Visit the ni.com to download software upgrades for NI Vision and the NI Vision Run-Time installers.
    Purchasing NI Vision Deployment Licenses
    You must purchase an NI Vision Run-Time License (part number 778044-03) for each target machine onto which you want to install your custom NI Vision application, even if you install the NI Vision Run-Time Engine directly from the NI Vision Development Module installation media. The NI Vision Development Module ships with one runtime license. Contact a National Instruments sales representative or visit ni.com to purchase additional runtime licenses.
    Note: Additional NI Vision Run-Time Licenses do not include installation media. To install additional licenses, use the original NI Vision Development Module installation media and the serial number provided by National Instruments.
    You can call the NI Vision Run-Time Engine installer from the application installer. If you create the application installer with the LabVIEW Application Builder or with LabWindows/CVI, you can direct the installer to call the NI Vision Run-Time Engine installer.
    LabVIEW 2011 or later: A LabVIEW-built executable or DLL containing licensed NI Vision functionality can run on a system with an activated NI Vision Run-Time Engine license and an unactivated or expired license of NI Vision Development Module.
    All text-based languages, and LabVIEW 2010 or earlier: A text-based or LabVIEW-built executable or DLL containing licensed NI Vision functionality returns error -1074396157: Unlicensed copy of NI Vision if NI Vision Development Module is installed and is unactivated or expired, even if NI Vision Run-Time Engine is activated. You must activate or uninstall NI Vision Development Module to run your program.
    You can also direct a custom application installer to call the NI Vision Run-Time Engine installer. This may be useful if you are creating an installer for applications created in other development environments. Refer to the documentation that came with the installer software to learn how to call executables from the custom installer. If you are using a custom installer, call the NI Vision Run-Time Engine installer at the end of the installation procedure because the installer may require the system to be restarted.
    To call the NI Vision Run-Time Engine installer silently (non-interactively), you must add /q /AcceptLicenses yes as command line arguments to the run-time engine installer. For example, enter \Run-Time Engine\visionrte.exe /q /AcceptLicenses yes, where is the location to which NI Vision is installed, and is the version number of the NI Vision Run-Time Engine installed. Refer to the Automating the Installation of NI Products section for more information on how to change the level of interactivity of the installer or whether it automatically initiates a system restart.
    The NI Vision Run-Time Engine installer does not install LabVIEW VIs. If you use the LabVIEW Application Builder to create an application (EXE) or dynamic link library (DLL), the Application Builder automatically includes the VIs used by the application. If you distribute a VI, you must include all subVIs that comprise the top-level VI. You must include the appropriate LabVIEW Run-Time Engine as part of the installation.
    Refer to the LabVIEW Help for more information about viewing the hierarchy of VIs and for more information about using the LabVIEW Run-Time Engine.
    In addition to including the NI Vision Run-Time Engine with the installer, you must include the appropriate LabWindows/CVI Run-Time Engine. Refer to the NI LabWindows/CVI Help for more information about creating an executable, creating a dynamic link library, and distributing applications.
    You can access the software and documentation known issues list online. Refer to the National Instruments Web site for an up-to-date list of known issues in the NI Vision Development Module.
    National Instruments is aware of the following issues you may encounter while using NI Vision Development Module.
    • When an FPGA target is active in a LabVIEW project, the Vision Assistant executable cannot generate code for a non-FPGA LabVIEW target into that same instance of LabVIEW.
    • NI Linux Real-Time targets crash when the target is disconnected from the host while using the Image Display Control on the target.
    • 16-bit mapping property of the Image Display Control on NI Linux Real-Time targets does not use the full image for computing mapping parameters when the image is zoomed in. The mapped image may not match the host-side Image Display Control 16-bit image mapping.
    • When zoom factors above 30 are used, the Image Display Control on NI Linux Real-Time targets leaves black-colored border space.
    • The snapshot property node for the Image Display Control on NI Linux Real-Time targets returns an error even though the control is functioning properly. This issue is present only when the target is connected to the host.
    • The Image Display Control on NI Linux Real-Time targets may not work properly when an image is set using a property node value and the target is connected to the host. The property node value works properly when the target is disconnected from the host.
    • Vision FPGA VIs may be broken when opened on one target after being used on another target. You can fix the broken VI by forcing LabVIEW to recompile it by pressing + + Run Button.
    • Vision FPGA Filter VIs with a mask using a 9x9 kernel support image widths up to 2,000 pixels.
    • The IMAQ Edge Detection VI and IMAQ FPGA Edge Detection VI produce different results when using gradient filters.
    • The AVI2 VIs do not support writing extra data to AVIs.
    • Japanese and Simplified Chinese for text overlays are not supported on NI Linux Real-Time targets.
    • The Calibration Axis is not set properly in the Calibration Training Interface, resulting in wrong real-world coordinates, when the Calibration Type is set to Point Coordinate Calibration and the Implicit Calibration Axis option is deselected.
