查看: 3282|回复: 0
[NI驱动程序] NI-VISA3.1 Mac OS X 美国国家仪器虚拟仪器软件架构VISA3.1 苹果版下载
    13 小时前
  • 签到天数: 3851 天
    连续签到: 44 天
    发表于 2020-3-3 11:34:58 | 显示全部楼层 |阅读模式 来自:广东省东莞市 联通
    NI-VISA3.1:
    链接:请注册视觉论坛会员登录后购买附件下载查看
    提取码:请购买附件下载查看
    NI-VISA3.1:
    请购买附件下载查看
    VISA3.1M.txt (617 Bytes, 下载次数: 0, 售价: 10 圆)
    National Instruments NI-VISA(TM) Software for Mac OS X. Version 3.1.
    Copyright(c) 1995, 2004 National Instruments Corporation. All rights reserved.
    NATIONAL INSTRUMENTS HOLDS MULTIPLE COPYRIGHTS, TRADEMARKS, AND PATENTS
    FOR THIS PRODUCT.  BY DOWNLOADING AND/OR INSTALLING THIS PRODUCT, YOU
    AGREE TO THE TERMS OF THE license.txt FILE THAT RESIDES IN THE SAME DIRECTORY
    AS THIS readme.txt FILE ON THE CD AND/OR WEB SITE.  FOR PATENTS COVERING
    NATIONAL INSTRUMENTS PRODUCTS, REFER TO THE patents.txt FILE ON THE ROOT
    DIRECTORY OF YOUR CD (IF APPLICABLE) AND/OR www.ni.com/patents.
    CONTENTS OF THIS FILE
    Support for new VISA Features
    VISA Support for Multiple GPIB-VXI Controllers
    Installed Files and Paths
    VISA Probes for LabVIEW 7.x
    NI-VISA 3.0 Improvements and Bug Fixes
    NI-VISA 3.1 Improvements and Bug Fixes
    Credits
    SUPPORT FOR NEW VISA FEATURES
    The NI-VISA Help (in HTML format) describes the new features of NI-VISA 3.1,
    but they are briefly listed here for your convenience.  The help is installed
    in "/National Instruments/NIvisa/Manuals".
    We now support remote NI-VISA access.  Any machine with the NI-VISA server
    can export its resources to other NI-VISA clients.  Only the client is
    supported on Mac OS X and its settings are configured in VisaConfig. To use
    a remote VISA resource, the name is a URL including the machine name or IP
    address, followed by the traditional VISA resource name.  Examples include:
    "visa://machine.domain.com/GPIB0::5::INSTR"
    "visa://1.2.3.4/ASRL2::INSTR"
    Remote NI-VISA fully supports all functionality of all interface types,
    including message based, register based, and all events.
    NI-VISA 3.0 on Mac OS X added TCP/IP functionality for both raw (SOCKET)
    and VXI-11 (INSTR) protocols.  This was added in NI-VISA 2.5 on Win32.
    This driver also supports the National Instruments ENET-Serial products.
    See the Serial section in chapter 9 of the NI-VISA User Manual for details.
    Note that the NI-488 driver only supports the GPIB-ENET, so in turn,
    NI-VISA also only supports the GPIB-ENET.
    VISA SUPPORT FOR MULTIPLE GPIB-VXI CONTROLLERS
    NI-VISA supports multiple GPIB-VXI controllers in a single system. Because
    the National Instruments GPIB-VXI controller ships with a primary address
    of 1, NI-VISA automatically searches for any GPIB-VXI controllers at that
    address.
    If you have changed the primary address (for example, if you added a second
    GPIB-VXI controller to your system, and set the address of the second
    controller to 9), or if you have a GPIB-VXI controller from another vendor,
    then you need to make changes to the visaconf.ini file which is located at
    "/Library/Prefereneces/NIvisa/visaconf.ini".
    If you are using a GPIB-VXI command module from another vendor, you also
    need to obtain and install that vendor's VISA GPIB-VXI component.
    INSTALLED FILES AND PATHS
    There are three main locations where NI-VISA installs files.
    The local "/Library/Frameworks" folder contains the VISA.framework folder.
    This folder contains all needed headers, and supporting Passport libraries
    that NI-VISA uses.
    In the local "/Applications/National Instruments" folder, there is an
    NIvisa folder.  Included here are the user and programmer manuals, as well
    as several groups of C examples using NI-VISA.
    This NIvisa folder also includes a graphical utility named VisaConfig to
    configure VISA options.
    Finally, the "/Library/Preferences" folder contains an NIvisa folder with
    INI files.  These files are used for NI-VISA settings and status codes.
    VISA PROBES FOR LABVIEW 7.x
    The VISA probes for LabVIEW 7.x greatly extend the amount of relevant
    information displayed when using LabVIEW probes on VISA refnums. They are used
    automatically by LabVIEW in place of the generic probe when they are
    installed.
    To install them, download them from "ftp.ni.com/support/visa/labview/probes/"
    and copy them into "/vi.lib/_probes/default/VISA/" where
    is the installation directory of LabVIEW.
    NI-VISA 3.0 IMPROVEMENTS AND BUG FIXES
    When you open a VISA session to GPIB0::INTFC and immediately query the
    attribute VI_ATTR_GPIB_SRQ_STATE, it previously returned the value
    VI_STATE_UNASSERTED.  It now returns VI_STATE_UNKNOWN because the SRQ line
    cannot be monitored if the interface is not yet CIC.  The correct state is
    returned after calling viGpibSendIFC.
