查看: 5275|回复: 3
[驱动] 菲力尔FLIR-灰点Point Grey工业相机WinX86/X64系统驱动SpinnakerSDK完整版1.29.0.5
    半小时前
  • 签到天数: 3850 天
    连续签到: 43 天
    发表于 2020-7-22 15:02:15 | 显示全部楼层 |阅读模式 来自:广东省东莞市 电信
    版本:
    SpinnakerSDK_FULL_1.29.0.5_x64
    链接: https://pan.baidu.com/s/1MfHd4MWpPSBIyMzuBVnm9Q 提取码:
    SpinnakerSDK_FULL_1.29.0.5_x86
    链接: https://pan.baidu.com/s/16cAHlMuP_-4rBN4a5FQL_w 提取码:
    Spinnaker SDK - 1.29.0.5
    - CHANGE LIST (list of updates with this version):
    Enhancements:
    - SpinView_WPF Auto Force IP should log a warning if no cameras are found
    - AcquisitionMultipleCamera Has Been Replaced By AcquisitionMultipleCameraRecovery
    - Update Spinnaker triggering examples to set TriggerSelector to FrameStart
    - Add support link to SpinView_WPF and SpinView_Qt
    - Spinnaker Ubuntu Dependency Installation
    Resolved Issues:
    - Linux installer tries to find Qt libraries in /usr/lib/
    - Issue with multiple device reset on Ubuntu
    - Single device shows two cameras in updater mode
    - SpinView_Qt crashes if the path to inference label is invalid
    - Spinview_QT cannot connect to camera in "Show only connected adapters" mode
    - Spinview_QT does not give feature descriptions when searching for feature
    - SpinView_WPF GUI hangs after executing force IP unless refreshing the device list
    - SpinView_WPF does not reset device tab view after GEV interface force IP
    - SpinView_WPF crashes when snapping image
    - Spinnaker Installer States a Newer Version of Spinnaker is Installed When an Older Version of Spinnaker is Installed
    - Windows USB transfer could be cancelled on active final1 packet during EndAcquisition()
    - Classification confidence shows 200% in SpinView_WPF
    - EndAcquisition() takes long when gdb is used
    - SpinPixelCorrection_WPF Crashes when applying filter
    - Spinnaker CameraPtr::EndAcquisition() hangs for 1.28.0.23
    - Fix Firmware update getting stuck at 97% issue
    Spinnaker SDK - 1.28.0.23
    Enhancements:
    - SpinView_Qt - add ability to cascade displays (streaming window) horizontally
    - SpinView_Qt - add a progress indicator to File Access tab
    - SpinView_Qt - Have inference data tied to streaming window rather than image
    - SpinView_Qt - Add Camera FPS counter
    - StatusBarControls should be part of SpinView_WPF instead of GUI XML
    - Add support for device specific JPEG-LS payload type
    - Clang format for C#
    Resolved Issues:
    - SpinView_Qt Linux Acquisition Mode Dropdown Menu Is Cut Off
    - Versions of some example exe's are never updated
    - EXC_CRASH when trying to start SpinView and other precompiled examples in MAC OS with Spinnaker v1.24.0.60
    - AdapterConfigGUI forces user to set default gateway on network adapters
    - SpinView 1.26.0.31 camera not visible and auto force IP does nothing
    - SpinView_WPF 1.25 takes longer time to enumerate GigE cameras than 1.20
    - SpinView_Qt crashes (or does not stream again) when stream window is closed while streaming
    - SpinView_Qt Write-to-DDR tooltip has extra spaces
    - SpinView_Qt crashes with segfault when disconnecting an initialized/streaming camera
    - Spinview_Qt 1.27.0.48 segfaults when Ax5 is selected
    - SpinView_Qt category node names are editable
    - SpinView_Qt crashes when streaming from software disconnect and reconnect
    - Searching camera feature in SpinView_Qt does not work with spaces
    - Cannot restart acquisition after DeviceReset on RaspberryPi3
    - FFY-U3: Intel USB active transfer cancel fix.
    - SpinView WPF does not reset device tab view after GEV interface force IP
    - Saving snapshot crashes SpinView_WPF
    发表于 2020-9-30 17:07:56 | 显示全部楼层 来自:广东省佛山市 电信
    发表于 2022-2-18 19:40:09 | 显示全部楼层 来自:江苏省 电信
    发表于 2022-4-17 14:39:13 | 显示全部楼层 来自:江苏省苏州市 移动
    GMT+8, 2026-4-8 08:48