    • The IMAQ Read QR Code VI may hang when the QR Code Cell Size has a minimum size of 2 or less. Setting the minimum size to 3 or higher will prevent this issue.
    • The IMAQ Read Data Matrix Barcode 3 VI may hang on some I16 images.
    • Zooming out on a large 32-bit image in the Image Display Control in LabVIEW will cause the image to black out. Only the displayed image is affected. The image itself is not modified.
    • To store error statistics on corrected images, you must run the IMAQ Get Calibration Info2 VI before correcting the calibration template image. The Return Error Information input must be set to TRUE.
    • Vision Assistant cannot generate C code if a double-byte character exists in the path to Vision Assistant or in the destination path for the generated code.
    • Some Vision Development Module .NET examples only work if Measurement Studio 8.6 or later is installed.
    • The Visual Basic .NET Label example does not compile.
    • There is no 64-bit Vision API for C or .NET.
    • Installing the Vision Development Module on a Windows Vista 64-bit computer where Visual Studio 2005 has been recently installed causes compatibility warnings.
    • On some systems, the Vision Development Module cannot open two of the installed AVI files, SideCrash2.avi, when running as a 64-bit application.
    Documentation is installed onto your hard drive with the NI Vision Development Module. To view the documentation, select Start»All Programs»National Instruments»Vision»Documentation»NI Vision. The NI Vision Development Module documentation set consists of the following documents:
    The following sections describe the documents available for each application development environment and where to find example programs.
    NI Vision for LabVIEW Documentation
    • NI Vision for LabVIEW Help—This document contains reference information about NI Vision VIs and details about how to use NI Vision with LabVIEW. It describes how to create machine vision and image processing applications in LabVIEW. It also describes how to create a real-time vision application using NI Vision and the LabVIEW Real-Time Module, and how to use the Vision FPGA VIs with an FPGA target and the LabVIEW FPGA Module. You can access this help in LabVIEW by selecting Help»NI Vision for LabVIEW Help.
    • NI Vision for LabVIEW Examples—Illustrates common applications you can create with NI Vision. In LabVIEW, select Help»Find Examples. Click the Help button in the NI Example Finder to display the NI Example Finder Help. NI Vision examples for LabVIEW are installed to \examples\Vision FPGA, where is the location LabVIEW is installed.
    NI Vision for LabWindows/CVI Documentation
    • NI Vision for LabWindows/CVI User Manual—Describes how to create machine vision and image processing applications in LabWindows/CVI using the NI Vision Development Module.
    • NI Vision for LabWindows/CVI Function Reference Help—Contains reference information about NI Vision for LabWindows/CVI functions.
    • Function panel help within LabWindows/CVI—Allows you to right-click within each Vision function to access help for that function, control, function class, and function library. Function panels are installed at is the location to which LabWindows/CVI is installed.
    • Example programs for specific applications are installed at \Samples\Vision.
    NI Vision Assistant Documentation
    • NI Color Classification Training Interface Help—Contains information about how to use the NI Color Classification Training Interface to classify color samples. In the NI Color Classification Training Interface, select Help»Online Help.
    • NI Texture Training Help—Contains information about how to use the NI Texture Training Interface to train a texture classifier file for use in texture defect detection applications. In the NI Texture Training Interface, select Help»Online Help.
    • NI Calibration Training Help—Contains information about how to use the NI Calibration Training Interface to select and create a calibration for use in machine vision applications. In the NI Calibration Training Interface, select Help»Online Help.
    When you install National Instruments software on Microsoft Windows 8.x, you will notice a few additional tiles on the Start screen, including shortcuts to NI application software products such as NI LabVIEW, Measurement & Automation Explorer (MAX), and the new NI Launcher.
    Using NI Launcher
    NI Launcher helps you find and launch installed NI products. It provides you with a method of finding NI products similar to the Start menu in previous versions of Microsoft Windows. To use NI Launcher, click the NI Launcher tile on the Start screen. NI Launcher launches the desktop and opens a menu containing a list of NI products. Double-click any NI product to launch it.
    Note  MAX does not appear as a desktop shortcut when installed on Microsoft Windows 8.x. You can launch MAX either from the Start screen or from within NI Launcher.
    Finding All Programs
    NI Vision Development Module Drops Support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 in 2016
    NI Vision Development Module will drop support for Microsoft Windows Vista, Windows XP, and Windows Server 2003 as of July 1, 2016. Versions of NI Vision Development Module that ship after July 1, 2016 will not install or run on Windows Vista, Windows XP, or Windows Server 2003. For detailed information about NI application software product life cycles, visit ni.com/info and enter one of the following Info Codes:
    NI LabVIEWlifecycle
    NI TestStandtslcp
    NI DIAdemddlcp
    NI SignalExpressselcp
    NI VeriStandnivslifecycle
    © 2015 National Instruments. All rights reserved.
    GMT+8, 2026-2-24 23:48