    For a TCPIP INSTR resource, calling viTerminate did not work correctly.
    For a TCPIP INSTR resource, calling viRead or viWrite with a large buffer
    occasionally would return an error without transmitting the entire buffer.
    For a TCPIP INSTR resource, opening and closing sessions to multiple host
    addresses would cause NI-VISA to crash.
    For a TCPIP INSTR resource, calling viLock with a timeout longer than the
    I/O timeout for that session could cause NI-VISA to return VI_ERROR_TMO.
    For a TCPIP SOCKET resource, viReadAsync was not implemented.  Now it is.
    For a Serial INSTR resource, viOpen will now open a port if the process
    that had been using that port exited ungracefully (such as with Ctrl-C).
    The previous behavior had been that viOpen would return VI_ERROR_RSRC_BUSY.
    For a Serial INSTR resource, if you enabled RTS/CTS flow control and then
    manually tried to set the state of the RTS line, some operating systems
    would generate VI_ERROR_NSUP_ATTR while others would return VI_SUCCESS but
    not actually modify the state of the line.  Neither of these behaviours was
    correct.  Now NI-VISA will return VI_ERROR_INV_SETUP in this case on all
    operating systems.
    For a Serial INSTR resource, if a binding existed to a valid file/device
    but that file/device was not really a serial port, then NI-VISA would
    not close the handle.  Repeated calls to viFindRsrc or viOpen would cause
    the process to eventually run out of file handles.  This has been fixed.
    If you had a GPIB device at primary address 1 that generated a response to
    *IDN? that was longer than 100 characters, viFindRsrc would occasionally
    crash.  This has been fixed.
    viFindRsrc would crash on a complex expression with multiple "|" symbols.
    viScanf %# modifier will now output the number of characters put into the
    buffer excluding the terminating null character.  This applies to the %#s,
    %#t, %#T, and %#[] modifiers. NI-VISA treats the maximum array size
    (specified on input) as the total buffer size including the terminating null
    character.
    Calling viFindRsrc repeatedly when logged in as root would eventually run
    out of file descriptors.  This has been fixed.
    The attributes VI_ATTR_MANF_NAME and VI_ATTR_MODEL_NAME are now correctly
    implemented for GPIB-VXI regardless of whether NI-VXI is installed.
    The maximum simultaneous number of GPIB-VXI controllers supported by
    NI-VISA has changed from 10 to 32.
    For a Serial INSTR resource, the internal modem is now correctly detected.
    For a Serial INSTR resource, during a viFindRsrc, when a previously found
    serial port was detected again, the scan would not proceed to find any
    new serial ports.  This has been fixed.
    For a Serial INSTR resource, a call to viOpen when the corresponding
    serial port did not exist returned VI_ERROR_SYSTEM_ERROR.  This return
    value has been corrected to VI_ERROR_RSRC_NFOUND.
    When calling viWaitOnEvent repeatedly with a timeout of 0 (immediate), some
    interfaces and event types would still consume excessive CPU time.  Now doing
    this will yield the CPU regardless of the interface or event type.
    For a GPIB resource, the operations viWriteAsync and viReadAsync did not
    support true asynchronous operations.  The data would still transmit and
    receive, but NI-VISA did it synchronously.  This has been fixed.
    viFindRsrc would return VI_ERROR_INV_EXPR if the expression exceeded 255
    characters.  Now it will accept resource expressions of any length.
    Calling viFindRsrc would always assert REN on each GPIB board after finding
    devices.  Now viFindRsrc will re-assert REN on each board only if there is
    at least 1 open VISA INSTR session on that board.
    For a TCPIP SOCKET resource, using viRead with termchar enabled was much
    slower than reading the exact number of bytes.  The performance of using
    termchar with viRead is now much better than it was.
    Calling viFindRsrc would return serial ports even if they were explicitly
    disabled in the configuration file.
    NI-VISA 3.1 IMPROVEMENTS AND BUG FIXES
    Reading data from a Serial port was slow.  The performance has improved.
    Using the Serial Break VI from LabVIEW did not work with remote NI-VISA.
    For a Serial INSTR resource, if a parity or framing error occurred, NI-VISA
    would not return the correct error condition.  This has been fixed.
    In the VisaConfig application, using the "Browse" button in the Enet-Serial
    dialog would not work.  This has been fixed.
    Calling viOpen on a remote NI-VISA resource did not honor the openTimeout
    parameter.  This has been fixed.
    Calling viFindRsrc on a remote system would cause LabVIEW to later crash
    when you exit.  This has been fixed.
    Calling viClose on an ethernet resource would leak a socket handle.  This
    has been fixed.
    The global attributes on a GPIB INTFC resource were not properly shared
    across sessions.  This has been fixed.
    Using the system call "fork" on a process with VISA loaded would sometimes
    cause the forked process to hang.  This has been fixed.
    CREDITS
    This product includes components that use the socket++ library.  The library
    is Copyright(C) 1992-1995 Greg Lavender (University of Texas) and
    Gnanasekaran Swaminathan (University of Virginia).  All rights reserved.
    KNOWN ISSUES
    1. Callbacks for any event on a GPIB INTFC session might not work unless
    you make a call to the VISA driver.  For more information see the
    Interrupt Callback Handler section in chapter 10 of the User Manual.
    GMT+8, 2026-4-9 21:29
