TA的每日心情 | 郁闷 半小时前 |
发表于 2020-7-22 15:07:04
来自:广东省东莞市 电信
菲力尔FLIR-灰点Point Grey工业相机MAC OS苹果系统驱动Spinnaker-2.0.0.109
版本:
Spinnaker-2.0.0.109
链接: https://pan.baidu.com/s/1Pu0FFnDKNJPDN4TG0hsjrQ 提取码:
Spinnaker SDK - 1.29.0.5
- CHANGE LIST (list of updates with this version):
Enhancements:
- SpinView_WPF Auto Force IP should log a warning if no cameras are found
- AcquisitionMultipleCamera Has Been Replaced By AcquisitionMultipleCameraRecovery
- Update Spinnaker triggering examples to set TriggerSelector to FrameStart
- Add support link to SpinView_WPF and SpinView_Qt
- Spinnaker Ubuntu Dependency Installation
Resolved Issues:
- Linux installer tries to find Qt libraries in /usr/lib/
- Issue with multiple device reset on Ubuntu
- Single device shows two cameras in updater mode
- SpinView_Qt crashes if the path to inference label is invalid
- Spinview_QT cannot connect to camera in "Show only connected adapters" mode
- Spinview_QT does not give feature descriptions when searching for feature
- SpinView_WPF GUI hangs after executing force IP unless refreshing the device list
- SpinView_WPF does not reset device tab view after GEV interface force IP
- SpinView_WPF crashes when snapping image
- Spinnaker Installer States a Newer Version of Spinnaker is Installed When an Older Version of Spinnaker is Installed
- Windows USB transfer could be cancelled on active final1 packet during EndAcquisition()
- Classification confidence shows 200% in SpinView_WPF
- EndAcquisition() takes long when gdb is used
- SpinPixelCorrection_WPF Crashes when applying filter
- Spinnaker CameraPtr::EndAcquisition() hangs for 1.28.0.23
- Fix Firmware update getting stuck at 97% issue
Spinnaker SDK - 1.28.0.23
Enhancements:
- SpinView_Qt - add ability to cascade displays (streaming window) horizontally
- SpinView_Qt - add a progress indicator to File Access tab
- SpinView_Qt - Have inference data tied to streaming window rather than image
- SpinView_Qt - Add Camera FPS counter
- StatusBarControls should be part of SpinView_WPF instead of GUI XML
- Add support for device specific JPEG-LS payload type
- Clang format for C#
Resolved Issues:
- SpinView_Qt Linux Acquisition Mode Dropdown Menu Is Cut Off
- Versions of some example exe's are never updated
- EXC_CRASH when trying to start SpinView and other precompiled examples in MAC OS with Spinnaker v1.24.0.60
- AdapterConfigGUI forces user to set default gateway on network adapters
- SpinView 1.26.0.31 camera not visible and auto force IP does nothing
- SpinView_WPF 1.25 takes longer time to enumerate GigE cameras than 1.20
- SpinView_Qt crashes (or does not stream again) when stream window is closed while streaming
- SpinView_Qt Write-to-DDR tooltip has extra spaces
- SpinView_Qt crashes with segfault when disconnecting an initialized/streaming camera
- Spinview_Qt 1.27.0.48 segfaults when Ax5 is selected
- SpinView_Qt category node names are editable
- SpinView_Qt crashes when streaming from software disconnect and reconnect
- Searching camera feature in SpinView_Qt does not work with spaces
- Cannot restart acquisition after DeviceReset on RaspberryPi3
- FFY-U3: Intel USB active transfer cancel fix.
- SpinView WPF does not reset device tab view after GEV interface force IP
- Saving snapshot crashes SpinView_WPF
