查看: 4076|回复: 0
[面阵相机] ECO815CTLGEC-900万像素CCD千兆网工业相机
    昨天 11:03
  • 签到天数: 3581 天
    发表于 2015-5-21 16:01:59 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    SVCam-ECO² Standard标准SVcam-ECO2概述
    SVCam-ECO²
    Compact Power
    The SVCam-ECO² extends the range of the SVCam-ECO: In the same housing. Sensors with reasonable pixel sizes are optimized in terms of image quality and operating modes. So the GigE Vision interface is fully exploited. Thus, extremely demanding solutions can be solved easily.
    The ECO2 series comes with an extensive standard feature set that adds significant value to your application. Take the integrated LED illumination drivers, integrated in the SVS-VISTEK cameras; an example of how we contribute to conserving your total system costs. This feature, paired with its superb image quality, awards the ECO2 among the highest value of ownership on the market.
    Technical Highlights技术亮点
    >  Progressive Scan Sensor逐行扫描传感器
    >  2 x direct control and ability to drive LED lighting再个直接控制并驱动的LED指示灯
    >  logical trigger funktions逻辑触发功能
    >  Proven I/O-Concept: 2 x Input (0-24 V), 1 x Input RS-422, 证明IO观念:2个输入(0~24V),一个RS-422输入
    >  2 x Output (24 V, 0,3 A), 1 x Output RS-422, 1 x Serial RS-232两个输出(24V、0.3A),一个RS-422输出,一个RS-232串口输出
    >  C-Mount lens interface镜头接口为C接口
    >  Wide range Power conditions: 10 – 25 V DC宽范围供电电压:10~25VDC
    >  SDK for Windows (32/64 Bit) and Linux available二次开发包可用于32位/64位Windows系统和Linux系统
    >  Sequence-Shutter and enhanced Strobe-Functionality顺序快门和增强的闪光功能
    >  Prepared for Lens- and Pan/Tilt unit control镜头平移和倾斜控制单元
    >  GenICam Standard compliant兼容GenICam标准
    >  up to 120 MB/s data rate最高可达120MB/S的数据率
    >  cable length up to 100 Meter电缆最长可达100米
    >  broadcast-safe广播保险箱
    >  high value of ownership高性价比
    eco815CTLGEC参数
    SVCam-ECO² Series系列eco815CTLGEC型号
    Resolution分辨率3360 x 2712 px
    Frame rate帧率7 fps
    Chroma颜色bayer (RGB)
    Interface数据接口GigE Vision
    Sensor传感器
    Sensor传感器型号ICX815AQA
    Manufacturer传感器品牌Sony
    Sensor type传感器类型Area CCD
    Sensor architecture传感器架构interline transfer
    Readout type扫描方式progressive scan
    Sensor size (h x v)传感器尺寸12.4 x 10.01 mm
    Optical diagonal光学对角线15.93 mm
    Sensor format传感器格式1 "
    Pixel size (h x v)像素尺寸3.69 x 3.69 µm
    Camera相机
    Exposure modes曝光模式MANUAL;AUTO;EXTERNAL
    Trigger modes触发模式INTERNAL;SOFTWARE;EXTERNAL
    Exposure time (min)最小曝光时间42 µs
    Exposure time (max)最大曝光时间60 sec (external ∞)
    Pixel format / max像素格式(最大)bayer8, bayer12
    Gain modes / max增益模式(最大)manual, auto / 18 dB
    SNR信噪比58 dB / 9.6 bit
    Pixel clock像素时钟54 MHz
    Internal memory内部存储器64 MB
    Feature Set功能设置
    Manual white balance自动白平衡yes
    AOI兴趣区域yes
    LUT查找表yes
    Offset偏移yes
    Readout control读出控制yes
    Binning像素组合yes
    Image flip图像翻转       yes
    Defect pixel correction坏点校正yes
    Tap balancing接口平衡manual;auto
    Housing外壳
    Lens mount镜头接口C-Mount
    Dimensions (w x h x d)物理尺寸38 x 38 x 45 mm
    Weight重量150 g
    Protection class防护级别IP40
    I/O-Interfaces输入输出接口
    Input up to 24V输入接口(最大24)2 x
    Output open drain开漏电极输出2 x
    I/O RS-232 串口2321 x
    I/O RS-422 串口4221 x
    Power supply供电电压10 to 25 V (DC)
    Power consumption功率4 W
    Dimensions [mm]尺寸图
    Pinout引脚接线
    Spectral Response图像传感器光谱响应曲线
    购买链接
    SVS ECO815CTLGEC_进口CCD_工业相机_机器视觉商城_LED光源_控制器_工业相机_镜头_图像采集卡_视觉配件_方案_系统_图像处理源代码_培训教程_论坛_机器视觉论坛_石鑫华视觉
    http://visionbbs.com
    GMT+8, 2025-7-2 00:21
