查看: 3980|回复: 0
[显微镜头] VST VS-LD系列低畸变微距工业镜头
    8 小时前
  • 签到天数: 3836 天
    连续签到: 29 天
    发表于 2015-5-11 15:07:54 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    概述
    VS-LD系列工业镜头
    Distortionless Macro Lens
    低畸变微距镜头
    Low distortion even when using extension tubes 10 models from focal lengths f4mm~f75mm
    很低的畸变,即使使用延长管时,10种型号,焦距从4mm到75mm
    Compact size: 32mm in diameter (except for VS-LD 6.5)
    紧凑小巧的尺寸:32mm直径(除了VS-LD6.5mm的镜头)
    For VGA ~3 Megapixel sensors
    可以适用于30万像素~300万像素图像传感器
    Reduced shading
    减少的像差
    镜头畸变对比图Distortion comparison chart
    VS-LD系列和常规镜头的畸变对比
    镜头平移Lens shift(对焦距离)
    VS-LD Series maintains low distortion and less shading by utilizing a higher amount of lens shift. The result is a lens with a great variety of WD and magnifications while maintaining a high quality image in the entire FOV.
    VS-LD系列使用更高的镜头平移空间也同样可以保持较低的畸变和较少的像差。其结果就是同一枚镜头可以使用多种不同的工作距离和放大倍数,也能在整个视场中保持较高的图像质量。
    VS-LD系列与普通常规镜头的镜头平移距离(对焦距离)
    型号与规格
    型号焦距f(mm)光学倍率工作距离(mm)光圈FTV畸变传感器靶面尺寸重量
    VS-LD440.01x~0.04x405.1~93.12.10~2.160.95%~0.92%1/2”52g
    VS-LD6.56.50.01x~0.06x631.5~892.28~2.40.11%~-0.01%1/2”50g
    VS-LD10100.02x~0.1x499.8~892.24~2.420.08%~-0.08%1/2”46g
    VS-LD15150.03x~0.15x491.8~91.82.06~2.30.11%~0.00%2/3”46g
    VS-LD20200.04x~0.22x511.0~86.82.22~2.600.06%~-0.15%2/3”45g
    VS-LD25N250.05x~0.25x511~1032.1~2.50.05%~-0.09%2/3”47g
    VS-LD30300.1x~0.23x312.7~143.12.20~2.460.03%~-0.05%2/3”46g
    VS-LD35350.3x~0.5x142.4~95.72.47~2.85~-0.03%2/3”58g
    VS-LD50500.1x~0.25x503.8~2132.70~3.06~0.05%2/3”73g
    VS-LD75750.15x~0.35x527.7~245.94.38~5.14~-0.02%2/3”100g
    购买
    购买本系列工业镜头,请登录机器视觉商城:
    http://visionbbs.com
    GMT+8, 2026-3-25 16:16
