TA的每日心情 | 擦汗 前天 16:03 |
发表于 2015-4-28 12:06:55
来自:广东省东莞市 电信
SVS SVCam-ECO-4IO系列千兆网工业相机
基本描述
SVCam-ECO-4IO cameras are master in LED illumination and communication and can control the timing for illumination precisely. 4 power outputs and 4 inputs (0-24 Volt) provide a maximum of control. Each output can be configured separately to fit the task and type of illumination. Together with a fully programmable sequencer, new possibilities are made available for your applications.
- VGA up to 5 MegaPixel
- Progressive scan sensors
- 4 x direct drive and control of LED lighting
- GigE Vision and GenICam-Standards compatibility
- Industrial I/O interface for easy integration
系列包含产品型号与基本参数 | Model | Sensor | Resolution [pixel] | Sensor Size | Frame-
rate [fps] | Chroma | Lens Mount | Interface | | eco414rCVGE4IO | ICX414AQ / Sony | 656 x 492 | 1/2 | 125 | bayer | CS-Mount | GigE | | eco414MVGE4IO | ICX414AL / Sony | 656 x 492 | 1/2 | 125 | mono | CS-Mount | GigE | | eco424CVGE4IO | ICX424AQ / Sony | 656 x 492 | 1/3 | 124 | bayer | CS-Mount | GigE | | eco424MVGE4IO | ICX424AL / Sony | 656 x 492 | 1/3 | 124 | mono | CS-Mount | GigE | | eco618CVGE4IO | ICX618AQA / Sony | 656 x 494 | 1/4 | 155 | bayer | CS-Mount | GigE | | eco618MVGE4IO | ICX618ALA / Sony | 656 x 494 | 1/4 | 155 | mono | CS-Mount | GigE | | eco415CVGE4IO | ICX415AQ / Sony | 780 x 580 | 1/2 | 86 | bayer | CS-Mount | GigE | | eco415MVGE4IO | ICX415AL / Sony | 780 x 580 | 1/2 | 86 | mono | CS-Mount | GigE | | eco204CVGE4IO | ICX204AK / Sony | 1024 x 776 | 1/3 | 47 | bayer | CS-Mount | GigE | | eco204MVGE4IO | ICX204AL / Sony | 1024 x 776 | 1/3 | 47 | mono | CS-Mount | GigE | | eco445CVGE4IO | ICX445AQA / Sony | 1296 x 964 | 1/3 | 30 | bayer | CS-Mount | GigE | | eco445MVGE4IO | ICX445ALA / Sony | 1296 x 964 | 1/3 | 30 | mono | CS-Mount | GigE | | eco267CVGE4IO | ICX267AK / Sony | 1392 x 1040 | 1/2 | 25 | bayer | CS-Mount | GigE | | eco267MVGE4IO | ICX267AL / Sony | 1392 x 1040 | 1/2 | 25 | mono | CS-Mount | GigE | | eco285CVGE4IO | ICX285AQ / Sony | 1392 x 1040 | 2/3 | 34 | bayer | C-Mount | GigE | | eco285MVGE4IO | ICX285AL / Sony | 1392 x 1040 | 2/3 | 34 | mono | C-Mount | GigE | | eco274CVGE4IO | ICX274AQ / Sony | 1600 x 1236 | 1/1,8 | 26.5 | bayer | CS-Mount | GigE | | eco274MVGE4IO | ICX274AL / Sony | 1600 x 1236 | 1/1,8 | 26.5 | mono | CS-Mount | GigE | | eco625CTLGEA4IO | ICX625AQA / Sony | 2448 x 2050 | 2/3 | 20 | bayer | CS-Mount | GigE | | eco625MTLGEA4IO | ICX625ALA / Sony | 2448 x 2050 | 2/3 | 20 | mono | CS-Mount | GigE | | eco655CVGE4IO | ICX655AQA / Sony | 2448 x 2050 | 2/3 | 10 | bayer | CS-Mount | GigE | | eco655MVGE4IO | ICX655ALA / Sony | 2448 x 2050 | 2/3 | 10 | mono | CS-Mount | GigE |
eco655MVGE4IO具体参数 | 工业相机制造商 | SVS-VISTEK | | 模型 | eco655MVGE4IO | | 芯片 | | 芯片/生产商 | ICX655ALA /索尼 | | 芯片类型 | 面阵CCD | | 芯片架构 | 行间转移 | | 读数类型 | 逐行扫描 | | 浓度 | 单 | | 芯片尺寸(长X宽) | 8.45 x7.07毫米 | | 芯片对角线 | 11.02毫米 | | 光导摄像管等效 | 2/3“ | | Pxel尺寸(长X宽) | 3.45×3.45微米 | | 像素时钟 | 60 MHz的 | | 相机 | | 尺寸(WxHxD) | 38 X 38 x 33毫米 | | 重量 | 85克 | | 防护等级 | IP40 | | 接口 | 千兆以太网 | | 分辨率 | 2448 x 2050像素 | | 帧速率 | 10 fps的 | | 曝光时间(min) | 7微秒 | | 曝光时间(最大) | 1秒 | | 外部暴露时间(min) | 7微秒 | | 外照射时间(最大) | ∞ | | 信噪比 | 58分贝,9.6位 | | A / D转换器 | 14位 | | 增益(最大) | 18分贝 | | 手动增益 | 是的 | | 自动增益 | 是的 | | 数据深度 | MONO8,MONO12 | | 内部存储器 | 64 MB | | 手动白平衡 | 是的 | | 自动白平衡 | 无 | | AOI | 1 | | AOI可自由编程 | 是的 | | 镜头卡口 | CS接口 | | 电源 | 10到25 V(DC) | | 耗电量 | 3.1 W | | 数字I / O接口 | | 输出集电极开路 | 4× | | 输入24V | 4× |
eco655MVGE4IO尺寸图
eco655MVGE4IO引脚接线图
eco655MVGE4IO光谱响应图
eco655MVGE4IO购买地址
SVS eco655MVGE4IO_进口CCD_工业相机_机器视觉商城_LED光源_控制器_工业相机_镜头_图像采集卡_视觉配件_方案_系统_图像处理源代码_培训教程_论坛_机器视觉论坛_石鑫华视觉
http://visionbbs.com
